Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
CZ-1 programming interface
2008-01-24 by jdcx64
I have both a CZ-1 and a JX-8P+PG800
The Roland is well built, it is easy to program and makes interesting
sounds, but I like the Casio even better.
The thing I don't like about the Casio is the programming interface.
The direct key for every setting is a good approach but the page
up/down cursor left/right system forces me to keep looking at the LCD
screen and spoils my mood. The value up/down keys are also not practical.
A small change to the CZ1 firmware could improve this:
- the modulation wheel could be used for parameter input
- the 8 black panel keys could be relabeled and used for direct
parameter selection,
  no more page up/down cursor left/right value+/- sus/end keys
  a first 1-8 key press to select parameters 1a-8a
  [a second 1-8 key press to select parameters 1b-8b]
  [a third 1-8 key press to select parameters 1c-8c]
example:
Changing DCW1 envelope curves:
1. press the DCW1ENV key
2. press panel key 1 for rate1; roll the wheel
3. press panel key 1 for level1; roll the wheel
[4. press panel key 1 for ***/sus/end1; roll the wheel]
5. press panel key N for rateN; roll the wheel
6. press panel key N for levelN; roll the wheel
[7. press panel key N for ***/sus/endN; roll the wheel]
This would allow me to play with sounds without even looking at the
screen.
I've been an assembly language programmer for many years and this
small change to the CZ-1 firmware is within my capabilities.
Does anyone know of disassembler/assembler tools for the NEC 87AD
series microcontrollers? Is a dump of the CZ1 ROM available?
Best regards,
Joaquim Carvalho
Re: CZ-1 programming interface
2008-01-28 by Fulfil Objective
Joaquim,
I don't think I've seen a dump of the CZ-1 ROM anywhere in all my
hunting around the web.
Your idea for reprogramming the mod wheel is interesting, although it
sounds a little intimidating to me.
If programming the envelopes (etc.) is the problem, maybe an easier
answer would be to use a higher level programming language to make a
nice application for a computer? It's so easy to interface the CZ-1
with a computer, and it has a decent set of sysex commands.  You could
have the whole computer screen to create your sounds, all the settings
at once, and not even use the little LCD.  I guess that wouldn't be as
good if what you're looking for is real-time or performance control.
But it would be good if all you need is better programming
capabilities.  And it wouldn't require disassembling, flashing ROMs, etc.
practical.
> example:
> screen.
> Best regards,
> Joaquim Carvalho
Re: [CZsynth] Re: CZ-1 programming interface
2008-01-28 by Atom Smasher
> nice application for a computer? It's so easy to interface the CZ-1 with
> a computer, and it has a decent set of sysex commands.  You could have
> the whole computer screen to create your sounds, all the settings at
> once, and not even use the little LCD.  I guess that wouldn't be as good
> if what you're looking for is real-time or performance control. But it
> would be good if all you need is better programming capabilities.  And
or better yet (for me, anyway) would be if you could do this in hardware
and put it in a 1U or 1/2U case ;)
         ...atom
  ________________________
  http://atom.smasher.org/
  762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
 	"A farmer's duty, is protecting the earth, maintaining
 	 it's fertility, and maintaining the fertility of seed.
 	 That is part of being a farmer. A farmer is not a
 	 low-paid tractor driver, that's a modern definition of
 	 what a farmer is. The real definition of a farmer is a
 	 person who relates to the land and relates to the seed
 	 and keeps it for future generations, keeps renewing
 	 it, fertility."
 		-- Dr. Vandana Shiva
2008-01-28 by jdcx64
...for me the fun thing is real-time programming with immediate sound
response.
The problem with the computer+midi sysex approach is that uploading a
patch to the CZ1 via midi takes almost 1 second.
--- In CZsynth@yahoogroups.com, "Fulfil Objective" <kasploosh@...> wrote:
> Joaquim,
etc.
> practical.
> > example:
> > screen.
> > Best regards,
> > Joaquim Carvalho
2008-02-01 by gmeredith1
I'm wanting to do the same thing, both for my CZ101 and also my
VZ10M. Surely someone out there is using one of those assignable
keyboard controllers to do this? Since reading this thread it has
just dawned on me that my Korg MicroKontrol may be just the thing
(well, Duh!!) so I might see if I can figure out how to assign all
the controls (32 of them!!) on the Korg to all the parameters on the
CZ/VZ. I can then save it in the Korg as a preset.
Cheers, graham
sound
> response.
a
> --- In CZsynth@yahoogroups.com, "Fulfil Objective" <kasploosh@>
wrote:
> > Joaquim,
although it
easier
make a
1
could
settings
be as
control.
ROMs,
> etc.
interesting
interface.
the LCD
> > practical.
> > > example:
> > > screen.
this
87AD
> > > Best regards,
> > > Joaquim Carvalho
2008-02-11 by jdcx64
That would be great(!) but I don't think it is possible, there are no
SYSEX messages for changing individual parameters on the CZs.
There's a message for sending all patch parameters as a whole but it
takes almost 1s and can not be programmed on the MIDI controllers that
I know of.
If anyone has any info contrary to this, please say so!
Joaquim
> Cheers, graham
> sound
> > response.
> a
> wrote:
> > > Joaquim,
> although it
> easier
> make a
> 1
> could
> settings
> be as
> control.
> ROMs,
> > etc.
> interesting
> interface.
> the LCD
> > > practical.
> > > > example:
> the
> > > > screen.
> this
> 87AD
> > > > Best regards,
> > > > Joaquim Carvalho
