AVR-Chat
Re: [AVR-Chat] AVRISP Firmware Update Failed
2006-03-16 by Richard Reeves
David:
> When "AVR Prog..." likes what it sees on the end of the serial cable
> the problem is "address: 0x0000, Expected: 0xcf3f, Found: 0xffff"
I've got a couple on my desk like that, and a 5V DC PSU to power the
AVRISP with.  Seems a bit random if the upgrade works, so I gave up
and bought a batch of MKIIs as soon as I could.
The MKIIs seem more stable, although we have two on which the status
LEDs didn't work when connected to some computers.  Odd.
Richard
"Iz dana u dan ona dolazi i odlazi u talasima"
   http://www.van-gogh.co.yu/
2006-03-16 by David Kelly
I have a collection of 3 AVRISP's in various states of failure. All got
this way when AVR Studio asked to update the firmware and was allowed
to. Not sure if I've ever seen it succeed.
Yesterday one had 2.04 and AVR Studio wanted to put 2.07 in it. Failed.
Then the manual procedure failed many times as well.
Somehow it worked this morning. I can't figure out what I did "right"
that I can get the other 2 working again.
Have tried powering the AVRISP directly off 3.3 and 5.0 regulated power
so as to ensure none of the other ISP connector pins were wiggling.
Tried variations on when I short the two holes and when I release. If I
have the "AVR Prog..." window open and the Program button is grayed,
short the holes and a moment later the Program button is enabled. Have
tried programming with the holes shorted. No change. Altho that might be
how one of my AVRISPs got to its "totally trashed" condition.
Usually I can short the two holes on the AVRISP and the "AVR Prog..."
tool accepts what is connected and I can attempt to write new firmware.
But not at the moment. Relaunch of AVR Studio 4.12 build 468 doesn't seem
to help. Reboot of computer doesn't seem to help. WinXP.
When "AVR Prog..." likes what it sees on the end of the serial cable the
Sat at a different computer with a version 4.11 of AVR Studio and got
pretty much the same. Altho that computer will launch "AVR Prog..."
while my usual computer with the latest won't at the moment.
I see a 6 pin ISP header on the AVRISP. Presumably this will let me use
a good AVRISP to write code in a problem AVRISP?
What is it that I'm missing? Makes me long for good old Freescale and
P&E tools.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2006-03-16 by James Hatley
Hi David,
For me I have always found that the AVRISP needs a really solid 5 volts
supply when it is updated. I have found that the best way for me was to
connect it to an STK500. It always programs fine. Last I did was 4.12 ...
worked fine with the STK500.
Jim
To: <AVR-Chat@yahoogroups.com>
Sent: Thursday, March 16, 2006 1:19 PM
Subject: [AVR-Chat] AVRISP Firmware Update Failed
> P&E tools.
