AVR-Chat
Re: [AVR-Chat] 8515 source in Australia (or NZ)
2005-06-16 by John Samperi
At 11:07 PM 16/06/2005, you wrote:
>Can you order from Digi-Key in the US?  ATMEGA8515-16AC is US $5.16 up to
>24, and $3.24 for 25 or more.  But I suppose the shipping costs could kill
>you.
I registered on Digikey's website yesterday. I send them an email
enquiring about shipping costs to OZ and see what happens.
I just ordered some chips from Future CA and got a shock to get
a US$107.90 delivery charge. I only paid US$30.00 last time in
August and US$60.00 from Arrow in the states. I send them a little
complain note but I will just have to wear it. X;{
There must be cheaper ways of getting the stuff here, not necessarily
3 days delivery but a week or 2 would be OK.
@Russell
Insight and Memec are the same company (Now belonging to Avnet).
I bought chips from them in March from the Sydney's office.
They don't keep the 8515 in stock so there will be a MOQ and
lots of waiting.
Also they bumped up their prices by more than 50% since March.
I bought M8 for $2.42 in tube qty now they want $3.80.
May try partners IC. I got a call from them a few days ago.
John Samperi
                         Ampertronics Pty. Ltd.
   11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
          Tel. (02) 9674-6495       Fax (02) 9674-8745
                Email: samperi@ampertronics.com.au
                  Website  http://www.ampertronics.com.au
* Electronic Design   * Custom Products   * Contract Assembly
2005-06-17 by Jeffrey Engel
John,
Mouser claims to have the mega8515's in stock and
shipping to OZ seems much more reasonable than the
others you've quoted.
$4.17 @ 25
$12.00 International mail (< 4lbs)
$36.00 FedEx INternational Priority (< 4 lbs)
8515 listing:
http://www.mouser.com/?Ne=500&handler=data.listcategory&Ntt=*8515*&terms=8515&crc=true&N=570&Ns=SField
shipping:
http://www.mouser.com/index.cfm?handler=estship&sl=0
Good Luck!
Jeff Engel
Arlington, TX
> >you.
> them an email
> happens.
> shock to get
> last time in
> them a little
> @Russell
> office.
> MOQ and
> lots of waiting.
> since March.
> $3.80.
> days ago.
> Regards
> John Samperi
> AUSTRALIA
> 9674-8745
>                   Website
> Assembly
Happiness is - positive intake manifold pressure.
Discover Yahoo!
Find restaurants, movies, travel and more fun for the weekend. Check it out!
http://discover.yahoo.com/weekend.html
2005-06-17 by John Samperi
Thanks Jeffrey. One more possible supplier. The $12.00
shipping cost is very attractive as I don't mind the
2-3 weeks lead time. But even the UPS charge is pretty
good.
John Samperi
2005-06-17 by Peter Gargano
> good.
Be wary of using UPS if that's an option they offer. Upon arrival UPS
may ring you up and say the duty is zero, the GST minimal, but there's
also a $52 customs clearance charge.
Use USPS (US Postal Service airmail) rather than UPS.
I've not had one pleasant dealing with UPS - ever!
Peter
Sleep and timer T0
2005-06-17 by Dave VanHorn
I must be missing something..
I have timer T0 running as a PWM generator with the AS0 bit in ASSR
set, and external 32kHz crystal.
Now I want to put the system to sleep, and have T0 wake me up once a
second for time keeping.
The problem is that once I go to sleep, the T0 int only happens ONCE!
It gets better though.. If I hang a breakpoint in the T0 ISR, and F10
through it, I get through the loop just fine, and I keep getting to
the T0 int. It's only when I let the code run without F10ing it, that
it fails to hit the T0OV isr.
Without the sleep, the T0 int fires once a second, and everything
acts like it should.
As I read the data sheet, T0 is supposed to be enabled to the
external crystal in ESB mode, so what's not right here?
At this point, I've decided to go to sleep:
So, I configure T0 for normal operation instead of PWM
	;Set timer 0 for once a second wakeups
	ldi		TEMP,128	;
	OUT		TCNT0,TEMP	;LOAD THE COUNT UP COUNTER
	ldi		TEMP,$06	;
	out		TCCR0,TEMP	;
I wait to make sure everything "took"
T0_Sleep_Update:
	in	TEMP,ASSR		;0000XXXX	Reserved
	andi	TEMP,$07		;XXXXX111	T0 async mode enable
					;00000---	Busy flags, 1 if register updating
	brne	T0_Sleep_Update	;
I clear off the T0 int flags:
	in	TEMP,TIFR		;
	andi	TEMP,$03		;Mask out non T0 bits
	out	TIFR,TEMP		;Turn off flags by writing 1's to them
I turn off the T2 overflow int that was doing my timekeeping while awake.
