AVR-Chat
AVR port pin verification help?
2006-11-21 by luthjej
Hi all,
   I'm new to this group, predominantly because I've always used PIC's
for control applications - but I've decided that it's time to give the
AVR a whirl; the feature list on the mega series AVR's is just too
good to pass up! :)
For my first design, I'm using a mega8 MCU for a closed loop
automotive control circuit, nothing terribly fancy, but I'm just
wondering about port allocations in terms of digital I/O's - I know
that on the older MCU's (PIC12Fxx, HC11 etc) there were significant
restrictions on what ports can be used for what function (i.e. PWM was
restricted to only a few pins, some ports were input or output only etc).
So, just before I go and get the PCB printed up, I was just hoping
that the knowledgable could cast their eye on my pin allocations that
I'm not doing anything impossible (or anything that's a particularly
bad idea! :).
I've read the data sheet cover to cover, and haven't come across
anything yet, although I'm still a bit vague as to which pins can
actually support PWM and whether different pins on different ports can
be allocated to different functions at the same time (e.g ADC Port -
can I do digital logic in, logic level out AND ADC conversion - all at
the same time?
PB0   - Out Piezo Buzzer Out (Direct Drive 20mA Max)
PB1,2 - Out PWM Drive 1,2 (to FET driver IC)
PD0,1 - In/Out RS232 Out via MAX232
PD2-7 - LCD Display Out
PB6   - Out SPI Device Slave Select
PB7   - In Keyboard (switches via 1N914's across PD2-7)
PC0   - 0-5v analogue in (for ADC use)
PC1-3 - +12v logic in (direct connect via 1k resistor)
PC4   - 0-5v analogue in (for ADC use)
PC5   - FET Drive (on/off) via FET Driver IC
MISO, SCK, MOSI - SPI Bus & ICP Header (Also LED via 500R resistor to
indicate SPI activity)
AREF,AVCC,VCC - Regulated +5v (no decoupling - direct connect)
Thanks in advance for your help.
Jon
Re: [AVR-Chat] AVR port pin verification help?
2006-11-22 by David VanHorn
> the same time?
You can allocate the pins as you see fit, within a port.
A single port can have inputs, outputs, ADC, PWM.. It's all in how you set
it up.
2006-11-22 by Jim Wagner
Hardware functions such as PWM are hard-coupled to specific
pins.  You can generate software PWM that uses any pin.
Likewise, UART, SPI, TWI, ISP, etc, are all hard-coupled to
specific pins. Again, you can implement any of  these
things in software on almost any pin. But, its REALLY hard
to use internal UART hardware with arbitrary Tx and Rx
pins.
Jim
On Tue, 21 Nov 2006 04:48:39 -0000
 "luthjej" <luthjej@yahoo.com.au> wrote:
> Hi all,
> always used PIC's
> time to give the
> just too
> good to pass up! :)
> loop
> I'm just
> I/O's - I know
> significant
> (i.e. PWM was
> output only etc).
> just hoping
> allocations that
> particularly
> bad idea! :).
> across
> pins can
> different ports can
> ADC Port -
> conversion - all at
> the same time?
> resistor to
> connect)
> Jon
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
I should add that all of the special function pins (in most
chips) also have a general purpose function. That is, they
are multiple use.
Jim
On Wed, 22 Nov 2006 00:15:14 -0500
> specific
> to
> hard
> pins.
> Jim
> > Hi all,
> > always used PIC's
> > time to give the
> is
> > just too
> > good to pass up! :)
> > loop
> > I'm just
> > I/O's - I know
> > significant
> function
> > (i.e. PWM was
> > output only etc).
> > just hoping
> > allocations that
> > particularly
> > bad idea! :).
> come
> > across
> which
> > pins can
> > different ports can
> (e.g
> > ADC Port -
> > conversion - all at
> > the same time?
> 500R
> > resistor to
> > connect)
> > Jon
2006-11-22 by Ned Konz
luthjej wrote:
> Hi all,
> good to pass up! :)
> bad idea! :).
> the same time?
Read the section starting at page 56 on I/O ports/Alternate Port
Functions. For a given internal peripheral you typically have a limited
set of choices; perhaps only one.
On the ADC ports, there is a discussion about combining ADC operation
and digital operation (in the ADC section, I think). These (and maybe
the analog comparator inputs?) are about the only case I can think of of
being able to use a pin in multiple modes; typically with the digital
functions the pins go through a multiplexer and you have to choose.
If you want to use the hardware PWM outputs this is a sensible choice
(PB1=OC1A, PB2=OC1B). But both will be running at the same frequency
because they share the same timer counter.
Right.
OK, as long as you don't need the analog comparator or external
interrupt pins.
So the AVR is a SPI master here?
Assuming Vref is 5V, that's OK.
Nope. You'd be driving too much current through the input protection
diodes. What's your VCC level? Why 1K? And if you mean "automotive 12V"
you VERY MUCH NEED input protection circuitry! Remember that you can see
voltages up to 60V here (if you have a loose battery cable, for
instance) and even negative voltages! There is much information
available on input signal conditioning for automotive voltages. Same
thing goes for your 12V-to-5V power supply; you can't expect to safely
connect just a 7805 and have everything survive!
OK
Right:
PB4/MISO
PB3/MOSI
PB5/SCK
If you want to use AVcc for AREF, you should do this internally and use
AREF for a decoupling cap. And you might want to connect AVCC to VCC via
an inductor/cap network.
> Jon
Ned Konz
ned@bike-nomad.com
http://bike-nomad.com
RE: [AVR-Chat] AVR port pin verification help?
