AVR-Chat
humidity sensor
humidity sensor
2006-03-30 by aila_alizadeh
hi everybody:
does anybody have information about humidity sensors with 2 pin ?
I just know that they act as a capacitor ,but I don't know how I
should measure it ,and how I should do that with avr .
whould you mind sharing your experience about that with me ?
If you send me any useful information about measuring & calibrating
these sensors and build a hygrometer ,I'll be very
thankful.
Aila Hasanalizadeh
Re: [AVR-Chat] humidity sensor
2006-03-30 by Ned Konz
On Mar 30, 2006, at 1:48 AM, aila_alizadeh wrote:
> hi everybody:
The best bet for measuring capacitive sensors is to use one of the
capacitance-to-analog or capacitance-to-digital converters that are
sold for that purpose.
QProx QT301
http://www.digikey.com/scripts/DkSearch/dksus.dll?
KeywordSearch&Stock=1&Keywords=qt301
AD Capacitance to digital converters
http://www.analog.com/en/subCat/0,2879,760%255F1077%255F0%255F%255F0%
255F,00.html
You can use other techniques (like for instance a CD4046 PLL) to
measure the capacitance, and then use a counter to measure the
resultant frequency.
Depending on the capacitance, you might also be able to do a really
simple converter that charges the cap through a resistor (fed from a
digital output pin) and then uses the analog comparator to detect
when a threshold voltage has been reached. The time that the cap
takes to charge to that level then gives you the capacitance.
I don't recommend using the schmitt trigger inputs for this, as their
threshold is not necessarily too stable or predictable.
If you added an analog switch you could compare the unknown
capacitance with a known reference; this helps cancel out
microcontroller-based errors.
Ned Konz
ned@bike-nomad.com
2006-03-30 by erikc
> hi everybody:
> thankful.
> Aila Hasanalizadeh
Go here:  http://www.linear.com/designtools/app_notes/index.jsp
Look for and download Application Notes AN3 and AN7.  Both appnotes
show a humidity sensing and signal conditioning circuit.
AN3 figure 8 shows a circuit which delivers an analogue voltage, while
AN7 figure 11 shows a circuit that delivers a variable frequency.
erikc
GILLETTE'S PRINCIPLE: "If you want to make people angry, lie. If
you want to make them absolutely livid with rage, tell the
truth."
Debug wire experiences
2006-03-30 by Don Ingram
Hi All,
Does anyone have any comments re experiences with debugwire on JTAGII.
I am specing a project at present which fits neatly with the Mega8 derivatives
but am reluctant to leave the well trodden path with the Mega16 / JTAG family.
I see very little history of conversation re debugwire and have little desire to
play pioneer ( the guy lying face down in the mud with the arrows in the back )
X-posted to chat & codevision.
Cheers
Don
Re: [AVR-Chat] Debug wire experiences
2006-03-31 by John Samperi
...and avrfreaks?? :-) many threads on JTAGICE 2 there.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2006-03-31 by Don Ingram
> Regards
> John Samperi
Lots on JTAGII in general, sod all on debugwire,
well, that I can find anyway ;-)
Don
Well I'd be happy to test it for you....just send me one :-D
I'm still debugging with the old ICE200 which does pretty much
all I need to do by enabling the compatibility bits in the
8515 and 8535 chips. For the M8 I can use the 4433 settings
if my project does not need the extra ram or I use an 8535
setting with an adaptor cable and use the pins I need off
the 8535.
Got a JTAG ice mk1(homemade) for the Mega64. You should be able
to use the older JTAG with a larger chip to emulate the M48 or M88
(no DW on the Mega8 that I know of) if you don't want to be a
guinea pig with debug wire. I guess there would be much more
noise on avrfreaks if it didn't work....I'll wait until I cannot
do without untill I purchase one...by then all bugs will be sorted out
(if any) :-)
John Samperi
2006-03-31 by Peter Gargano
Don, I'd be very happy to hear about what you discover (in case your
x-posts bear fruit).
Peter.
Re: humidity sensor
2006-03-31 by Joe
I have used a sht11. This will read temp and humidity and then u can
calc Dew point. Serial data out. There is code on the Bascom site.
See:
http://www.sensirion.com/en/02_sensors/00_products.htm?cat=3&art=1
JoeT
PS
excuse me if this is posted twice.
--- In AVR-Chat@yahoogroups.com, "aila_alizadeh" <aila_alizadeh@...>
wrote:
> hi everybody:
calibrating
> thankful.
