AVR-Chat
i2c temperature sensor code
2007-04-11 by jasonparkerhendrix
Does anyone have example winavr code for working with temperature
sensors via i2c?
Specifically I'm working with a TMP75AIDR
(http://focus.ti.com/lit/ds/symlink/tmp75.pdf) and an ATMEGA32
(http://www.atmel.com/dyn/resources/prod_documents/doc2503.pdf)
However, any winavr code for any other i2c sensor and/or avr would be
very welcomed.
Thanks!
Re: [AVR-Chat] i2c temperature sensor code
2007-04-12 by Ranjit Puri
Heres some classic bit-banged I2C code (written for AVR GCC) that talks to a
DS1631 I2C temperature sensor (see attached).
Ranjit
On 11 Apr 2007 18:25:08 -0700, jasonparkerhendrix <hendrix.jason@gmail.com>
> sensors via i2c?
> very welcomed.
> Thanks!
Ranjit
2007-04-12 by Alex Gibson
Ranjit Puri wrote:
> Hi,
> Regards
> Ranjit
Can't send attachments to yahoo groups, they block it automatically.
Need to either paste it as text or upload it to the files area or put it
on your web site and include a link.
Alex
Re: i2c temperature sensor code
2007-04-12 by jeff_smith_8992
Peter Fleury has some example I2C code (I2C Master Interface)
available at his web site:
http://homepage.hispeed.ch/peterfleury/avr-software.html
--- In AVR-Chat@yahoogroups.com, "jasonparkerhendrix"
> sensors via i2c?
> very welcomed.
> Thanks!
Thanks Alex,
The files can also be had from
http://ranjit.puri.googlepages.com/I2C_AVR_sampleC.zip
Ranjit
On 12 Apr 2007 05:21:13 -0700, Alex Gibson <yahoo@alexthegeek.com> wrote:
>   Ranjit Puri wrote:
> > Hi,
> to a
> > Regards
> > Ranjit
> Alex
Ranjit
2007-04-13 by jasonparkerhendrix
Thanks for this code example!
For some reason, the temperature is reported to be 255 C.  Obviously
this means something isn't right.  Can you give me any hints to what
I may have done incorrectly?
The only thing I changed in the code was to this:
#define DEV_ADDR 0x37
Because according to the datasheet
(http://focus.ti.com/lit/ds/symlink/tmp75.pdf) the address if all 3
address pins are left "floating" is 0110111
Any suggestions would be greatly appreciated.
Thanks!
--- In AVR-Chat@yahoogroups.com, "Ranjit Puri" <ranjit.puri@...>
wrote:
> Thanks Alex,
> Regards
> Ranjit
> On 12 Apr 2007 05:21:13 -0700, Alex Gibson <yahoo@...> wrote:
> >   Ranjit Puri wrote:
> > > Hi,
that talks
> > to a
> > > Regards
> > > Ranjit
automatically.
put it
> > Alex
> Ranjit
Re: [AVR-Chat] Re: i2c temperature sensor code
2007-04-13 by Michael Ardai
The low bit of the address selects R/W.  That would make
0110 111x be 6E for write and 6F for read.  See figure
5 in the data sheet.
BTW, I can't remember if you are using a TMP75 or a
TMP175.  The TMP75 doesn't allow for floating addresses.
/mike
Thanks for your help.  You helped me realize exactly what the problem
was, and it's working great now.
Thanks!
> /mike
