RE: [AVR-Chat] ATMEGA64L, ATMEGA64
2011-01-31 by Tim Mitchell
----Original Message----
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of Clark Martin Sent: 30 January 2011 22:49 To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] ATMEGA64L, ATMEGA64 > On Jan 30, 2011, at 2:25 PM, Tim Mitchell wrote: > > > > If this is a one-off device and you have a chip that > > runs at 16Mhz, you'll be fine. I would not do it for > > production though as sooner or later you will get some > > that don't work. > > > I'd avoid doing it at all if possible. It might work > today, it might work tomorrow but it might not the next > day. Temperature is one variable that might affect it's > working, if it gets too hot or too cold it might stop > working. Also it might work, or at least seem to but you > might be getting errors that throw off the circuit's > operation without causing it to fail altogether. > You may be right, but this was not my experience, and I hammered the devices in all sorts of conditions (not knowing about the 8Mhz limitation until I came across a couple that didn't work properly) - if they worked at all at 16Mhz then they were pretty solid. The 8MHz-only ones either would not start up, or locked up after running for a couple of seconds. -- Tim Mitchell
