Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
output level in CZ-101
2013-03-09 by mm47
hi all!
I just had shipped my first CZ synth :), which I boutgh on ebay.
I already feel this could be one of my favorite synths (I own several rolands, korg, moog, sequential circuits,...)
Through headphones it sounds right, but when connected from the output jack to a Mackie mixer, the sound is so low that I need to increase the mixer channel gain to have it sound at levels comparable to other synths (more than 20dB). (of course the CZ volume is set to the max, and that slider works fine).
I have the impression that it just shouldn't be like this, but I'd like to hear a confirmation, before moving on to try to see if this has to be fixed and how.
It sounds fine, it's just so weird the signal level is so low.
I suspect it might be broken, also because the guy who sold it to me had put a piece of tape on the output jack.... (but this guy said twice it was working perfectly...).
Can comment on the output signal level?
Also, does anybody know in more detail what's the expect ouput level (say for a pure sinewave of given frequency and max amplitude and volume), I mean some objective way of quantifying it, so that I can try to measure it (I own a multimeter, and probably goign to buy an oscilloscope soon)?
Thanks ahead of any suggestion!
Best,
Marco
Re: [CZsynth] output level in CZ-101
2013-03-11 by Jing Garcia
Yes. By the way you described it, there must be something wrong with the signal from that output jack.
A lose internal connection or dirty leads perhaps? At least you have sound coming from the headphones jack. That's a good sign :)
Sent from my BlackBerry wireless handheld
Sender: CZsynth@yahoogroups.com
Date: Sat, 09 Mar 2013 21:01:42
To: <CZsynth@yahoogroups.com>
Reply-To: CZsynth@yahoogroups.com
Subject: [CZsynth] output level in CZ-101
hi all!
Best,
Marco
2013-03-11 by Narfman96 - Narfland Studio
The output muting relay is bad or not working. Check the schematics that were posted recently. You can bypass it for a test but there will be a turn on spike in the output.
>________________________________
> From: mm47 <marcoballins@...>
>Sent: Saturday, March 9, 2013 4:01 PM
>hi all!
>Best,
>Marco
