Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
VZdump
VZdump
2004-09-06 by phonophobie
Hi! I remember some people also have problems with that Windows based
Editor on newer Systems like XP. If you just want to transfer
soundbanks  you can use Vzdump on a atari (emulator). I just tried it,
and it works. All i had to do is changing the filename extension intoo
VZdump language...
I found the info at http://casio.sallyandsteve.com/
" Atari ST Software
VZDUMP2.PRG, and its resource file VZDUMP.RSC have been donated by
Fred Fee. They are a CASIO VZ utility programme for the Atari ST. This
is what Fred says about it:
"I have a MIDI dump program for the Atari that can handle data in X-Or
format from any of the VZ series, so that data can be swapped freely
between them. I used it to load files from the EasyVeeZee site since
they are in X-Or VZ1 VC+OP format and then loaded the voices into my
VZ8M. I also used the program to save my VZ8M bank in VZ1 format.
Steve's editor uses the .VZ1 extension whereas my program uses .VZB
for VC+OP banks from the VZ1 since I made it compatible with the
nomenclature used by X-Or."Thanks Fred. "
phono
