AVR-Chat
Setting timer0 on Atmega48
2011-09-24 by Philippe Habib
This should be a simple thing but I'm having trouble getting it to work.
I want a regular interrupt every 10ms while using the internal 8Mhz oscillator.  I'm using AVR studio with the default (GCC?) compiler.
Can someone let me know what I'm doing wrong?
I try to set the various timer registers like this:
	TCCR0A = 0x00;
	TCCR0B = 0x05;
	TCNT0 = 177;
	TIMSK = 0x01;
What I'm hoping for here is a timer that will use the div1024 start at 177 and set off the timer int when it overflows at 255.
Then I turn on interrupts
        SEI();
Here is my ISR:
#if __GCC__
SIGNAL(SIG_OVERFLOW0)
#else
#pragma vector=TIMER0_OVF_vect
__interrupt void TIMER0_OVF(void)
#endif
	uccounter++;
	TCNT0 = 177;	// reset the timer
	return;
uccounter is a global unsigned char.  I just use it to toggle a port when its 0.
Am I missing something and is there a library call that makes setting all this easier?
Thanks.
Re: [AVR-Chat] Setting timer0 on Atmega48
2011-09-24 by Jim Wagner
Hello, Phillipe
First, signal is deprecated for use in gcc.
Second, 8MHz divided by 1024 gives a tick every 128uS. You cannot get
1ms from that,  because it would take 7.8125 clock "ticks".
Third, by far the easier way to count a specific number of clock ticks
is to set the compare value in a compare register and have the counter
reset. You can then count, additionally, on the overflow interrupt. No
counter reloading is needed.
Jim Wagner
Oregon Research Electronics
> work.
> TCCR0A = 0x00;
> TCCR0B = 0x05;
> TCNT0 = 177;
> TIMSK = 0x01;
> SEI();
> Here is my ISR:
> #if __GCC__
> #else
> #endif
> uccounter++;
> return;
> when its 0.
> Thanks.
Thanks for the reply.
I wanted a tick every (about) 10ms so I got 78 ticks, subtracted that from the overflow value of 255 and came up with the 177 which I used as my start value.
So I think what you're suggesting is that I set 78 in a compare register and then have my isr get called on compare.  That's fine too.
Am I on the right track as far as the registers I've set?
Thanks.
To: AVR-Chat@yahoogroups.com
Sent: Saturday, September 24, 2011 3:23:19 PM
Subject: Re: [AVR-Chat] Setting timer0 on Atmega48
Hello, Phillipe
Jim Wagner
> work.
> TCCR0A = 0x00;
> TCCR0B = 0x05;
> TCNT0 = 177;
> TIMSK = 0x01;
> SEI();
> Here is my ISR:
> #if __GCC__
> #else
> #endif
> uccounter++;
> return;
> when its 0.
> Thanks.
Yahoo! Groups Links
Yes, by far easier to set the 78 in a compare register. Look at the
Timer0 mode list for the bit combination to reset on compare; you may
not be able to do that with all compare registers (for that timer).
Please use the ISR() construction. Many of the newer chips do NOT have
signal vector definitions. The table of vector names is in the avr-
libc document.
Jim
> Thanks.
> From: "Jim Wagner" <wagnerj@proaxis.com>
> Hello, Phillipe
> Jim Wagner
> > work.
> > TCCR0A = 0x00;
> > TCCR0B = 0x05;
> > TCNT0 = 177;
> > TIMSK = 0x01;
> > SEI();
> > Here is my ISR:
> > #if __GCC__
> > #else
> > #endif
> > uccounter++;
> > return;
> > when its 0.
> > Thanks.
2011-09-24 by Clark Martin
I don't have the data sheet for the 48 handy so I looked at the 168 but they are similar.
> TCCR0A = 0x00;
> TCCR0B = 0x05;
Your setup here is configuring the counter for Normal operation.  You can do it this way but it s simpler and more accurate to use CTC mode.  Once set it will interrupt every 10mS (approx) without having to set any registers.
For the 168 this means:
TCCR0A	= 0x02;
TCCR0B	= 0x05;
> TCNT0 = 177;
And
OCR0A	= 78;
> TIMSK = 0x01;
TIMSK0		= 0x02;
Note that it's more readable to use the bit constants (defined in the various ioXXX.h files) ie:
TCCR0A	= (1 << WGM01) | (0 << WGM00);
TCCR0B	= (0 << WGM02) | (1 << CS02) | (0 << CS02) | (1 << CS02);
TIMSK0		= (1 << OCIE0A);
It makes it clearer what the bits are doing.  It also makes it easier to port it to other processors.  If the new processor doesn't have certain bits the compiler will flag it as an error.  A hex constant won't.
> SEI();
> Here is my ISR:
And here you'd use the OCR0A interrupt
> #if __GCC__
> #else
> #endif
> uccounter++;
> return;
You don't actually say here what if anything happened when you did this.
Clark Martin
Redwood City, CA, USA
Macintosh / Internet Consulting
"I'm a designated driver on the Information Super Highway"
2011-09-24 by R E Purcella
Ok, I see a change in the thread from mega 8 (which doesn't have compare
function in timer0) and now to mega48 (which does)
rep
> libc document.
> Jim
>> Thanks.
>> ----- Original Message -----
>> From: "Jim Wagner"<wagnerj@proaxis.com>
>> Hello, Phillipe
>> Jim Wagner
>>> work.
>>> TCCR0A = 0x00;
>>> TCCR0B = 0x05;
>>> TCNT0 = 177;
>>> TIMSK = 0x01;
>>> SEI();
>>> Here is my ISR:
>>> #if __GCC__
>>> #else
>>> #endif
>>> uccounter++;
>>> return;
>>> when its 0.
>>> Thanks.
>> Yahoo! Groups Links
2011-09-25 by Philippe Habib
Thank you.  I had to quit working on this yesterday, but its working now.  I'm used to using compilers that have all of these functions brought out in an idiot ready interface so I'm afraid I don't know all of the ins and outs of the registers and all of their interactions as well as I'd like.
Sent: Saturday, September 24, 2011 3:53:43 PM
> TCCR0A = 0x00;
> TCCR0B = 0x05;
TCCR0A	= 0x02;
TCCR0B	= 0x05;
> TCNT0 = 177;
And
OCR0A	= 78;
> TIMSK = 0x01;
TIMSK0		= 0x02;
> SEI();
> Here is my ISR:
> #if __GCC__
> #else
> #endif
> uccounter++;
> return;
Clark Martin
Yahoo! Groups Links
Re: Setting timer0 on Atmega48
2011-09-25 by greggy
The data sheet can often throw some light on the chips abilities and workings also...
--- In AVR-Chat@yahoogroups.com, M W <rd232d@...> wrote:
> I find that it helps a LOT sometimes to read the .h files for the specific micro I'm on, lets me know what's in there & usually then I can figure out why. Helps :)
>   Mark
> From: Philippe Habib <phabib@...>
> Cc: AVR-Chat@yahoogroups.com
> Sent: Sunday, September 25, 2011 9:31 AM
2011-09-25 by M W
  Mark
2011-09-25 by Clark Martin
I rarely need to go to the .h file.  I use the Atmel PDF docs and look at the Register Description.  The avrlibc include files match up quite nicely.  The one exception is the IRQ vector names so I do go into the include files for vector names, that is when I can't guess it.
>   Mark
> From: Philippe Habib <phabib@well.com>
Clark Martin
