AVR-Chat
interrupt emulation?
2007-01-04 by Thomas Keller
OK.   I am now running into problems with interrupts in emulation.
Can AVR Studio emulate interrupt driven programs (e.g., with timer
interrupts)?  Either ti cannot, or I am, doing something wrongelse wrong
in my interrupt setup.
   I did remember to set the interrupt enable masks, bot the timer
specific ones, and the global interrupt enable.
tom
RE: [AVR-Chat] interrupt emulation?
2007-01-04 by larry barello
You are most likely doing something wrong.  Internally generated interrupts
work for me.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Thomas Keller
tom
Re: [AVR-Chat] interrupt emulation?
2007-01-04 by David VanHorn
I'm voting for "B".  :)
You need GIE, or no ints will happen (Global interrupt enable... duh..)
Then you need the specific mask bits for the ints you want.
Then you need a populated jump table.
Then you need proper handlers.
In my belts-and-suspenders world, I start with a fully populated vector
table, and each ISR has code that disables that particular int.   Then on
the ones that I'm going to actually use, I write real handlers.   This keeps
any accidentally enabled ISR from chewing up the system.
At other times, I've sent all "unused" ints to "halt and catch fire" code,
so that they couldn't escape detection.  Sometimes it's better to crash
early and hard.
2007-01-04 by Roy E. Burrage
The only problem I've had with them is the A/D ISR.  When it gets there
you'll have to fake it out by manually entering some data.  Other than
this they work for me too.
Design notes 24 and 46 from AVRFreaks might help you with this.
REB
>work for me.
>-----Original Message-----
>Of Thomas Keller
>tom
2007-01-04 by Jim Wagner
Tom,
When you think you SHOULD get an int, but don't, stop
emulating and check the interrupt bits in the source
register and check the various control bits that determine
what happens to the int. Each interrupt source (timer, etc)
has a register with a bit that indicates the status of that
int.
Jim
On Thu, 04 Jan 2007 14:23:37 -0600
> in emulation.
> with timer
> wrongelse wrong
> the timer
> tom
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
There's another point where studio could improve.
At one point, when I was beta testing the ICE-50, they managed to "twist"
the two middle bits in the ADC result.   Let me tell you that was
interesting, since it was part of a servo loop.
I had to swap them back "manually", till they fixed it in later releases.
