AVR-Chat
Re: [AVR-Chat] STK500 starter kit
2004-11-05 by David Jones
>>> dvanhorn@dvanhorn.org 05/11/2004 2:22:25 pm >>>
>Until you accidently "disable" the ISP mode which renders your chip
>next to useless unless you have a parallel programmer to fix it. For
>some reason people don't like to talk much about this major trap for
>young players.
>I wouldn't say that so much as it just dosen't happen that often.
That's beside the point. It can and does happen.
What happens if you have a soldered an AVR part on a board and lock up
the ISP mode? - bad news.
I know people who refuse to use SMD or solder DIP AVR parts into any
board, and I must say I'm one of them. Call me paranoid, but I'm not
going to design in a non-robust ISP system into one of my designs.
>Try a PIC sometime, IIRC if you lock the code, you can no longer
reprogram
>the part at all.
>On the AVR, you just erase the part and carry on.
PICs are the primary micro I use. You can't render a Flash PIC part
useless no matter what you program into it. There were a few exceptions
to this on specific parts, but they have long since been fixed with
silicon revisions.
>You do have to make sure that the programmer isn't running too fast
for the
>target system, especially when working with <1 MHz clocks.
Yet another silly AVR specific thing.
I can't believe the guys who designed the AVR ISP did it in this way,
it's completely non-robust. I can imagine the laughter if I tried to
propose such a system at a design review!
ISP modes on other micros like the PIC just work. No traps.
Dave :)
2004-11-05 by Dave VanHorn
Hmm.. Well, we have a system in production with three AVRs in it, and
haven't had any problems.
Fuse gotchas (was Re: STK500 starter kit)
2004-11-05 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "David Jones" <david.jones@s...>
wrote:
> ... ISP modes on other micros
Maybe the PIC, but not all micros. The ZiLOG Z8 Encore! has a far
worse gotcha than the AVR because the oscillator settings are
controlled by the first word of program memory, not by separately
accessed fuses. So, you can shoot yourself in the foot much more
easily, including just looking at program memory in the debugger and
trying to change what is stored by typing over values. It works, but
thereafter nothing else does.
I agree that this is an issue for beginners and more attention should
be brought to it.
Recall that I discovered that fuse gotchas are solved for AVRs with
the JTAG interface because this interface does not require the clock
to be running so you can repair any fuse misconfigurations.
The thread on the STK500 was really interesting. I was, of course,
looking for new product opportunities, but it seems that ISP is a
generally a solved problem.
Graham.
2004-11-05 by Joel Kolstad
lock up
any
not
That is paranoid, and for a company making real products, monetarily
wasteful.  I've never 'accidentally' disabled ISP on an AVR, and
I've used plenty of them.  I mean, how can you inadvertently disable
ISP other than (1) clicking on the configuration bit setting in a
programming application that you didn't need to or (2) perhaps
having signal integrity problems during programming?  In the first
case, that's clearly user error (and something that should be
learned long before a product ships) and in the second case it's a
bad design anyway and you're lucky if programming is the only thing
you have problems with.
There are plenty of commercial products out there that can
be 'killed' if 'things go wrong' during an upgrade -- the prime
example being PCs, where a power outage in the middle of re-flashing
the BIOS ROM can potentially leave it completely dead.
fast
> for the
Is the PIC programming interface completely asynchronous?  If not
surely there's some maximum clock rate on the data, right?
way,
I wouldn't argue that there isn't room for improvement,
but 'completely non-robust' is a patently false characterization.
---Joel
By the way, if you think AVR programming is 'non-robust,' I hope you
never end up using CPLDs or FPGAs where 'accidentally' sending a bad
bitstream can cause the part to _melt down and die_ (internally lots
of outputs all get shorted together).  We had a design where we
accidentally sent the bitstream from a different model board to the
FPGA ane it blew out the board's power supply (which was at least a
lot easier and cheaper to fix than swapping the BGA FPGA would have
been!).
---Joel Kolstad
Re: [AVR-Chat] Fuse gotchas (was Re: STK500 starter kit)
2004-11-05 by Ken Holt
While skimming and deleting this thread, I have just been debugging a
returned
board that does seem to have a fuse/lockup problem.  I cannot reach the
Tiny26
through the ISP (STK500 cable); but the Tiny continues to operate it's
pre-downloaded
program.  I assume that the serial enable fuse was accidently turned off
by someone,
and now there is nothing that can be done to load new code.