I turn on the T0 overflow int.
	in	TEMP,TIMSK	;
	andi	TEMP,$BF	;10111111 T2 overflow off
	ori	TEMP,$01	;00000001 T0 overflow on
	out	TIMSK,TEMP	;
I set the sleep mode
Snooz_Loop:
	;Set up the sleep mode
	in		TEMP,MCUCR			;
	ori		TEMP,$3C			; Extended Standby mode
	out		MCUCR,TEMP			;
Then I sleep:
	sleep						;
	in		TEMP,MCUCR			;
	andi		TEMP,$DF			; disable sleep
	out		MCUCR,TEMP			;
	;Wake up here on pressed button ints, or T0 overflow
	I do some checks here after I wake up and the T0 ISR exits,
	breq	Snooz_Loop			;If nothing going on, resume sleeping
If I was to get that far, then i would restore everything on the way
back to normal operation.
2005-06-17 by Astria Nur Irfansyah
I just arrived in Australia and i will be living here for quite a
while. Mm... is it really that hard to get an AVR here? Coz usually in
indonesia we can buy them online very easily from
http://www.digi-ware.com (indonesian store). It's very cheap, the
prices are in Indonesian Rupiah. I compared to Dontronics, and i think
dontronics is 3 times more expensive. I'm not sure how much would it
cost for delivery from indonesia, but for local delivery it would cost
less than 2 dollars. And the payment is usually by bank transfer (BCA
Bank)
Just FYI, an ATmega8515 costs Rp55000 which is 7.4 AUD (1 AUD = Rp7400)
I live in sydney now, can anyone tell me where to buy some electronic
components such as cheap capacitors, multimeters, soldering wire, etc?
Are there any electronic components shop around kensington? thankyou
-irfan-
> > good.
> Peter
>while.
WELCOME! =D>
It's not hard, but I am a cheapskate and try to get
them at the best price. Unfortunately when one orders
small qty one doesn't have much of a clout :'(
Seems to have good prices, a little hard to understand for me
as they don't seem to have an English version of the website.
Can you find out if they ship to Australia and how much for
shipping? Also it would be nice to be able to use a credit card.
There may be a Dick Smith store near you. The best prices are
from Altronics and Electus if you buy wholesale.
You can buy from their web sites also, or you can drive across the
other side of Sydney to Auburn for Altronics retail/wholesale and
Silverwater for Electus (Jaycar) retail/wholesale.
If you go to York St in the city (behind QVB building ) you will
also find a few stores next to each other.
John Samperi
Re: [AVR-Chat] Sleep and timer T0
2005-06-17 by Francisco Silva
Hi Dave,
2005/6/17, Dave VanHorn <dvanhorn@dvanhorn.org>:
In assynchronous mode you must wait for the registers update (up to 2
32kHz cycles). I use the following code on a atmega8.
inline static void PowerSave(void)
    MCUCR = (1 << SE)				// enable sleep mode
	|(0 << SM2) | (1 << SM1) | (1 << SM0);	// selects power save mode
    asm("sleep");
    MCUCR = 0;
#define WaitT2Upd() {while (ASSR & ((1 << TCR2UB) | (1 << OCR2UB) | (1
<< TCN2UB)));}
static u16 tcnt2_shadow;
// I maintain a shadow because its expensive to read TCNT2 in async mode
.... loop ....
	WaitT2Upd();
	PowerSave();
	// setup next wake as soon as possible
	tcnt2_shadow += 8 * 256;
	OCR2 = tcnt2_shadow;
.... loop ....
Francisco
2005-06-17 by Zack Widup
Speaking of Dick Smith Electronics, does he still have any stores in the
USA?  I think they were called American Electronics years ago.  I got his
catalogs in the mail back then but it's been some time since I've seen
one of them.
Zack
I thought the read of the ASSR register was supposed to return me
ones in the low three bits, if those updates were not yet complete.
It said that I could write all three at once, but then I had to loop
waiting for the three bits in the ASSR to zero, before proceeding.
It does int ONCE though, so obviously something's hosed.
The main point is that you MUST wait at least one timer clock cycle
before *re-entering* sleep mode. The easyest way to do this is
changing some register and waiting on ASSR.
Francisco
AHH!!
