Bricked ATTINY SMD
2012-11-20 by Dave McLaughlin
Hi all, I have inadvertently bricked an ATTINY13 after trying to set the fuses. I was trying to set the 4MHz speed with 64ms start up and also enabling the Debug Wire interface. Now I can't talk to the device at all. I have searched around and found some stuff on the high voltage programming but all the ideas seem to be to work with the DIP package and I have the SMD package on my board. Does anyone know how to get this to work with SMD or a suitable device I can purchase that might plug over the top of the IC and allow it to be programmed? I can isolate all the IO pins to do this. Unsoldering it is not an option unless I am stuck with replacing it. Cheers Dave. PS.. Can I actually programme the fuses on this device to get debug-wire to work? [Non-text portions of this message have been removed]