The Tiny is an smt, soldered in place, and even if I could get it off
cleanly, I don't
think there's any way to place it on the STK500.
Should I assume there's no way to move forward?
thanks,
Ken
>be brought to it.
>Graham.
>Yahoo! Groups Links
2004-11-06 by Ian Drennan
> be brought to it.
Greetings all
I have been following this thread with  interest as I am new to AVR and am
about 3 weeks into using my new STK500.
The 'fuse gotcha' issue seems to have got me today when I plugged in a new
Mega8 and changed an oscillator fuse so as to run using the STK500 onboard
clock. I set the fuse for external clock i.e.. Ext. Clock; StartupTime: 6CK
+ 64 ms;[CKSEL = 0000 SUT = 10]
Obviously this was a mistake as I am now locked out and assume the part is
now useless. Please can someone advise what the fuse setting should have
been to allow the mega8 to run using the STK500 onboard clock.
Many thanks
Ian
RE: [AVR-Chat] Fuse gotchas (was Re: STK500 starter kit)
2004-11-06 by Larry Barello
No AVR part is useless after programming the fuse bits.  You just have to
use the appropriate programming method - fortunately the STK500 supports
both ISP and Parallel programming.  For example, program the RESET line to
be an I/O pin on the tiny26 and you are REALLY HOSED, unless you use
parallel mode to "recover" your chip.  However, for the run of the mill: I
programmed an external clock...  You simply enable the external clock drive
on your STK500 - read the manual about those little jumpers near the back of
the board.
There are gotcha's with ISP: if your target board has an output driving the
MISO or SCK then it won't work.  I arrange my designs to have the ISP lines
brought directly out to the header and then insert 4.7k resisters between
the ISP pins and the rest of the circuit.  I just don't put any high-drive
elements on the other side of the resisters (e.g. LEDs)
Cheers!
Sent: Saturday, November 06, 2004 6:03 AM
To: AVR-Chat@yahoogroups.com
Subject: Re: [AVR-Chat] Fuse gotchas (was Re: STK500 starter kit)
> be brought to it.
Greetings all
Many thanks
Ian
Yahoo! Groups Links
2004-11-06 by Stefan Wimmer
debugging a
> returned
reach the
> Tiny26
it's
> pre-downloaded
turned off
> by someone,
off
> cleanly, I don't
I had a similar problem lately. What I did was: remove the 'faulty'
AVR (a Mega8 with accidentially disabled Reset line) using a smd
repair hot air gun, clean and reflux the board and solder on a new
one. Not a big story if you have the right tools at hand or know
someone who has (takes about 2 minutes that way). And not a big loss
to trash a ~$2 part - what do you pay for a Tiny26 that you are so
concerned about the thing?
Stefan
To: <AVR-Chat@yahoogroups.com>
Sent: Saturday, November 06, 2004 5:36 PM
Subject: RE: [AVR-Chat] Fuse gotchas (was Re: STK500 starter kit)
drive
of
> the board.
lines
> Cheers!
> From: Ian Drennan [mailto:ianid@sai.co.za]
> > be brought to it.
> Greetings all
6CK
> Many thanks
> Ian
Larry
Thanks for this reply.
Soon after sending my mail I realised that the I had the OSCSEL jumper miss
mounted. All is now ok
Ian
2004-11-06 by Ken Holt
Stefan -
Thanks for your advice - I have assumed that I will be just removing and
replacing the Tiny26, but I was starting to think what other theoretical
possibilities
there were.   For parallel programming, my old STK500 manual doesn't even
mention the Tiny26s, and I'd have to find an adaptor to actually plug it in.
I'm really more concerned about how to keep this lockup from happening
again,
as it seems to have at my client's shop.  I assumed that the SPIEN fuse
had been
disabled by faulty programming, but the spec says that fuse cannot be
changed by
serial mode, nor the RSTDISBL fuse.  My reset pin does still work, since
grounding
it restarts the program.  Also, the internal clock is still selected and
running, so the
device hasn't been accidently set to external clock.
The MOSI and MISO pins are used (during operation) as inputs from a
Cypress USB
chip, and I once thought that maybe those two signals might cause havoc
under the
right circumstance; however SCLK and Reset are both local only to the
ISP header.
