Using OD and Preamp simulator (for Eric Johnson tone)
2004-05-24 by stratoskier
Greetings, I think I already know the answer to this, but... On the Boss GP5 and the older SE-70 1/2 rack unit (precursor to the VF1), there were some Guitar Multi algorithms that included both OD/Distortion and a separate Amp Simulator. In other words, the OD/Distortion was a separate effect, rather then included within the Preamp Simulator as in the VF1. That allowed you to set up patches where you simulated overdriving the preamp with a particular pedal, just like we normally do when using a pedal before our guitar amp. Looks like this isn't possible with the VF1, other than maybe setting the "Gain" parameter to High within the AmpSim section. Right? The GP5 also had the option to set up a "Custom Preamp". I don't believe we can do that on the VF1 either. The reason I ask about this is that I'm trying to duplicate a GP5 Eric Johnson patch that I found on the web, and it specifies OD before a Custom preamp, etc. Anyone else have a good Eric Johnson patch for the VF1? Thanks, Bert
