AVR-Chat
*yikes*
*yikes*
2007-01-05 by Thomas Keller
I feel like such a dummy.    I have my program doing everything I want
and need it to do, with one exception (a major exception, to be sure).
I cannot get the timer interrupt to work.   if I step through the
program manually, it does what I need of it, but when I try to get the
timer to interrupt and step it through, it does nothing at qll (so far
as I can tell).
Which brings up a secondary question, as well:   when using the F5 "Run"
feature in the debugger, apparently the watch windows do not work, until
you hit an Ctrl-F and halt the run.  Once I get the interrupt thing
working, will that change?  Will the fact of the interrupt trigger an
update to the watch windows?  If not, how do I determine if the program
is doing what is supposed to be doing while running under the F5 feature?
tom
here is my code, as it stands so far:
> .include "tn25def.inc"
> ; Define here the variables
> .def  temp  =r16
> ; Define here Reset and interrupt vectors, if any
> RESET:
>    rjmp BEGIN
>    reti                                                     ; Addr $01
>    reti                                                      ; Addr $02
>    reti                                                      ; Addr $03
>    reti                                                      ; Addr $04
>    rjmp    TIMER0                                  ; timer/counter 0
> overflow interrupt
>    reti                                                      ; Addr
> $06        Use 'rjmp myVector'
>    reti                                                      ; Addr
> $07        to define a interrupt vector
>    reti                                                      ; Addr $08
>    reti                                                      ; Addr $09
>    reti                                                      ; Addr $0A
> compare match A interrupt
>    reti                                                      ; Addr
> $0C        Not all MCUs have the same
>    reti                                                      ; Addr
> $0D        number of interrupt vectors
>    reti                                                      ; Addr $0E
>    reti                                                      ; Addr $0F
>    reti                                                      ; Addr $10
> ; Program starts here after Reset
> START:
> ;    this table povides the data for the intensity curve needed for
> ;    xxxxxxxxxxxxxxx.  the data represent the value sin3 * 255 for
> ;    each angle from 0 through 90  at .9 degree increments
>     .eseg
> TABLE:
>     .db    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 2, 3, 3, 4, 5, 6, 6
>     .db    8, 9, 10, 11, 13, 14, 16, 18, 20, 22, 24, 26, 29, 31, 34, 36
>     .db    39, 44, 48, 52, 55, 59, 62, 66, 70, 74, 78, 82, 86, 90, 94, 99
>     .db    103, 108, 112, 117, 121, 126, 130, 135, 140, 144, 149, 153
>     .db    158, 163, 167, 172, 176, 180, 185, 189, 193, 197, 201, 205
>     .db    209, 212, 216, 219, 223, 226, 229, 232, 234, 237, 239, 242
>     .db    344, 346, 247, 249, 250, 252, 253, 254, 255, 255, 255
>      .cseg
> BEGIN:
>     ldi    r30,    RAMEND                        ; initialize stack
> pointer
>     out    SPL,    r30
>         ldi    r31,    0x00                                ; set up
> upper WGM bytes
>     out    WGM01,    r31                        ; and once again
>     ldi    r31,    0x03                                ; set upo to
> set waveform configuration
>     out    WGM00,    r31                        ; output to
> appropriate control register
>     ldi    r30,    0x04;                                ; enable
> timer/counter 0 compare match A interrupt
>     out    TIMSK,    r30                            ; store to
> timer/counter 0 Interrupt mask register
>     ldi    r30,    0x80                                ; enable
> gloabel interrupts in SREG
>     in    r29,    SREG                               ; grab current
> SREG value
>     or    r30,     r29                                  ; or in
> existing bits
>     out    SREG,    r30                             ; store in SREG
> register
> ;    set up timer delay for ~~.01 second
> ;    counter clock will be prescaled by 1024 to make the .01 second
> count easier
>     ldi    r21,    0x38                                ;  load low
> byte of delay count
>     ldi    r22,    0xff                                  ; load high
> byte value for delay count
>     out    TCNT1,    r2                            ; store in
> timer/counter register
>     ldi    r31,    0xe5                                ; load the
> control value for TCCR1
>                                                              ; CTC1
> set, PWMa set, COM1A set to
>                                                              ; toggle
> on match, timer clock set
