Hi Dave,
Heres some bit banged TWI code for you.
http://ranjit.puri.googlepages.com/I2C_AVR_sampleC.zip
Ranjit
On 6/27/07, David VanHorn <microbrix@gmail.com> wrote:
> > For bit banged ASM stuff look at AVR300 and AVR302, I have used the
> > master and it works very well. Some people think that there may be
> > some merits on using the bit banged TWI as they suspect some hardware
> > issue with the hardware TWI. I have some more bits if you get stuck,
> > I have partially translated the C code for AVR315 (Master) into ASM but
> > it is not pretty yet.
> I'd prefer to use the TWI hardware. I need this fast, and I'm in a
> very limited environment, one master, and exactly four slaves.
> I already implemented a "broken comms" timer, so that it will restart
> if the comms hangs. Only a truly hung hardware (broken) would stop
> me.
Ranjit
