AVR-Chat
Re: aviation use of atmega's
2012-01-25 by Mike Bronosky
Checking with a sales rep would be a great idea.
http://www2.atmel.com/about/contact/default.aspx?contactType=Atmel+Sales+Office
You can probably get some free samples to get you started.
Linux since March 2004
www.counter.li.org
Registered Linux User: #482134
Taking up Linux Ubuntu and give-up the Windos habit.
Hasta la Vista, Baby. I won't be back!
Re: [AVR-Chat] Re: aviation use of atmega's
2012-01-25 by tim gilbert
Rule #1 of product development: don't design in parts that are hard to get!  If the major distributors don't stock it; don't use it.  Customers tend to get upset when their production runs get delayed because you used a non-stocked part.
Free sample are nice, but I want to know that I can get parts when needed and not have to wait 12 weeks for the factory to ship.
Tim Gilbert
JEM Innovation Inc.
303-926-9053 (office)
303-437-4342 (cell)
www.jeminnovation.com
www.pdksolutions.com
  To: AVR-Chat@yahoogroups.com
  Sent: Wednesday, January 25, 2012 11:08 AM
  Subject: [AVR-Chat] Re: aviation use of atmega's
  www.counter.li.org
2012-01-25 by wagnerj@proaxis.com
Arrow has 1,730 of ATmega88-15AD. I would call them a "major distributor".
However, the spec'd "Absolute Maximum" of -55C to +150C is not matched by
the spec sheet data which only covers the range of -40C to +150C. Bummers!
Jim Wagner
Oregon Research Electronics
> a non-stocked part.
> Regards,
> Tim Gilbert
> JEM Innovation Inc.
> 303-437-4342 (cell)
>   ----- Original Message -----
>   From: Mike Bronosky
>   www.counter.li.org
2012-01-26 by Alex A
Actually, if you want to look for the automotive grade parts, look at something like part number ATmega168-15AZ.  These are the rated more for the upper end of the scale rather than the lower end.
When the data sheet says Absolute Maximum, these are the specs that the vendor will guarantee the part.  However, the Atmel datasheet also states "Exposure to absolute maximum rating conditions for extended periods may affect device reliability."  This is pretty much the case for any vendor you look at.
> Jim Wagner
> > a non-stocked part.
> > Regards,
> > Tim Gilbert
> > JEM Innovation Inc.
> > 303-437-4342 (cell)
> >   From: Mike Bronosky
> >   www.counter.li.org
Re: Mixing C and assembly with special requirements.
2012-03-26 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, fireweaver <firewevr@...> wrote:
> Can I somehow tell the C compiler that comes with AVR
> Studio that these certain five registers are reserved
> for the exclusive use of the decoder and therefore avoid
>  using them in any way?
In general, no.  It is possible to "reserve" any of the registers r2 to r7 but doing so requires great care in constructing your application so that *no other code* uses the reserved registers.  In particular, this means that the register reservation must be specified in every module comprising your application and, further, that you either avoid using any of the AVR-libc routines or confirm that the ones that you do use do not use your chosen reserved registers.  Note, too, that you must perform this confirmation exercise for *every* new release of AVR libc because register allocation may change with each release.
This question has been posed many times on the AVR Freaks forum.  The strategy is generally discouraged because of the potential problems.
Don Kinzer
ZBasic Microcontrollers
http://www.zbasic.net
Re: [AVR-Chat] Mixing C and assembly with special requirements.
2012-03-26 by David Kelly
On Mar 26, 2012, at 2:57 PM, fireweaver wrote:
> I have a question of some concern to me, perhaps you could help.
> In overview, it involves mixing assembly language and C code.
> In detail:
> The CPU that I am using is ATmega328 using AVR Studio 5 as a development
> environment.
> I an writing a motor control application that involves a quadrature encoder
> attached to the motor shaft and a corresponding decoder with the following
> characteristics:
> [1] The decoder itself is implemented entirely in assembly language.
> [2] All the rest of the application will be written in C.