A careful third look at the data sheet turns up this nugget:
If Timer/Counter0 is used to wake the device up from Power-save or Extended
Standby mode, precautions must be taken if the user wants to re-enter
one of these
modes:
(and I do)
The interrupt logic needs one TOSC1 cycle to be reset. If the time between
wake-up and re-entering sleep mode is less than one TOSC1 cycle, the
interrupt will
not occur, and the device will fail to wake up.
(That's what's happening to me!)
If the user is in doubt whether the time before re-entering
Power-save or Extended Standby mode is sufficient, the
following algorithm can be used to ensure that one TOSC1 cycle has elapsed:
1. Write a value to TCCR0, TCNT0, or OCR0.
2. Wait until the corresponding Update Busy flag in ASSR returns to zero.
3. Enter Power-save or Extended Standby mode.
So, the sleeping loop looks like this now, and it works! :)
  (code above here shuts down the T2 int, and enables the T0 int, as
well as converting T0 from a PWM timer to a regular timer)
Snooz_Loop:
	in	TEMP,MCUCR			;
	ori	TEMP,$3C			;00111100
						;0XXXXXXX External SRAM enable
						;X0XXXXXX Wait state select bit
						;XX1XXXXX Sleep enable
						;XXX1XXXX SM1
						;XXXX1XXX SM0
						;XXXXX1XX SM2 Extended Standby mode
						;XXXXXX0X Int vector select
						;XXXXXXX0 Int vector change enable
	out	MCUCR,TEMP			;
	sleep					;
	out	OCR0,TEMP			;I don't care what gets written, but I need the write to
						;pace my re-entry to sleep. I write this as early as possible
						;so as to minimize wasted time waiting for the update to take.
	in	TEMP,MCUCR			;
	andi	TEMP,$DF			;11011111
						;XX0XXXXX Sleep enable
						;XXX1XXXX SM1
						;XXXX1XXX SM0
	out	MCUCR,TEMP			;
	;Test for pressed buttons
	clr	TEMP2			;
	sbic	PIND,3			;
	ldi	TEMP2,0x08		;Sets a 1 in this position if the button is NOT pressed
	in	TEMP,PINE		;					BBBBXXXX
	andi	TEMP,0xF0		;Mask out buttons			11110000 (If no buttons pushed)
	or	TEMP,TEMP2		;Add in the lone stranger			00001000
	ori	TEMP,0x07		;Fill in zeroes				11111111
	inc	TEMP			;					00000000
	and	TEMP,TEMP		;Check for zero
	brne	Wake_Up		;If no buttons, resume sleeping
T0_Snooz_Update:
	brne	T0_Snooz_Update	;
	rjmp	Snooz_Loop		;
Wake_Up:
	(down here, we re-activate the T2 int, and put T0 back to being a PWM timer)
2005-06-17 by Jim Wagner
Where do you tell it to sleep again? Has it really finished
everything needed for the next int before being put to
sleep?
Jim
On Fri, 17 Jun 2005 01:46:23 -0500
> bit in ASSR
> me up once a
> happens ONCE!
> ISR, and F10
> getting to
> F10ing it, that
> everything
> the
> second wakeups
> ldi
> TEMP,128      ;
> OUT
> UP COUNTER
> ldi
> TEMP,$06      ;
> out
> TCCR0,TEMP      ;
> T0_Sleep_Update:
> in
> TEMP,ASSR
> ;0000XXXX      Reserved
> andi
> TEMP,$07
> enable
> register updating
> brne
> T0_Sleep_Update      ;
> in
> TEMP,TIFR
> andi
> TEMP,$03
> out
> TIFR,TEMP
> 1's to them
> in
> TEMP,TIMSK      ;
> andi
> overflow off
> ori
> overflow on
> out
> TIMSK,TEMP      ;
> Snooz_Loop:
> in
> TEMP,MCUCR
> ori
> TEMP,$3C
> out
> MCUCR,TEMP
> Then I sleep:
> sleep
> in
> TEMP,MCUCR
> andi
> TEMP,$DF
>       ; disable sleep
> out
> MCUCR,TEMP
> breq
> Snooz_Loop
> resume sleeping
> on the way
> To visit your group on the web, go
> to:http://groups.yahoo.com/group/AVR-Chat/
> To unsubscribe from this group, send an email
> to:AVR-Chat-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms
> of Service.
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
>sleep?
We got it.
I missed the part where it says that you have to wait before going
back to sleep.
See previous message.
The trick is to write to any one of the registers, and then wait for
the update flag to clear, before going back to sleep.
