AVR-Chat
A little help with SD cards . . . ?
2006-04-25 by kernels_nz
Hi guys,
Ive googled it to death, and read all the app notes and data sheets I
could get my hands on, but clearly I havent read them hard enough!
Just a few questions if anyone has used them succesfully please.
1. As i read and understand it, can I only use 512byte block sizes for
single block writing in SPI mode ? Do I then have to write as a
minimum 512bytes of info everytime I write to the card ?
2. Can anyone enlighten me as to how the physical sectors work ? How
many blocks per sector etc ? As I understand it, I need to supply a
start address for all write / read instructions, just wondering how I
know what address to give to make sure I start at the edges of blocks
and stay in the same sector.
If anyone has written any notes etc. that may be useful they would be
greatly appreciated.
Cheers
Hein B
Auckland, New Zealand.
Re: [AVR-Chat] A little help with SD cards . . . ?
2006-04-25 by Jesper Hansen
kernels_nz wrote:
> Hi guys,
You MUST write complete 512 byte blocks. When reading you can terminate
a read by raising CS, but when writing this is not possible. If you do
not fullfill a block write, no data will be written at all.
Forget all about physical sectors and just think of the card as a
collection of 512 byte blocks. If you start playing with different block
sizes (which only works on read anyway) you'll quickly end up confused.
Simply address the card by logical sector numbers, by simply shifting up
the sector number 9 bits and feed that address to the card.
/Jesper
Re: A little help with SD cards . . . ?
2006-04-26 by kernels_nz
Hi Jesper,
Thanks for that, it was as I understood it from the datasheets, just
wanted to double check with someone more familiar. Just one more
thing, am I then correct in assuming that Block1 is bytes 0 to 511,
block 2 is bytes 512 to 1023 etc. ? And the address I supply for write
instructions, I always then just change bits higher than the 9th bit
(512) ?
Cheers again
Hein
--- In AVR-Chat@yahoogroups.com, Jesper Hansen <jesperh@...> wrote:
> kernels_nz wrote:
> > Hi guys,
block
shifting up
> /Jesper
Re: [AVR-Chat] Re: A little help with SD cards . . . ?
2006-04-26 by Jesper Hansen
Yes.
> (512) ?
Yes. You should always adddress the card at sector/block boundaries.
ADC sample time
2006-04-26 by Peter Harrison
Hi
I have an optical sensor. It triggers an emitter and reads a response
from a photodiode and amplifier. after firing the emitter, I wait until
the amplifier has had time to reach a stable output - say 5us - then I
initiate an ADC conversion.
Now, If I turn off the emitter too soon, the ADC result is decreased so
my question is: How long should I keep the signal present at the ADC
input to allow the internal sample and hold capacitor to charge?
According to the (ATMEGA32) datasheet, the S/H capacitor has a value of
14pF but the series resistance of the multiplexer is shown as
1..100kOhm. This seems a bit of a large range. Time constants could be
up to 1.4us requiring that I wait as long as 7us or so to charge the
capacitor. The source impedance is an op-amp output so it should not
have any effect to speak of. The sheet also describes the sampling time
as negligible. Seems like a new, optimistic definition of the word to me.
My code seems to need to wait at least 1us before turning off the
emitter. As I need to perform 5k conversions per second, I could do
without wasting all that time in the timer interrupt waiting for the
signal to settle. I already have to arrange that on a timer tick, I
collect the previous result and then fire off another conversion.
Have I got it right and this is just how it works, or have I missed
something? Is the switch resistance really that variable?
Pete Harrison.
Re: [AVR-Chat] ADC sample time
2006-04-26 by Jim Wagner
My recollection is (without checking data sheet - BAD!) is
that the S/H switch is triggered about 1.5 ADC clocks after
the ADC starts. I would guess that this could play a
significant role in your problem. The data sheet also
inferred, if I remember (again, unchecked) that the S/H
switch was closed for one half an ADC clock. There is an
ADC timing diagram for many of the devices that show you
this basic operation.
