I don't know if the HT-6000 and HT-700 are "that" different, but my newly acquired HT-6000 saves everything when I power it off.
I have a new unformatted ram card for the HT-6000, but as of yet I have not needed to use it. I bought my HT-6000 specifically to mutilate the bell sounds (and, trust me, when making hard techno, an analog-clipped bell from an HT-6000 sounds much fatter than a similar sound from either a poly 800 or a super jx!) and after changing the resonance and filter cutoff ... I turn it back on ... still there.
I honestly cannot say that I know what I am doing. Its just another of many sound boxes to me that I bought because no VST will ever sound as good, but the thing works like a charm.
I haven't needed to use my ram card yet because the thing saves all of my filter changes (need to make everything techno sounding).
But, my HT-6000 has been plugged into AC since I first got it. That may be why it is storing my settings. I have not put batteries in it. And I haven't changed any paramaters on anything other than the VCF, so maybe that is something it can store without writing a seperate "user" patch. But my particular box, having been powered by AC since the day I got it, remembers my VCF settings without me really having to do anything but turn the dials and hit a few buttons.
I don't know if the HT-6000 has an internal battery like the CZ-1, or if it needs juice from the "battery" batteries (I don't even know if this thing uses C or D cells!) but having it plugged in the whole time it keeps my settings.
Another factor in this may be the fact that I only use it to generate some at-tempo sounds that I record in Cubase. Most of the time, I record my loop and forget to turn it off. The dang thing turns itself off (which is hideously annoying since I'm running on ac power...). Perhaps it saves its state when it auto-powers-off.
I can't say that I am anywhere near an expert on the HT series. All I can say is that when digitally recording techno-ish sounds from within Cubase... its sound its equal to or surpasses that of the CZ-1 and Yamaha TX802. From what I understand the HT-700 is the same thing as the HT-6000, it just has half the voices.
So, in theory, your HT-700 should work the same as my HT-6000. And therefore, in theory, if you leave the thing plugged into AC the whole time, it will remember your patch changes no matter what the condition of the internal battery (if there is one) or the presence of "normal" batteries.
I'm not an expert on these things by any means, so I may be completely and totally wrong, but my advice would be to leave it plugged into AC at all times as that is what works for my HT-6000.
The HT-700 and HT-6000 may be completely different in how they store patches but from what little I know about them, leaving it plugged into AC should solve your problem.
p a t
punkdisco_uk <forums@...> wrote: Hi All. Sold my CZ1000 many years ago and finally got a HT-700. It
does not have a RAM cartridge but I was under the impression that the
'Internal' (user writable) locations would store the patterns/patches
IF you kept batteries in it. Trying this tonight and its works for a
minute but any longer and the stuff if lost.
So, should the internal memory hold stuff after turning off providing
you have batteries?
Thanks for any replies.
London
www.punkdisco.co.uk
www.punkdisco.co.uk/Music/Wot.mp3 - New annoying track
www.myspace.com/punkdisco - Zero content, more pictures