> [3] It maintains a running 24-bit count of the encoder's position.
> [4] It will be called by a periodic interrupt at 25 kHz sample rate.
> [5] THE DECODER RESERVES FIVE OF THE MACHINE REGISTERS FOR ITS EXCLUSIVE
> USE.
>     This is the big deal I want to question you about.
> What I want to do is this:  Can I somehow tell the C compiler that comes
> with AVR Studio that these certain five registers are reserved for the exclusive
> use of the decoder and therefore avoid using them in any way?
Question for you: Why are you so determined to implement the decoder in assembly? What evidence do you have to support the additional effort and future difficulty in maintaining the code?
The biggest compromise I see to use C is that the counter will be 32 bits. If you must, let C calculate to 32 bits and then chop it down to 24. You can use a mask to reach the high 8 bits, or overlay the 32 bits with a bitfield.
Don't worry about the "5 dedicated registers". Use static variables in C and if they have to be stashed in RAM then let them. Its a machine, its not going to complain about repetitive tasks. And as a machine if its fast enough to get the job done, and done correctly, then don't sweat the details.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
> The decoder I have does its thing in about 28 cycles.  As a C
> interrupt routine, it is well over 100 cycles and may not be
> able to keep up with the encoder.
If you are willing to post the existing assembly code and provide an upper limit on the number of cycles that is acceptable, I expect that you would have several people rise to the challenge to make it avr-gcc compatible or re-implement it so that it is compatible.
Don Kinzer
2012-03-26 by fireweaver
In detail:
environment.
characteristics:
USE.
with AVR
use of the
erikc
>> In detail:
>> environment.
>> characteristics:
>> USE.
This is a one off hobby project.  I am retired and living within a very
tight budget, so buying a dedicated decoder chip like this one below
would hurt.
http://www.avagotech.com/pages/en/motion_control_encoder_products/integrated_circuits/decoder_ic/hctl-2022/
The decoder was originally created (in a two-channel version) to act as
a digital readout for a milling machine.  I used rotary encoders
attached to the table leadscrews to generate the count pulses.  That
project was 100% assembler (for small code size - originally written for
an ATTiny2313).  It works very well.
The motor control thing is mainly experimental.  I suppose I could talk
an ATTiny part into doing the decoder function, it is an idea worth
considering,  At least they're in my price range.
Implementing the decoder in C would just massively slow things down.
I'll try it but I think there will be problems.  The decoder I have does
its thing in about 28 cycles.  As a C interrupt routine, it is well over
100 cycles and may not be able to keep up with the encoder.  On second
thought, perhaps by dividing the task among more than one processor
might be a good way to go.
Re: [AVR-Chat] Re: Mixing C and assembly with special requirements.
2012-03-27 by fireweaver
> Don Kinzer
Here is the code.  I don't know how this will appear since the group
forbids attachments.
Use a fixed width font like Courier to make it look right.
The general idea is to control a motor which can run up to 3000 RPM.  It
has an built-in
encoder with 400 counts (at 4X) per revolution.