2006-11-22 by larry barello
One nice thing about the AVR is that all I/O pins have identical digital
characteristics (pull-up, down, hysterisis, thresholds).  So from a general
I/O point of view there is no issue.  Peripherals can be switched in/out and
are attached to specific pins.  The best way to learn about them is as Ned
noted, below: Read the manual.
Analog pins are slightly different in that they have their own power supply
(AVCC) which has to be the same as VCC so there is really no difference
except that the filtering on the supply is recommended to keep the readings
clean.  I never do anything special for my AVCC line, relying upon proper
board layout & bypassing and generally I get excellent results.
Although you can do digital I/O on an analog line while doing an analog
conversion, it basically messes up the results due to the digital logic
current draw affecting the signal levels.  Clever code could put the digital
logic into a high-impedance input state before conversions.  Newer chips
have a bit in a register to physically disconnect the digital section from
the analog so that too could be manipulated to get on-the-fly digital and
analog out of one pin.
| -----Original Message-----
| From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
| Of Ned Konz
| Sent: Wednesday, November 22, 2006 12:11 PM
| To: AVR-Chat@yahoogroups.com
| Subject: Re: [AVR-Chat] AVR port pin verification help?
| luthjej wrote:
| > Hi all,
| > good to pass up! :)
| etc).
| > bad idea! :).
| > the same time?
| Right.
| interrupt pins.
| OK
| Right:
| PB4/MISO
| PB3/MOSI
| PB5/SCK
| > Jon
| > Yahoo! Groups Links
| Ned Konz
| ned@bike-nomad.com
| Yahoo! Groups Links
2006-11-22 by Ralph Hilton
On Wed, 22 Nov 2006 12:11:00 -0800 you wrote:
An  LCD usually takes 4 pins for data, RS, RW and EN so PD2-7 is one pin short.
I also wouldn't be happy with using PC5 as an output right next to PC4 as an ADC
input.
I would not use ADC4 or ADC5 as an ADC input if others are available as they give less
resolution than other channels.
Doubling up the LCD output and keyboard input seems complicated.
I think an ATmega16 would give a smoother ride.
I'm not experienced with automotive applications but do know that there are horrible
spikes flying around. Direct connection to input pins seems dangerous. I'd be thinking
about opto-coupling with reverse voltage protection diodes and zeners just to be safe.
When you are looking at where to get PCBs made up - I just got a package a few days
ago from www.ezpcb.com - 50 each of 10 boards all panelized into one order - $490
including shipping, gold immersion, ROHS compliant.
>luthjej wrote:
>> Hi all,
>> good to pass up! :)
>> bad idea! :).
>> the same time?
>Right.
>interrupt pins.
>OK
>Right:
>PB4/MISO
>PB3/MOSI
>PB5/SCK
>> Jon
>> Yahoo! Groups Links
>Ned Konz
>ned@bike-nomad.com
>Yahoo! Groups Links
Ralph Hilton
http://www.ralphhilton.org
C-Meter: http://www.cmeter.org
FZAOINT http://www.fzaoint.net
Re: AVR port pin verification help?
2006-11-24 by luthjej
Thank you all kindly for your suggestions, I've made a few changes to
the overall circuit layout:
1W 5.1v Zeners added to 12v digital inputs - I had considered doing
this earlier, but made the assumption - without calculation - that a
1K resistor "should" provide all the input protection I need, but
better safe than sorry!
max v=60
I = 60/5000 = 12mA
W = 60x0.012 = 720 mW dissapated by the Zener in a worst case scenario
I think the original calculation for the 1k was for a 5.0v VREF, when
you factor a spike of 60v into the equation that is clearly not
adequate - thanks for the pickup!
This circuit is particularly for a diesel application, and although
there would be some feedback floating around from the likes of starter
solenoids and inductive fans - at least there is no ignition feedback
to worry about!
Supply rails are already well protected via MOV, Polyfuse and
Zener/Diode arrays (I wouldn't trust a 7805 to do this job by itself
any farther than I could throw it! :)
ADC4 --> Moved to ADC2 for better resolution
AREF has been modified to use decoupling cap & internally source AVCC
for AREF
Now I just have to wrap my head around good PCB design rules :)
AVR UART ' UBRRH'?
2006-11-24 by praveen kumar
hello frens,
  In Atmegax Datasheet, there mentioned about selection b/w  UBRRH  n UCSRC , which share common mem address.
  If i try to set baud rate first by selecting UBRRH with URSEL bit 0,
  n after that set frame format in UCSRC with URSEL bit 1, it is not working.
  but, if set frame format first in UCSRC without bothering about URSEL,
  n then baud rate settings in UBRRH, its working fine!
  how it is possible?
  praveen
 Find out what India is talking about on  - Yahoo! Answers India
 Send FREE SMS to your friend's mobile from Yahoo! Messenger Version 8. Get it NOW
2006-11-24 by Celso Monteiro
Dear Jon,
Regarding protection levels at the inputs, I noticed you provided
protection in typical load dump levels, 60V for 12V systems.
Probably you're working in aftermarket application because OEMs
would not accept these levels.
Regarding input protection, maybe you could use the AVR internal
clamping diodes, keeping current levels controlled by appropriate
resistors. Remember that you need to have some sink for the currents
flowing thru the diodes so a shunt regulator could do the job, the
7805 regulator would allow voltage increase to - maybe - potential
damage levels.
Good luck,
Celso
to
a
> max v=60
> I = 60/5000 = 12mA
scenario
when
starter
feedback
> to worry about!
itself
AVCC
> for AREF
