RE: [AVR-Chat] Where has everyone gone?
2014-05-02 by Mike Bronosky
I use Ubuntu, a distro of Linux, almost exclusively. The last I looked at AS it wasn't available for Linux.
Mike
2014-05-02 by Jim Wagner
Mike
2014-05-02 by Cat C
2014-05-03 by Dave McLaughlin
I concur, it still needs work.
Try creating and empty project and drop in all the libraries you need. At this point a proper compiler will build without any errors, at least those that don't need any special defines for some libraries. Codevision for example will compile without errors for any Code wizard builds.
But Coocox fails with lots of errors in the code itself. It takes a fair bit of work to get it going.
Dave…
Very funny Scotty, now beam down my clothes…
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of Cat C
Sent: 03 May 2014 02:54
To: AVR-Chat@yahoogroups.com
Subject: Free IDE for any micro-Controller family (was: [AVR-Chat] Where has everyone gone?)
I've used CooCox a little and I can't say it's bad but it has "holes" in coverage and porting samples is a PITA.
Some versions seem to work and other break things.
Cat
2014-05-03 by Steve Boak
2014-05-03 by Martin McKee
Dave…
I've used CooCox a little and I can't say it9;s bad but it has "holes" in coverage and porting samples is a PITA.Cat
2014-05-03 by Cat C
2014-05-03 by larryvc@hotmail.com
LPCXpresso Pro is only US $495.00 for a single user license, not the thousands that you mention. We have done some very large projects here and have yet to need the Pro version.
@JS, I am still alive and well. Super busy these days.
2014-05-03 by John Samperi
At 04:42 AM 4/05/2014, you wrote: >@JS, I am still alive and well. Super busy these days. I'm glad on all accounts. :-) Regards John Samperi ******************************************************** Ampertronics Pty. Ltd. 11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA Tel. (02) 9674-6495 Website http://www.ampertronics.com.au *Electronic Design * Custom Products * Contract Assembly ********************************************************
2014-05-04 by Philippe Habib
I'm using 6.2 and I can vouch for the slowness of it. Booting is slow and responsiveness is bad enough that I've repeated commands thinking they got lost. I haven't figured out how to get DS 6 to have libraries outside of the project the way I did with IAR. Having libraries in the project and having to update multiple projects sort of runs against what libraries are supposed to do for you. I've also used a couple of the free Eclipse based IDEs for TI, Silabs, and ST Micro. They're not as slow as Dev Studio 6, but I'm still getting used to them as far as commands and usage.
----- Original Message ----- From: "Jim Wagner" <wagnejam99@comcast.net> To: AVR-Chat@yahoogroups.com Sent: Friday, May 2, 2014 11:47:40 AM Subject: Re: [AVR-Chat] Where has everyone gone? Correct, and I have been told that it will not work on wine. However, there are versions of the up to date toolchain (command line) that have been prepared for several flavors of linux by Bingo600. He has been doing an excellent job of keeping that current. See: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=42631 While the topic appears old, it has been updated many times. Jim Wagner Oregon Research Electronics On May 2, 2014, at 11:34 AM, Mike Bronosky wrote: I use Ubuntu, a distro of Linux, almost exclusively. The last I looked at AS it wasn't available for Linux. Mike
2014-05-04 by Martin McKee
John Samperi
Tel. (02) 9674-6495
2014-05-04 by Jim Wagner
I would certainly agree that "limited" versions are useless. However, given that very likely half of all LPC series products come in well under the 256k debug limit, I feel it is perfectly reasonable to consider. I guess I would think of the free version of LPCXpresso as "constrained," not "limited."And, it's not the same, of course. But it is a debug/emulation limit. It will happily compile projects of any size. It's then up to the user to get it into the product though. And you'd better hope it works. But, it might still allow for fewer Pro seats needed.
Martin Jay McKeeOn Sat, May 3, 2014 at 12:42 PM, <larryvc@hotmail.com> wrote:
2014-05-04 by tim gilbert
-- Tim Gilbert JEM Innovation Inc. 303-926-9053 (office) 303-437-4342 (cell) www.jeminnovation.com www.pdksolutions.com
To dredge up an old-horse, of sorts, any recommendations for free IDE for 8051 family? Or, even a compiler and programming mechanism that works?
Thanks
Jim WagnerOregon Research Electronics
Martin Jay McKee
Everyone,
When will the chip manufacturers realize that they're selling chips and not software?
Having worked for a major semiconductor house, I can tell you that the cost of spinning a new chip completely dwarfs the cost of developing a complete IDE from scratch!
The first micro manufacturer that decides to "give away the razor and sell them the blades" will crush everyone else!
Tim
Thanks
Martin Jay McKee
Atmel has done that, and so far, they are not crushing anyone.
On May 3, 2014, at 7:36 PM, tim gilbert wrote:
Everyone,
Tim
Thanks
Martin Jay McKee
2014-05-04 by Pradumn Joshi
Hello Jim,
I used MCU 8051 IDE earlier although my experience with 8051 was limited and have no idea with new developments in core(integration of RF and other modern peheriperals and higher clock frequencies last I heard).
MCU 8051 IDE
Windows version is available since v1.3.5, April 2010. Versions prior to 1.4.2 requires that the ActiveTcl is installed on the system, otherwise th...
View on mcu8051ide.sourcef... Preview by Yahoo
Thanks
Jim Wagner
Oregon Research ElectronicsOn May 3, 2014, at 5:55 PM, Martin McKee wrote: > > >I would certainly agree that "limited" versions are useless. However, given that very likely half of all LPC series products come in well under the 256k debug limit, I feel it is perfectly reasonable to consider. I guess I would think of the free version of LPCXpresso as "constrained," not "limited." > >And, it's not the same, of course. But it is a debug/emulation limit. It will happily compile projects of any size. It's then up to the user to get it into the product though. And you'd better hope it works. But, it might still allow for fewer Pro seats needed. > > >Martin Jay McKee > > > > >On Sat, May 3, 2014 at 12:42 PM, <larryvc@hotmail.com> wrote: > > >> >> >> >>LPCXpresso Pro is only US $495.00 for a single user license, not the thousands that you mention. We have done some very large projects here and have yet to need the Pro version. >> >> >>@JS, I am still alive and well. Super busy these days. >> >> >> > > >
Hello Jim,; I used MCU 8051 IDE earlier although my experience with 8051 was limited and have no idea with new developments in core(integration of RF and other modern peheriperals and higher clock frequencies last I heard).MCU 8051 IDEWindows version is available since v1.3.5, April 2010. Versions prior to 1.4.2 requires that the ActiveTcl is installed on the system, otherwise th...Preview by YahooOn Sunday, May 4, 2014 6:35 AM, Jim Wagner <wagnejam99@comcast.net> wrote:
To dredge up an old-horse, of sorts, any recommendations for free IDE for 8051 family? Or, even a compiler and programming mechanism that works?ThanksJim WagnerOregon Research ElectronicsOn May 3, 2014, at 5:55 PM, Martin McKee wrote:I would certainly agree that "limited" versions are useless. However, given that very likely half of all LPC series products come in well under the 256k debug limit, I feel it is perfectly reasonable to consider. I guess I would think of the free version of LPCXpresso as "constrained," not "limited."And, it's not the same, of course. ; But it is a debug/emulation limit. It will happily compile projects of any size. It's then up to the user to get it into the product though. And you'd better hope it works. But, it might still allow for fewer Pro seats needed.
LPCXpresso Pro is only US $495.00 for a single user license, not the thousands that you mention. We have done some very large projects here and have yet to need the Pro version.@JS, I am still alive and well. Super busy these days.