; SINGLE CHANNEL QUADRATURE DECODER
;  This is the quadrature decoder.  This decoder is designed to decode
two      ;
; channels to a resolution of one part in 2^24.   It is designed to run
as fast ;
; as
possible.        ;
; Selling
points:                                                               ;
;       1.  One channel to 24-bit
precision.                                    ;
;       2.  Very fast execution time = 25 cycles worst
case.                    ;
;       3.  Small code
size.                                                    ;
;       4.  Extensible to more channels (as dedicated
encoder)                  ;
; Weak
points:        ;
;       1.  Commandeers 4 registers for its own
use.                            ;
.include        "m168Adef.inc"
;   Defined by original
project                                                 ;
ATmega168                                    ;
/----U----\                                   ;
;                             PC6 | 01   28 |
PC5                               ;
;               (X-axis I in) PD0 | 02   27 |
PC4                               ;
;               (X-axis Q in) PD1 | 03   26 |
PC3                               ;
;               (X error out) PD2 | 04   25 |
PC2                               ;
;                             PD3 | 05   24 |
PC1                               ;
;                             PD4 | 06   23 |
PC0                               ;
;                             VCC | 07   22 |
GND                               ;
;                             GND | 08   21 |
AREF                              ;
;                             PB6 | 09   20 |
AVCC                              ;
;                             PB7 | 10   19 |
PB5                               ;
;                             PD5 | 11   18 |
PB4                               ;
;                             PD6 | 12   17 |
PB3                               ;
;                (duty cycle) PD7 | 13   16 |
PB2                               ;
;                             PB0 | 14   15 |
PB1                               ;
; (duty cycle) is used to see how long the routine
runs                         ;
; PORTD bits are laid out as
follows:                                           ;
.equ   CH_X0    = PD0   ; Channel A inphase in
.equ   CH_X1    = PD1   ; Channel A quadrature in
.equ   ERR_X    = PD2   ; Channel A error signal out
.equ   OC2B     = PD3   ; Timer overflow bit (diagnostic output).
.equ   Q_DEBUG  = PD7   ; Duty cycle informs on CPU usage ()
; Reserved register
assignments.                                                ;
; Encoder
management                                                            ;
        .def    encoder_state    = R9
; X-count accumulator (dedicated to
encoder)                                    ;
        .def    X_count_0        = R21   ; low byte
        .def    X_count_1        = R22
        .def    X_count_2        = R23   ; high byte
; This code is may be located anywhere in
memory.                               ;
;        _______         ___________         _______     ___
___        ;
; A |___/   |   \___|___/   |   |   \___|___/   |   \___/   \___|___/
\___/   ;
;   |   |   |___|___|   |   |___|   |   |___|___|   |   |___|   |___|
|___    ;
; B \___|___/   |   \___|___/   \___|___/   |   \___|___/   \___/
\___/   \   ;
;    -6  -5  -4  -3  -2  -1   0   1   2   3   4   5   6   ?   ?  OK
;   |                  normal operation                 | error
codes       |   ;
;                                                        ? = Error, K =
Okay    ;
; The encoder is periodically sampled.  Each sample is compared to the
previous ;
; sample giving one of 16 possible choices.  These choices funnel into
four     ;
; possible actions, depending on how the bits change between
samples.           ;
;  Sampling rate is required to be at least twice the rate of incoming
encoder  ;
; pulses to ensure accurate
counting.                                           ;
; These actions
are:                                                            ;
;        Increment - add one to the count
register                              ;
;        Decrement - subtract one from the count
register                       ;
;        Idle - inputs did not change, do
nothing                               ;
;        Error - should never happen, both inputs changed at the same
time.     ;
;               If the error signal comes and goes, it is a sign that
the input ;
;               is changing too fast for the decoder to keep up
with.           ;
; A,B
A,B        ;
; Was     Is      Do
This                                                       ;
; 00      00
idle                                                          ;
; 00      01
increment                                                     ;
; 00      10
decrement                                                     ;
; 00      11
error                                                         ;
; 01      00
decrement                                                     ;
; 01      01
idle                                                          ;
; 01      10
error                                                         ;
; 01      11
increment                                                     ;
; 10      00
increment                                                     ;
; 10      01
error                                                         ;
; 10      10
idle                                                          ;
; 10      11
decrement                                                     ;
; 11      00
error                                                         ;
; 11      01
decrement                                                     ;
; 11      10
increment                                                     ;
; 11      11
idle                                                          ;
.cseg
.org    0x100
Quadrature_Decoder:
; do all preparation in advance         ;(cycles)
         lsr     encoder_state           ;(1)  current X,Z state becomes
previous
         in      ZH,PIND                 ;(1)  sample the inputs once
; update the state of the X-input
         bst     ZH,CH_X1                ;(1)
         bld     encoder_state,1         ;(1)
         bst     ZH,CH_X0                ;(1)
         bld     encoder_state,3         ;(1)  copy port bits to current
X state
decode_X:
         ldi     ZH,high( X_actions)     ;(1)  load once, doesn't change.
