Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Vz-10m
Vz-10m
2011-07-13 by dogstar669
I just picked a casio vz-10m at a pawn shop for $75.
It worked great but I noticed the presets had been changed, so I reset it. Held write during power up.
It seemed to reset it, but now the LCD is blank (all pixels darkened I think would be the best description.).
When I turn it off and on, I think it shows an error message or at least some sort of text before the display goes all dark, so I'm pretty sure the actual LCD is still fine.
It still seems to be working and I can play all the original presets now. Just no LCD.
Any ideas on how to fix it? I'm hoping it is simple. Right now, I have it unplugged and will try it again in a few hours.
Re: [CZsynth] Vz-10m
2011-07-14 by José Ángel Morente
Did you check the internal battery?
2011-07-14 by Gordon JC Pearce
On Wed, 13 Jul 2011 23:19:12 -0000
You probably reset the contrast with all the other settings.  I have no idea now how to adjust it; probably press and hold "DISPLAY" while moving the data slider.
Gordon MM0YEQ
Re: Vz-10m
2011-07-14 by narfman96
> Gordon MM0YEQ
Wow Gordon!!! It's on page 25 of the VZ-10m manual. Hold the display button and move the value slider.... common sense rules again!
Re: Vz-10m
2011-07-14 by cwjall
Try holding the display button down (right of display) and use the value slider to ajust the brightness I think that is how I do it on mv vz-1
> Gordon MM0YEQ
Re: Vz-10m
2011-07-15 by dogstar669
Thanks!!! That fixed it like a charm.
BTW, I love the sounds coming out of this thing. So pure, so digital. It's really not ashamed of being a digital synth.
I think it will be great for doing some video game compositions.
> > Gordon MM0YEQ
Re: Vz-10m
2011-07-15 by steve_the_composer
Congrats on a spectacular find!!!!
Steve
RE: Vz-10m
2011-07-15 by tttsystems@earthlink.net
You have to adjust the LCD contrast....instructions are in the manual (I am on holiday in Europe right now).  You have to hold a button and use the slider....that should restore the LCD.
Bob
El Segundo, CA
Tin Stockholm for a few more days)
---- Original Message ----
Reply-To: CZsynth@yahoogroups.com
Date: 07/15/11 3:30 PM
Cc:
Sub: [CZsynth] Re: Vz-10m
Steve
---- End Original Message ----
RE: Vz-10m
GreatN just reading older emails and found someone already answered your question...with more info than I had.  Glad it worked !    Bob  El Segundo, CA
Date: 07/14/11 8:20 PM
Cc:
> > Gordon MM0YEQ
