oops
2007-08-09 by Thomas Keller
OOps I forgot to include the code *doh*:
---- cut here ----
; begin file intialization
.include "tn25def.inc" ; include processor definition file
; define registers
.def TEMP = r16
; interrupt vector table
.org 0 ; set address for interrupt
vector table
RESET: rjmp START ; reset/restart vector
INT0a: reti ; external interrupt 0 vector
PCINT0a: reti ; pin change interrupt 0 vector
TIMER1_COMPA: reti ; timer1 comnpare match A vector
TIMER1_OVF: rjmp TIMER_HNDLR ; timer0 overflow flag A
vector
TIMER0_OVF: reti ; timer1 overflow flag A vector
EE_RDY: reti ; EEPROM ready flag vector
ANA_COMP: reti ; analog comparator vector
ADCa: reti ; analopg to digital conversion
complete vector
TIMER1_COMPB: reti ; timer1 compare output match B
vector
TIMER0_COMPA: reti ; timer0 compare output match A
vector
TIMER0_COMPB: reti ; timer0 compare output match B
vector
WDT: reti ; Wach Dog Timer vector
USI_START: reti ; USI start vvector
USI_OVF: reti ; USI overlfow vector
START:
; set up timer/counter1
ldi TEMP, 0x01 ; set for clock / 1
out TCCR1, TEMP ; save in appropriate register
ldi TEMP, 0x01 ; set for clk/1024 TMP /1
out GTCCR, TEMP ; store in appropriate register
ldi TEMP, 0x02 ; set time to 5 periods
out OCR1A, TEMP ; save in appropriate register
ldi TEMP, 0x44 ; set interrupts enabled
out TIMSK, TEMP ; store in approproiate
register
; set Stack Pointer to end of RAM
ldi TEMP, 0xdf ; load end of RAM
out SPL, TEMP ; and save to stack pointer
sei ; enable global interrupts
LOOP:
rjmp LOOP ; go into infinite loop waiting
for interrupts
rjmp LOOP ; go back to loop after
interrupt handling cmmpletes
; timer handler
TIMER_HNDLR:
inc r20 ; incremenrt count on
number of interrupts
reti ; return from interrupt
; end of code