> Aila Hasanalizadeh
RE: [AVR-Chat] Re: humidity sensor
2006-03-31 by Shoaib Javed
Yeah, this sensor is a good choice if cost is not an issue.
Shoaib
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Joe
Sent: 31 March 2006 07:13
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] Re: humidity sensor
See:
JoeT
PS
wrote:
> hi everybody:
calibrating
> thankful.
> Aila Hasanalizadeh
Yahoo! Groups Links
2006-03-31 by Ivan Vernot
HI Don,
I have used debug wire on a Tiny13.
It worked well enough (when I it worked) but I am a little disturbed that I
have been locked out of a few micros when things go wrong.
FWIW here is how it worked for me
-  need to connect to regular ISP lines.
- AVRStudio is told to go into debug wire mode
- AVRStudio enter as 'special' ISP mode to set the debug wire fuse bits
- Alls well and debug wire works just like JTAG (cool)!
BUT
Before you exit you debug setting (and AVRStudio) you must remember to clear
the debugwire fuse bit.
If you don't or AVRStudio crashes or AVRStudio reports that it could not set
the debug wire fuse bit (as was my case) then you can get locked out of the
micro and regular ISP no longer works nor does debug wire :-(
I don't want to appear too negative.as I have not had too much time to look
into this as yet (and it is possible that I screwed up something).
I have been successfully developing with debug wire for a couple of week
with no problems. Then, I need to (in a hurry) make a quick mod for a client
and in a flurry of activity I managed to lock myself out of three devices in
a row!!!!
I have not been able to investigate it further and it does concern me
but )(as I said)  I was a very happy camper 'till then.
I am 'hoping' that I did something stupid in my rush.
HTH.
BTW: IF I'm not mistaken the mega 16 and the mega8 pin compatible? So you
could use the mega16 in development (and use JTAG) and then when its all
done recompile for a mega 8.
Ivan Vernot
To: <AVR-Chat@yahoogroups.com>; <codevisionavr@yahoogroups.com>
Sent: Friday, March 31, 2006 10:06 AM
Subject: [AVR-Chat] Debug wire experiences
> Hi All,
> derivatives
> family.
> desire to
> back )
> Cheers
> Don
2006-04-01 by Don Ingram
Mega16 is 44 pin, Mega8/Mega168 is 32 pin.
Local disti has reported a number of companies routinely using debugwire, he
didn't mention the lockout issue although.
Given the need to have to use the SPI lines for programming anyway I am leaning
toward the well trodden JTAG solution. I would like to use a much smaller device
but feature creep has begun & Mega8 class is the minimum family so Mega16 is a
short hop away & cost is not an issue...
Cheers
Don
Ivan Vernot wrote:
> HI Don,
> BUT
> a row!!!!
> HTH.
> Cheers,
> Ivan Vernot
> From: "Don Ingram" <don@led.com.au>
>> Hi All,
>> derivatives
>> family.
>> desire to
>> back )
>> Cheers
>> Don
>> Yahoo! Groups Links
Cheers
Don Ingram
Leading Edge Design
Mob:   +61 4 1877 5670
Ph :   +61 7 4942 5670
SIP: 899 060 4942 5670
Fax:   +61 7 4942 5680
23 Daniel St
North Mackay
QLD 4740
Australia
P.O. Box 10326
Mt Pleasant
QLD 4740
Australia
2006-04-01 by John Samperi
M168 (?) and M8 are pin compatible. M16 is a 40 pin (44 smd) device :-)
I'm sure you know that, a slip of the fingers? :-)
John Samperi
Pin compatibility (was: Debug wire experiences)
2006-04-02 by Stefan Wimmer
...so are M48 and M88.
It's nice to be able to use a PCB for a whole series (M8, M48, M88,
M168) of processors.
Scroll down to the last entry on this page for an example:
http://www.raketenmodellbau.org/forum?
action=viewthread&page=3&threadid=5566
supported devices
2006-04-19 by naveed mughal
i m doing final project on avrora, my task is to extend avrora. first i have to know that what devices are supported by avrora-beta-1.6.0...
i'll be very thankfull if u help ...
thanks Naveed
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
Re: [AVR-Chat] supported devices
2006-04-19 by Ned Konz
> beta-1.6.0...
Didn't you believe the page on supported microcontrollers on the
Avrora web site?