>                                                              ; for
> system clock divided by 256
>     out    TCCR1,    r31                    `    ; store in register
>     ldi    r31,    0x75                                ; load value
> for TCCR1A
>     out    TCCR1,    r31                          ; and store to TCCR1A
>         ldi    r31,        0x38                            ; load
> compre output macth value
>     out    OCR1A,        r31                      ; store in output
> compare register 1A
>     ldi    r23,    0xff                                    ;   use r3
> as high/low byte flag for timer
> control (see interrupt handler for more)
> ;    this code sets the default initial table adress at 0
>     ldi    r16,    0x00                                ; first
> addresss in EEPROM table data
>     ldi r17,    0x00                                   ; direction
> control byte, 0 = up
>     rjmp    MAIN                                    ; go to the main
> loop in the code
> NEXT:
>     ldi    r31,    0x00                                ; compare value
>     cp    r17,    r31                                  ; check
> direction bit for value
>     breq    UP                                         ; it's set for
> an up count
> value
>     dec    r16                                           ; count the
> table pointer down one
>     cp    r16,    r31                                  ; at the bottom
> yet?
>     breq    CONT0                                 ; nope. continue
>     RJMP    QUIT0                                ; all done, depart
> UP:
>     ldi    r31,    0x63                                ; compare value
>     inc    r16                                            ; increment
> table pointer
>     cp    r16,     r31                                  ; 99 decimal,
> end of table
>     breq    FIXIT0                                    ; deal with
> table overflow
>     rjmp    QUIT0                                    ; all done, depart
> CONT0:
>     ldi    r17,    0x00                                ; set to count
> up again
>     rjmp    QUIT0
> FIXIT0:
>     ldi    r17,    0xff                                ; reset
> direction flag for down count
>             QUIT0:
>     ret                                                    ; return
> from subrouttine call
> ;    read a value from the EEPROM table
> TABLEDATA:
>     out    EEARL,     r16                        ; move table value
> address to EEPROM
>                                                             ; address
> register low byte
>     rcall    NEXT                                    ; go grab next
> tabel address                                sbi EECR,EERE
>     in    r18,        EEDR                            ; read data from
> EEPROM data register
>     out    OCR0A,    r18                           ; output to PWM
> control register
>     ret                                                        ; all
> done, go home
> TIMER0:
>     ldi    r31,    0xff
>     cp    r23,    r31                                    ; low byte or
> high/
>     breq    HIGHFIX                                 ; this is the low
> bytem go fix it for the high byte
> LOOP1:
>     ldi    r23,    0xff                                    ; reset for
> next low byte count
>     out    TCNT1,     r21                            ; reload the
> timer for the countdown, low byte
>     rcall    TABLEDATA                            ; go do the output
> needed
>     reti                                                        ; go
> to sleep until next timer interrupt
> HIGHFIX:
>     ldi    r23,    0x00                                    ; set flag
> to high byte indicator
>     out    TCNT1,    r22                              ; set the timer
> for the high byte countdown
>     rjmp    LOOP1                                      ; now go finish
> interrupt handler
> ;    this is the main control loop, an infinite loop
> MAIN:
>     rcall    TABLEDATA                            ; go do the first
> call to table data
> LOOP2:
> ;    rcall    TABLEDATA
>     sleep
>     rjmp    LOOP2                                    ; go back to
> sleep until next interrupt
>        ; in
> other words, loop forever
>     .exit
Re: [AVR-Chat] *yikes*
2007-01-05 by John Samperi
You have NOT enabled the general interrupts as far as I can
see with a SEI instruction. This sets the general interrupt
bit. You will also need to set to the timer interrupt, don't have
time right now to go through your code :(
You will need to put a breakpoint at the appropriate place in
the interrupt service routine so that the program stops and then
you will be able to see what's happening.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2007-01-05 by Jim Wagner
It just does not update while running. I use breakpoints
when you need to trap on something.
