AVR-Chat
Re: Saving PRR in assembler
2013-02-27 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, Philippe Habib <phabib@...> wrote:
> The mov instruction only seems to like "real" registers
> and the command mov r17,PRR does not work.
The PRR register is in the I/O space.  If the address is 0x31 or less, you can use the IN and OUT instructions; otherwise, you must use LDS and STS to read/write the register.  It is useful to use one of the macros that yields IN/OUT or LDS/STS depending on the port referenced - especially so if you're writing code to run on several different devices where a particular register is in the IN/OUT range on some devices but not so on others.
Often, it is instructive to write some C code for some particular functionality and then examine the code the compiler generates.  How one does that depends on which C compiler is being used.
Don Kinzer
ZBasic Microcontrollers
http://www.zbasic.net
>PRR is at 0x64 according to the datasheet.
I should have mentioned that the LDS/STS method will work for any I/O address - those are 4-byte instructions.  In contrast, IN/OUT instructions are 2-byte so that's the motivation for using IN/OUT when possible.
You should be able to find a number of AVR assembly language tutorials in the Internet.
Don Kinzer
2013-02-27 by Philippe Habib
I've got some free time so I'm playing with the assembler.  I want to write an assembly function that will read the ADC and return the value.
The first thing I want to do is save the contents of the PRR so that I can restore it to where it was on exit.
The mov instruction only seems to like "real" registers and the command mov r17,PRR does not work.  I haven't found the right way to do this.  Can anyone offer a suggestion?
Thanks.
Re: [AVR-Chat] Re: Saving PRR in assembler
Thank you.  That's good to know about the address range.  PRR is at 0x64 according to the datasheet.
To: AVR-Chat@yahoogroups.com
Sent: Wednesday, February 27, 2013 3:48:11 PM
Subject: [AVR-Chat] Re: Saving PRR in assembler
Don Kinzer
Yahoo! Groups Links
