Yes Phono, that same one. I thought it was ultimately going to make
the trick for me (as it was programmed specifically for the VZs),
but it doesn't seem to like my system's MIDI config. When I restart
the computer with the MidiExpress off so that I just get the few
MIDI I/Os from my two PC sound cards, then it starts up well, but
shortly after it presents an error message and shuts down. I fear
it's 16bit code and in several cases, run-time DLLs have functions
no longer compatible with newer OS, as you implied.
I tried yesterday Midi-OX and it didn't work either, although I
liked it the most among the handful progs I've tried so far. It
seems it is something with the way the VZ-10M accepts SysEx
commands, as I can do a memory dump to the PC apparently well. But
uploading a bank from the PC, that's a different story.
I can try to program something by myself using VC++ v6 so that any
kind of OS incompatibility is no longer a factor, but I was trying
to avoid it if possible as I'd have to study the VZ's SysEx
implementation and I guess be willing to do some trial and error.
I don't know, any other idea?
Gus.
--- In CZsynth@yahoogroups.com, "phonophobie" <sidstation@h...>
wrote:
> i was running into the same problems. it seems that all those vz-
tools
> are only running on win98... i am on xp now and it also doesn´t
work
> for me! For simple sysex dumps use "midiox". But when you want to
> transfer vz specific files (".vz1" or whatever they are called) you
> have to use win98. However what do you mena with the
program "VZPATCH"
> ? Is it that one from Easy VeeZee?
> --- In CZsynth@yahoogroups.com, "gusmm.geo" <gusfmm@y...> wrote:
> > Hi all. I'm trying to transmit some Sysex libraries for the
first
> > time to my VZ-10M and I can't find the right way to do it.
> > I've tried several Sysex programs (SysEx1.0, ChangeIt!, and even
> > VZPATCH which gives me errors on WinME, therefore I haven't been
> > able to effectively use it), without success.
> > The VZ is configured to receive on channel 1, excluse parameter
is
> > enabled, and I manually set it to receive MIDI VOICE/OP. I'm
using a
> > MOTU MicroExpress to merge all my MIDI setup and I've been
always
> > able to control the VZ from a Roland JV-90 that I use as my
master
> > keyboard.
> > I'm able to transmit the memory content to the PC successfully,
as
> > it indicates so, but it is a different situation when I try to
> > upload from the PC back to the VZ. Anyone has any clue on how to
> > sort it out? I've noticed every program uses a different MIDI
config
> > on regards to block size, etc. but I'm not quite sure what it
means.
> > Gus.