Jim
On Fri, 05 Jan 2007 14:32:03 -0600
> everything I want
> to be sure).
> through the
> try to get the
> at qll (so far
> as I can tell).
> using the F5 "Run"
> not work, until
> interrupt thing
> if the program
> the F5 feature?
> tom
> > .def  temp  =r16
> > RESET:
> >    rjmp BEGIN
> >    reti
> Addr $01
> >    reti
> Addr $02
> >    reti
> Addr $03
> >    reti
> Addr $04
> >    rjmp    TIMER0                                  ;
> timer/counter 0
> > overflow interrupt
> >    reti
> Addr
> >    reti
> Addr
> >    reti
> Addr $08
> >    reti
> Addr $09
> >    reti
> Addr $0A
> >    rjmp    TIMER0                                  ;
> timer/counter 0
> >    reti
> Addr
> >    reti
> Addr
> >    reti
> Addr $0E
> >    reti
> Addr $0F
> >    reti
> Addr $10
> > START:
> curve needed for
> sin3 * 255 for
> increments
> >     .eseg
> > TABLE:
> 3, 4, 5, 6, 6
> 26, 29, 31, 34, 36
> 82, 86, 90, 94, 99
> 144, 149, 153
> 197, 201, 205
> 237, 239, 242
> 255, 255
> >      .cseg
> > BEGIN:
> >     ldi    r30,    RAMEND                        ;
> initialize stack
> > pointer
> >     out    SPL,    r30
> >         ldi    r31,    0x00
>                                ; set up
> > upper WGM bytes
> once again
> >     ldi    r31,    0x03
>                                ; set upo to
> >     out    WGM00,    r31                        ;
> output to
> >     ldi    r30,    0x04;
>                                ; enable
> >     out    TIMSK,    r30                            ;
> store to
> >     ldi    r30,    0x80
>                                ; enable
> >     in    r29,    SREG                               ;
> grab current
> > SREG value
> >     or    r30,     r29
>                                  ; or in
> > existing bits
> >     out    SREG,    r30                             ;
> store in SREG
> > register
> the .01 second
> > count easier
> >     ldi    r21,    0x38
>                                ;  load low
> > byte of delay count
> >     ldi    r22,    0xff
>                                  ; load high
> >     out    TCNT1,    r2                            ;
> store in
> >     ldi    r31,    0xe5
>                                ; load the
>   ; CTC1
>   ; toggle
>   ; for
> >     out    TCCR1,    r31                    `    ;
> store in register
> >     ldi    r31,    0x75
>                                ; load value
> > for TCCR1A
> store to TCCR1A
> >         ldi    r31,        0x38
>                            ; load
> >     out    OCR1A,        r31                      ;
> store in output
> > compare register 1A
> >     ldi    r23,    0xff
>                                    ;   use r3
> 0
> >     ldi    r16,    0x00
>                                ; first
> >     ldi r17,    0x00
>                                   ; direction
> >     rjmp    MAIN                                    ;
> go to the main
> > loop in the code
> > NEXT:
> >     ldi    r31,    0x00
>                                ; compare value
> >     cp    r17,    r31
>                                  ; check
> >     breq    UP
>                                         ; it's set for
> > an up count
> >         ldi    r31,    0x00
>                                ; compare
> > value
> >     dec    r16
>                                           ; count the
> >     cp    r16,    r31
>                                  ; at the bottom
> > yet?
