How to set interrupt mask whilst single stepping
2013-02-06 by Dave McLaughlin
Hi all, I have had to switch back to Studio 4 until Atmel sort out the bug with JTAG ICE2 and Studio 6 Since doing so, I can't find the option to set interrupt mask during single stepping so every time I single step my code, I end up in one of the 2 interrupt handlers! Make debugging a nightmare. I don't recall this being an issue before but I can't find any setting to sort this out. Appreciate any pointers. Dave. [Non-text portions of this message have been removed]
2013-02-06 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, "Dave McLaughlin" wrote: > I can't find the option to set interrupt mask during single > stepping [...] Choose a view that shows the registers including SREG. Click on the I bit in the SREG display and it will toggle. Then, you can single step without vectoring to an ISR. Don Kinzer ZBasic Microcontrollers http://www.zbasic.net
2013-02-06 by John Samperi
At 12:49 AM 7/02/2013, you wrote: >Since doing so, I can't find the option to set interrupt mask during single >stepping so every time I single step my code, I end up in one of the 2 >interrupt handlers! Make debugging a nightmare. You can stop the stop timers from running on break, is this what you want? Regards John Samperi ******************************************************** Ampertronics Pty. Ltd. 11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA Tel. (02) 9674-6495 Website http://www.ampertronics.com.au *Electronic Design * Custom Products * Contract Assembly ********************************************************
2013-02-06 by Jim Wagner
Go to the view of the peripheral registers and clear the interrupt enable bits of the timers or other devices that are making things hard. Or, go to the Status Register and clear the global interrupt enable bit. Jim Wagner Oregon Research Electronics
----- Original Message ----- From: "John Samperi" <samperi@ampertronics.com.au> To: AVR-Chat@yahoogroups.com Sent: Wednesday, February 6, 2013 11:12:57 AM Subject: Re: [AVR-Chat] How to set interrupt mask whilst single stepping At 12:49 AM 7/02/2013, you wrote: >Since doing so, I can't find the option to set interrupt mask during single >stepping so every time I single step my code, I end up in one of the 2 >interrupt handlers! Make debugging a nightmare. You can stop the stop timers from running on break, is this what you want? Regards John Samperi ******************************************************** Ampertronics Pty. Ltd. 11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA Tel. (02) 9674-6495 Website http://www.ampertronics.com.au *Electronic Design * Custom Products * Contract Assembly ******************************************************** [Non-text portions of this message have been removed]
2013-02-07 by Dave McLaughlin
Thanks John and all, It's not just the timer interrupt, I also have CAN bus interrupts running. The timers halted option is set anyway. I don't recall ever having to disable interrupts before. Doing a search I come across a few references to an option to mask interrupts during single stepping but can't find this in Studio 4 Dave.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of John Samperi Sent: 07 February 2013 02:13 To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] How to set interrupt mask whilst single stepping At 12:49 AM 7/02/2013, you wrote: >Since doing so, I can't find the option to set interrupt mask during single >stepping so every time I single step my code, I end up in one of the 2 >interrupt handlers! Make debugging a nightmare. You can stop the stop timers from running on break, is this what you want? Regards John Samperi [Non-text portions of this message have been removed]
2013-02-07 by Jim Wagner
I believe that the ONLY way to mask interrupts while single-stepping is to clear the IE flag bit in the Status Register. Jim Wagner On Feb 6, 2013, at 6:54 PM, Dave McLaughlin wrote: > Thanks John and all, > > It's not just the timer interrupt, I also have CAN bus interrupts running. > The timers halted option is set anyway. > > I don't recall ever having to disable interrupts before. > > Doing a search I come across a few references to an option to mask > interrupts during single stepping but can't find this in Studio 4 > > Dave. > > From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf > Of John Samperi > Sent: 07 February 2013 02:13 > To: AVR-Chat@yahoogroups.com > Subject: Re: [AVR-Chat] How to set interrupt mask whilst single stepping > > At 12:49 AM 7/02/2013, you wrote: > >Since doing so, I can't find the option to set interrupt mask during single > >stepping so every time I single step my code, I end up in one of the 2 > >interrupt handlers! Make debugging a nightmare. > > You can stop the stop timers from running on break, is this what you want? > > Regards > > John Samperi > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed]
2013-02-25 by David V
S6 has an option to "hide" the interrupts from you, but it doesn't seem to work very well yet. You can turn off specific ints in S4 while stepping, just clear the appropriate enable bits. You can also just disable all.
I will frequently use a debug equate for this.
.equ debug = true ;
.... Init code happens... then just before main where I would SEI.
.if debug
; leave ints off for debug!
.else
sei
.endif