         mov     ZL,encoder_state        ;(1)
         andi    ZL,15                   ;(1)
         subi    ZL,0xFF-low(X_actions)  ;(1)
         ijmp                            ;(2)  do an X action
X_actions:
         .db     low(X_idle), low(X_increment), low(X_decrement),
low(X_error)
         .db     low(X_decrement), low(X_idle), low(X_error),
low(X_increment)
         .db     low(X_increment), low(X_error), low(X_idle),
low(X_decrement)
         .db     low(X_error), low(X_decrement), low(X_increment),
low(X_idle)
X_error:    ; both inputs changed at same time, or encoder turning too fast.
         sbi     PORTD,ERR_X             ;(2) "X error" = 1
X_idle:     ; not moving
         reti                            ;(2)
X_increment:    ; counting up
         cbi     PORTD,ERR_X             ;(2) "X error" = 0
         subi    X_count_0,low(-1)       ;(1)
         sbci    X_count_1,byte2(-1)     ;(1)
         sbci    X_count_2,byte3(-1)     ;(1)
         reti                            ;(4)  longest path = (13)
X_decrement:    ; counting down
         subi    X_count_0,low(1)        ;(1)
         sbci    X_count_1,byte2(1)      ;(1)
         sbci    X_count_2,byte3(1)      ;(1)
         reti                            ;(4)
;                                  End of
decoder                               ;
;AVRASM: AVR macro assembler 2.1.43 (build 48 May 30 2011 10:07:37)
;Copyright (C) 1995-2011 ATMEL Corporation
;D:\videos\quadrature_encoder_1_1.s(20): Including file
'D:\videos\m168Adef.inc'
;ATmega168A memory use summary [bytes]:
;Segment   Begin    End      Code   Data   Used    Size   Use%
;[.cseg] 0x000200 0x00023e     46     16     62   16384   0.4%
;[.dseg] 0x000100 0x000100      0      0      0    1024   0.0%
;[.eseg] 0x000000 0x000000      0      0      0     512   0.0%
;Assembly complete, 0 errors. 0 warnings
erikc
2012-03-27 by Don Kinzer
> group forbids attachments.
It got quite mangled, of course.  If you don't have a server where you can store files you can use a service like DropBox.  An account with a 2GB limit is free.
I converted your code to an avr-gcc compatible ISR.  As you surmised, it did grow in size and number of cycles.  If I counted correctly, the worst case is 70 cycles, not counting the cycles to get into the ISR.  It is also about twice the size of your original code.  You can see the code (untested) here:
http://dl.dropbox.com/u/43035239/decoder.S
Incidentally, unless I'm missing something, the code sequence below from your post doesn't do what you intend.  It looks like the code is supposed to load an offset from the table, selected by the combined previous state/next state, and then jump to that offset.  However, the LPM instruction to actually load from Flash is missing.  As it stands, the code will jump to a table entry and start executing but the table contains offsets, not instructions.
>andi    ZL,15
>ijmp
Don Kinzer
> So  I should write:
> lpm     ZL,Z                      ;<---
> ijmp
Yes, if you want to load the value from the table entry into ZL.  Also, I suspect that the instruction preceding the lpm should actually be
 subi    ZL,0-low(X_actions)
This subtracts the negative of the low byte of the X_actions address, effectively adding the low byte of the X_actions address.
I thought you said (or perhaps I inferred) that this code was working.  It doesn't seem that that is so.
Don Kinzer
>> andi    ZL,15
>> ijmp
> Don Kinzer
So  I should write:
andi    ZL,15
lpm     ZL,Z                      ;<---
ijmp
The intent is to do a case jump to one of the four action routines.
erikc
2012-03-28 by Don Kinzer
>This is the version that I am using in my DRO.
It would be a lot more convenient for those trying to help you if you would put the file on DropBox or some other server so that it can be accesses with the formatting preserved.