> >     breq    CONT0                                 ;
> nope. continue
> >     RJMP    QUIT0                                ; all
> done, depart
> > UP:
> >     ldi    r31,    0x63
>                                ; compare value
> >     inc    r16
>                                            ; increment
> > table pointer
> >     cp    r16,     r31
>                                  ; 99 decimal,
> > end of table
> >     breq    FIXIT0                                    ;
> deal with
> > table overflow
> >     rjmp    QUIT0                                    ;
> all done, depart
> > CONT0:
> >     ldi    r17,    0x00
>                                ; set to count
> > up again
> >     rjmp    QUIT0
> > FIXIT0:
> >     ldi    r17,    0xff
>                                ; reset
> >             QUIT0:
> >     ret
> return
> > TABLEDATA:
> table value
> > address to EEPROM
>  ; address
> > register low byte
> >     rcall    NEXT                                    ;
> go grab next
> > tabel address                                sbi
> EECR,EERE
> >     in    r18,        EEDR                            ;
> read data from
> >     out    OCR0A,    r18                           ;
> output to PWM
> > control register
> >     ret
> all
> > done, go home
> > TIMER0:
> >     ldi    r31,    0xff
> >     cp    r23,    r31
>                                    ; low byte or
> > high/
> >     breq    HIGHFIX                                 ;
> this is the low
> > LOOP1:
> >     ldi    r23,    0xff
>                                    ; reset for
> > next low byte count
> >     out    TCNT1,     r21                            ;
> reload the
> do the output
> > needed
> >     reti
> go
> > HIGHFIX:
> >     ldi    r23,    0x00
>                                    ; set flag
> >     out    TCNT1,    r22                              ;
> set the timer
> >     rjmp    LOOP1
>                                      ; now go finish
> > interrupt handler
> > MAIN:
> do the first
> > call to table data
> > LOOP2:
> > ;    rcall    TABLEDATA
> >     sleep
> >     rjmp    LOOP2                                    ;
> go back to
>      ; in
> >     .exit
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
2007-01-06 by Thomas Keller
John.
     I didn't use an sei instruction,no. I set the appropriate bit in a
register, read in the current SREG vale, or'ed it together,t hen used an
out instruction to store the result in the SREG.  While unconventional,
it SHOULD have the same net result.
2007-01-06 by Jim Wagner
Tom
The only bit that has anything to do with interrupts in the
SREG is Bit7:GlobalInterruptEnable.  Are you doing all that
to try to set and clear Bit7?
It would seem like it OUGHT to execute an ISR. Do you have
the  corresponding bits set in the timer? For a Mega16, its
the TIMSK (Timer Mask Register) and, after the timer event
happens, a bit is set in the TIFR (Timer Interrupt Flag
Register). This latter bit will be cleared when the ISR
executes.
Jim
On Fri, 05 Jan 2007 19:17:14 -0600
> John.
> unconventional,
> can
> interrupt
> don't have
Jim;
Yeah, I know it is a bit much, I had forgotten about the sei
instruction, which is something that hasn't existed on processors i have
worked with in the past.
Yes, I have the interrupts enabled (at least, if I understood the data
sheet on how to do that, I do), and yes (again, contingent upon my
correct understanding of the data sheet), I have the timer control bits
set for the performance I wish.  This is why I am so confuzzled.
tom
Jim Wagner wrote:
> Tom
> executes.
> J
Tom -
A technique I have used to debug timers is to temporarily
set up the timer so that the interrupt happens in a
relatively few clock cycles. This can be done by using the
minimum clock prescale, a small compare value, etc. Then, I
manually steep through the program and when it gets close
to the point where I expect the action, I view the
registers (to the left of the code window in Studio). Then
I watch exactly what happens. Usually, I find that
something fairly simple does not happen the way I expected.
Then, I read the docs to see what I overlooked.
Jim
On Sat, 06 Jan 2007 10:32:33 -0600
> Jim;
> sei
> processors i have
> understood the data
> contingent upon my
> timer control bits
> confuzzled.
> tom
> Jim Wagner wrote:
> > Tom
> the
> that
> have
> its
> event
> > executes.
> > J