I found it by searching for
	avrora supported devices
http://compilers.cs.ucla.edu/avrora/extend/mcu.html
where they say:
A microcontroller in Avrora is a self-contained execution unit with
program storage, RAM and internal devices that represents a complete
execution unit to be simulated. A microcontroller may be connected to
external devices such as LEDs, but these are not considered part of
the microcontroller. For example, the ATMega128L contains 128KB
Flash, 4KB EEPROM, 4KB SRAM, several timers, two UARTs, an SPI
interface, etc.
Avrora allows you to add your own microcontroller model, for Atmel
microcontrollers not yet supported or not yet build. By creating a
new Java class that implements the Microcontroller interface, you can
build a software model of the microcontroller in which your program
will run. You can add the correct parameters for storage size,
external pin assignments, and internal devices.
By specifying the -chip option to the simulator, you can select from
one of the supported microcontrollers, or specify the fully qualified
name of your own microcontroller class.
So the answers to your question are "the microcontrollers that are
supported are represented by classes that implement the
Microcontroller interface", and "you can make your own
Microcontroller class if you need or want to".
Just look at the source code; the JavaDoc is online.
http://compilers.cs.ucla.edu/avrora/api/current/avrora/sim/mcu/
Microcontroller.html
AtmelMicrocontroller.html
ATMegaFamily.html
ATMega128.html
ATMega16.html
ATMega32.html
After all, you're going to have to read the source in order to extend
Avrora, right?
Ned Konz
MetaMagix embedded consulting
MetaMagix@gmail.com
2006-04-20 by naveed mughal
hello dears,
my project is to extend avrora, that i have to convert it completely in gui, i want to convert it like other digital or electronic simulator, for example just like "tkgate" in linux, "electronic workbench" and circuit maker. i 'll be very thank ful if someone will guide me in right direction, that how should i start it, how it will be possible for me.....
Mughal
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2ยข/min or less.
AVRORA Errror how to solve it ...
dear i m new user of avrora. when i started to use it every thing was right. i used it on fedora core 5. but after some time, from some i m reciveng an error. i change my plateform ftom fedora 5 to fedora 4, java versions but problem is still there. so what is this, and how to solve it .... Error is following....
[naveed@localhost avrora]$ java -jar avrora.jar blink.od
Avrora [Beta 1.6.0] - (c) 2003-2005 UCLA Compilers Group
This simulator and analysis tool is provided with absolutely no warranty,
either expressed or implied. It is provided to you with the hope that it be
useful for evaluation of and experimentation with microcontroller and sensor
network programs. For more information about the license that this software is
provided to you under, specify the "license" option.
Loading blink.od...avrora.syntax.objdump.ParseException: Encountered "" at line 25, column 14.
Was expecting:
at avrora.syntax.objdump.ObjDumpParser.generateParseException (ObjDumpParser.java:1687)
at avrora.syntax.objdump.ObjDumpParser.jj_consume_token (ObjDumpParser.java:1562)
at avrora.syntax.objdump.ObjDumpParser.Raw2 (ObjDumpParser.java:297)
at avrora.syntax.objdump.ObjDumpParser.RawData (ObjDumpParser.java:285)
at avrora.syntax.objdump.ObjDumpParser.Item (ObjDumpParser.java:150)
at avrora.syntax.objdump.ObjDumpParser.Statement (ObjDumpParser.java:136)
at avrora.syntax.objdump.ObjDumpParser.Section (ObjDumpParser.java:125)
at avrora.syntax.objdump.ObjDumpParser.Module (ObjDumpParser.java:46)
at avrora.syntax.objdump.ObjDumpProgramReader.read (ObjDumpProgramReader.java:83)
at avrora.Defaults$AutoProgramReader.read (Defaults.java:452)
at avrora.Main.loadProgram (Main.java:359)
at avrora.core.LoadableProgram.load (LoadableProgram.java:88)
at avrora.sim.types.SingleSimulation.process (SingleSimulation.java:172)
at avrora.actions.SimulateAction.run (SimulateAction.java:79)
at avrora.Main.runAction (Main.java:144)
at avrora.Main.main (Main.java:132)
Mughal
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Re: [AVR-Chat] AVRORA Errror how to solve it ...
2006-04-20 by Jim Wagner
You are not likely to get much help with avrora here. I've
never seen anybody refer to it on this list. Of course, you
are welcome to ask, but please don't be upset if nobody
answers!
I have also never seen it referred to on the avrfreaks
list. There are a lot more folks there, however, so the
odds of finding someone might be a little better.
Jim
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
