AVR-Chat
AVRISP Mk2 problem
AVRISP Mk2 problem
2006-03-24 by Les Grant
Hi everyone,
I have an AVRISP Mk2 here. I can read and write fuses, I can read the
chip ID (mega32) but I can't read or write the flash. I have tried it
running from a powered USB hub and the USB port on the front of the
PC. Has anyone had any similar experiences? Any clues please?
Les Grant.
Les Grant. VK2KYJ.      Phone: 02 9896 7150 Fax: 02 9896 7153
Grantronics Pty Ltd     Int'l: +612 9896 7150, +612 9896 7153
ABN 46 070 123 643
PO Box 275, Wentworthville. NSW. 2145. Australia.
http://www.grantronics.com.au  mailto:info@grantronics.com.au
Microcontroller Hardware and Software development:
Atmel AVR - C, ASM, Digital and analogue
o ImageCraft AVR, TI, Motorola and ARM Windows-hosted C compilers
o ELNEC Device Programmers (E)EPROMs, Flash, Micros, PLDs
o CAN-BUS Hardware and Software from LAWICEL
o Logical Systems Programming, Prototyping & Production Adaptors
o Cleverscope USB oscilloscopes
Re: [AVR-Chat] AVRISP Mk2 problem
2006-03-24 by James Hatley
Hello,
Have you set the programming frequency correctly? Should be 1/4 or less of
your m32 processor frequency.
Jim
To: <AVR-Chat@yahoogroups.com>
Sent: Thursday, March 23, 2006 5:52 PM
Subject: [AVR-Chat] AVRISP Mk2 problem
> Hi everyone,
> Regards,
> Les Grant.
> ABN 46 070 123 643
2006-03-24 by Ivan Vernot
Hi Les,
A couple of thing to try
 - Check hat the ISP freq is < 1/4 Xtal freq (Under 'Board' Tab the ISP freq
combo box)\
 - in the 'advanced' tab try to read the signature bytes (does not solve
anything but interesting..
- Try to manual erase the device (in 'Program' tab)  before trying to
program flash (this resets the fuses as well)
An the some 'simple' ones (Ok, sorry to insult you ;-) ) but ...
- in the 'Program' tab - check that the 'Programming mode' settings are
    - 'Erase Device before programming' checkbox set
    - 'ISP' checkbox set
HTH
Ivan
Sent: Friday, March 24, 2006 12:52 PM
> Hi everyone,
> Regards,
> Les Grant.
> ABN 46 070 123 643
Hi Ivan,
I just fumbled my way to full functionality. Apparently, I had to
read and write the ISP clock frequency before reading or writing
flash or EEPROM even though everything else worked...
Thanks for the quick response. You were an excellent 'sounding
board'. :-)
Les.
On 24 Mar 2006 at 13:32, Ivan Vernot wrote:
> Hi Les,
>  ISP freq
> combo box)\
It says the attainable frequency is 1.049kHz (yes, kHz). The board
has a 14.7456MHz crystal and the oscillator is enabled and running.
>  solve anything but interesting..
This works. "Signature matches selected device"
It erased ok.
> are
You will have to do better than that before I will consider myself
insulted! :-)
Les.
> From: "Les Grant" <LesGrant@grantronics.com.au>
> > Hi everyone,
> > the chip ID (mega32) but I can't read or write the flash. I have
> > tried it running from a powered USB hub and the USB port on the
> > front of the PC. Has anyone had any similar experiences? Any clues
> > please?
> > Regards,
> > Les Grant.
> > ABN 46 070 123 643
> > o ImageCraft AVR, TI, Motorola and ARM Windows-hosted C compilers o
> > ELNEC Device Programmers (E)EPROMs, Flash, Micros, PLDs o CAN-BUS
> > Hardware and Software from LAWICEL o Logical Systems Programming,
> > Prototyping & Production Adaptors o Cleverscope USB oscilloscopes
> > Yahoo! Groups Links
ABN 46 070 123 643
