CZ-5000 Step Mode Recording: Part 1: Getting Started
2004-05-30 by steve_the_composer
(1) Track Setting: While pressing and holding down the MANUAL key, simultaneously press the track selector that corresponds to the track in which you wish to record. [snip] (2) Initiating Recording: Select a timbre [patch]. TIPS: * P=0/G=0 - portomento=off/glide=off * Use transport keys to move within track. --eg, press FWD to advance a step. * use button to enter type of note, rest, triplets, repeat symbols, 1st/2nd endings, etc. * play notes to ender note data for whaever duration has been selected --eg, if you select 1/16th notes and play the keyboard, you will * enter those notes as 16th notes. * press the button repeatedly to cycle through options --eg ||: 1/4 1/2 whole :||