Don Kinzer
2012-03-28 by fireweaver
>> So  I should write:
>> lpm     ZL,Z                      ;<---
>> ijmp
> Don Kinzer
I screwed up and sent the wrong code.  This is the version that I am
using in my DRO.
What I sent you was an attempt to compress it even further.  My bad.
===begin code===
two      ;
as fast ;
; as
possible.        ;
; Selling
points:                                                               ;
precision.                                    ;
case.                    ;
;       3.  Small code
size.                                                    ;
encoder)                  ;
; Weak
points:        ;
use.                            ;
;.include        "m168Adef.inc"
project                                                 ;
ATmega168                                    ;
/----U----\                                   ;
;                             PC6 | 01   28 |
PC5                               ;
PC4                               ;
PC3                               ;
PC2                               ;
;                             PD3 | 05   24 |
PC1                               ;
;                             PD4 | 06   23 |
PC0                               ;
;                             VCC | 07   22 |
GND                               ;
;                             GND | 08   21 |
AREF                              ;
;                             PB6 | 09   20 |
AVCC                              ;
;                             PB7 | 10   19 |
PB5                               ;
;                             PD5 | 11   18 |
PB4                               ;
;                             PD6 | 12   17 |
PB3                               ;
PB2                               ;
;                             PB0 | 14   15 |
PB1                               ;
follows:                                           ;
.equ   Q_DEBUG  = PD7   ; Duty cycle informs on CPU usage out
; Reserved register
assignments.                                                ;
; Encoder
management                                                            ;
        .def    encoder_state    = R16
encoder)                                    ;
        .def    X_count_0        = r26   ; low byte
        .def    X_count_1        = r27
        .def    X_count_2        = r28   ; high byte
memory.                               ;
___        ;
\___/   ;
|___    ;
\___/   \   ;
codes       |   ;
;                                                        ? = Error, K =
Okay    ;
previous ;
four     ;
samples.           ;
encoder  ;
counting.                                           ;
; These actions
are:                                                            ;
register                              ;
register                       ;
nothing                               ;
time.     ;
the input ;
with.           ;
; A = old phase A, B = old phase
B                                              ;
; a = new phase A, b = new phase
B                                              ;
; Aa
Bb        ;
; 00 00
idle        ;
; 00 01
up        ;
; 00 10
down        ;
; 00 11
idle        ;
; 01 00
down        ;
; 01 01
error        ;
; 01 10
error        ;
; 01 11
up        ;
; 10 00
up        ;
; 10 01
error        ;
; 10 10
error        ;
; 10 11
down        ;
; 11 00
idle        ;
; 11 01
down        ;
; 11 10
up        ;
; 11 11
idle        ;
.cseg
.org    0x100
Quadrature_Decoder:
         lsl     encoder_state           ; 00000B0A -> 0000B0A0
         bst     ZH,0                    ; read A
         bld     encoder_state,0         ; 0000B0A0 -> 0000B0Aa
         bst     ZH,1                    ; read B
         bld     encoder_state,2         ; 0000B0Aa -> 0000BbAa
         andi    encoder_state,15        ; trim encoder state
decode_X:
         subi    ZL,-low(X_actions)      ;(1)
X_actions:
         rjmp    X_idle
         rjmp    X_increment
         rjmp    X_decrement
         rjmp    X_idle
         rjmp    X_decrement
         rjmp    X_error
         rjmp    X_error
         rjmp    X_increment
         rjmp    X_increment
         rjmp    X_error
         rjmp    X_error
         rjmp    X_decrement
         rjmp    X_idle
         rjmp    X_decrement
         rjmp    X_increment
         rjmp    X_idle
         reti                            ;(4)
         reti                            ;(4)
         reti                            ;(4)
===end code===
erikc
> Don Kinzer
http://dl.dropbox.com/u/69622804/quadrature_encoder_1_0.s is where you
will find it.
Thanks for the tio.
erikc