I've pulled up MISO and MOSI and connected them only to the ISP header,
with still
no-talkie.
Ken
>debugging a
>>returned
>reach the
>>Tiny26
>it's
>>pre-downloaded
>turned off
>>by someone,
>off
>>cleanly, I don't
>Stefan
>Yahoo! Groups Links
The wiring for setting up the STK500 for parallel mode with a tiny26 can be
found in the help section of Astudio 4.x (not 3.x!) - you will have to dig
around a bit to find it.  It requires a custom 10 conductor cable.
What I do to recover chips that won't ISP program, is to get an SOIC test
clip, bring all wires out to a 20 pin wire-wrap dip and plug that into the
tiny26 socket of the STK500.  Then I can clip on, put the board into
parallel mode and recover the chip.
This isn't guaranteed to work depending upon what is connected to the
various pins of the tiny26.
Cheers!
P.S. I have never had a chip "lock up" in the field, but I have had batches
of chips from the factory with one or more CPUs with the wrong fuse
settings.  Out of four or five hundred CPUs maybe 3 or 4 like that.
What I *have* done, is forget to read/set the fuse settings and start
programming chips (after, say, programming some mega16's) and really messing
up the tiny26.  Once I blew through four or five boards before I figured out
what I was doing wrong :)
Sent: Saturday, November 06, 2004 2:28 PM
Stefan -
possibilities
again,
had been
changed by
grounding
running, so the
Cypress USB
under the
ISP header.
with still
no-talkie.
Ken
>debugging a
>>returned
>reach the
>>Tiny26
>it's
>>pre-downloaded
>turned off
>>by someone,
>off
>>cleanly, I don't
>Stefan
>Yahoo! Groups Links
Yahoo! Groups Links
2004-11-07 by Stefan Wimmer
> Stefan -
removing and
theoretical possibilities there were.
Ok, it is always good to understand WHY something went wrong.
In my case it was easy: it was a simple case of me setting the wrong
fuses (fingers klicking faster than brain could keep up...)  :-))
Stefan
2004-11-15 by Brian Dean
On Fri, Nov 05, 2004 at 02:43:54PM +1100, David Jones wrote:
> That's beside the point. It can and does happen.  What happens if
> you have a soldered an AVR part on a board and lock up the ISP mode?
> - bad news.
Are you sure it is the SPIEN fuse?  According to the datasheet you
cannot change the SPI enable fuse when actually using the ISP
interface.  I've tried to purposefully disable it using ISP
programming mode to no avail - it remains enabled.  I think one must
use JTAG or high voltage parallel programming to disable the SPIEN
fuse.
However, sometimes folks are guilty if changing the on-chip clock
source options which can leave the chip without a working clock.  For
example, can can set the fuse bits to select an external clock source
when there is none.  Not as deadly as clearing the SPIEN fuse as you
can generally feed in the needed clock and get back up and running.
It does sort've beg the question though - whey even have the option of
disabling the SPI programming interface?
-Brian
Brian Dean
BDMICRO - ATmega128 Based MAVRIC Controllers
http://www.bdmicro.com/
2004-11-15 by Kathy Quinlan
>>- bad news.
> fuse.
> -Brian
Added Security ? IE no chance of jumping into bootloader mode etc.
Kat.
K.A.Q. Electronics	Website: www.kaqelectronics.dyndns.org
IM: Yahoo: PinkyDwaggy  MSN: katinka@kaqelectronics.dyndns.org
For Everything Electronics     Phone: 0419 923 731
RE: [AVR-Chat] STK500 starter kit
2004-11-15 by Larry Barello
Security?
On Sun, Nov 14, 2004 at 08:49:41PM -0800, Larry Barello wrote:
> Security?
Maybe.  But isn't that what the lock bits are for?
-Brian
Disabling SPIEN (was Re: STK500 starter kit)
2004-11-15 by Graham Davies
--- In AVR-Chat@yahoogroups.com, Brian Dean <bsd@b...> wrote:
> ... whey even have the option of
I agree with Brian that the lock bits are the main security
mechanism. So, how about another guess ... maybe if you're using the
SPI pins for something else, you would worry that you'd accidentally
trigger SPI and mess up the chip. By disabling SPI, you make this
impossible and get to sleep better.
Graham.
