AVR-Chat
attiny12
attiny12
2007-02-25 by dpintod
Hello everibody:
Can somebody tell me if I can drive a solid state relay directly from
the tiny12 or I need a transistor.
David.
Re: [AVR-Chat] attiny12
2007-02-26 by John Samperi
The i/o pins can supposedly drive 20mA, how much current does the
solid state relay need to work?
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
RE: [AVR-Chat] attiny12
2007-02-26 by AVR Development
As far as I know you can drive that directly from your ATtiny.  You just
need like 5 mA or so to drive a solid state relay (SSR).  Basically, the
input to a solid state relay is an optoisolator so it looks just like an LED
to the processor.
Barry AKA JoeLlama
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of dpintod
Sent: Sunday, February 25, 2007 7:16 AM
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] attiny12
Hello everibody:
David.
Basically, you need to put a resistor inline with your port pin to limit
current to the LED input of the SSR (solid state relay).  You can get by
with 5 or 10 mA nicely :)  Gotta figure your voltage drop across the port
and also the LED in the SSR which is about 1.2 volts forward drop.  Then
calculate a resistor for the remaining voltage to limit to 5 or 10 mA.
Normally, I connect my LEDs to Vcc and sink to the port.
Barry AKA JoeLlama
Of John Samperi
Sent: Sunday, February 25, 2007 5:43 PM
Subject: Re: [AVR-Chat] attiny12
John Samperi
Email: john@ampertronics. <mailto:john%40ampertronics.com.au> com.au
Website http://www.ampertro <http://www.ampertronics.com.au> nics.com.au
2007-02-26 by dlc
Will the solid state relay take less than 20ma to turn it on?  If so,
then yes it will work, if not, no.
DLC
dpintod wrote:
> Hello everibody:
> Thanks,
> David.
Dennis Clark          TTT Enterprises
www.techtoystoday.com
Check the specs of your SSR (look up the datasheet on google if you need
to).  SSRs usually trigger with 5 or 10 mA (remember, you're just lighting
up an LED).
Barry AKA JoeLlama
Of dlc
Sent: Sunday, February 25, 2007 8:01 PM
DLC
dpintod wrote:
> Hello everibody:
> Thanks,
> David.