Jim
On Wed, 26 Apr 2006 20:03:34 +0100
 Peter Harrison <peter.harrison@helicron.net> wrote:
> Hi
> reads a response
> 5us - then I
> is decreased so
> at the ADC
> charge?
> has a value of
> shown as
> constants could be
> charge the
> should not
> sampling time
> the word to me.
> off the
> I could do
> waiting for the
> timer tick, I
> conversion.
> have I missed
> Pete Harrison.
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
2006-04-27 by Ned Konz
On Apr 26, 2006, at 12:03 PM, Peter Harrison wrote:
> Hi
> until
> decreased so
> value of
> time
> to me.
The 7usec is not out of line, considering that the sample/hold is
sampling until 1.5 sample clocks after asserting ADSC (which is, at
best, 7.5usec given that 200KHz is the max clock for 10 bit
conversions).
Have you considered "free-running" mode?
Ned Konz
MetaMagix embedded consulting
MetaMagix@gmail.com
2006-04-27 by Peter Harrison
>> Hi
>> until
>> decreased so
>> value of
>> time
>> to me.
> conversions).
Ah... We have a thing at work where the act of asking the question seems
to help the brain formulate a solution. I had overlooked the 1.5 clocks
bit and now I have read the sheet again in the light of that I think I
can substantially improve things. For example, since I am likely to have
to wait 7us anyway for a sample and hold action (with a 200kHz ADC
clock) then I might as well trigger a conversion at the same time as the
emitter is fired. The sensor amplifier will have reached its output
level by the time the ADC does the sample anyway. The second delay seems
to be redundant. That will halve the time spent in the sensor interrupt.
(in the original post, I said I waited 1us for a sample when I should
have written 10us)
I could still do with knowing how long the sample takes though. If the
series resistor really is only 1k, I can motor on a bit more. Perhaps I
will have to do some tests and vary the delay to see the effect on the
response.
Not really appropriate I think. There are four channels, each must be
fired and read individually in sequence and a complete set must be done
every millisecond. That seems to require the triggered measurements.
Pete Harrison
2006-04-27 by David VanHorn
You could kick off the sequence from a timer, then go free-running, changing the channel on every aquisition till you're done with the sequence.
Re: [AVR-Chat] PalmIII LCD and touchscreen information.
2006-11-21 by Leon Heller
To: <AVR-Chat@yahoogroups.com>
Sent: Tuesday, November 21, 2006 10:43 AM
Subject: [AVR-Chat] PalmIII LCD and touchscreen information.
> Hi All,
> I was wondering if someone has some information about
> this PalmIII pilot LCD + touchscreen. I mean the connector
> pinout and how to control it.(datasheet)
> I want to control it with an ATMega128 but
It's probably RS-232 like my Palm IIIx.
Leon
2006-11-21 by Q boll
Hi All,
After looking for a few hours googlen I cann’t find any information.
Pascal
Nieuw: Live Mail. Mis het niet en profiteer direct van de voordelen!
http://imagine-windowslive.com/mail/launch/default.aspx?Locale=nl-nl
RE: [AVR-Chat] PalmIII LCD and touchscreen information.
2006-11-21 by Qboll
Hi Leon,
I don't mean the connector of the PalmIII itself but
the connector on the LCD INSIDE the PalmIII.
Pascal
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On
Behalf Of Leon Heller
Sent: dinsdag 21 november 2006 12:07
To: AVR-Chat@yahoogroups.com
Subject: Re: [AVR-Chat] PalmIII LCD and touchscreen information.
From: "Q boll" <msg_qboll@hotmail. <mailto:msg_qboll%40hotmail.com> com>
To: <AVR-Chat@yahoogroup <mailto:AVR-Chat%40yahoogroups.com> s.com>
> Hi All,
Leon
