Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
CZ-1 Relay Failure/Low Volume
2013-06-07 by Paul
So I somehow bought both a CZ-5000 and a CZ-1 today and I'm wondering if the CZ-1 needs to have a relay replaced. The volume seems very low no matter what I crank up. I'm having trouble finding any direct discussions about relay replacement though I do find mention of low volume troubles.
 Also, my CZ-5000 needs a C key and the slider caps replaced for the volume and chorus sliders. Does anyone know of a source for replacements?
    Paul T
Re: CZ-1 Relay Failure/Low Volume
2013-06-11 by angelsynth
Hello all,
I'm looking too for replacements for volume and chorus sliders of my "new" Cz1.
Does somebody know where to find spare parts or replacements that fits the CZ1 sliders?
Ángel
>   Thanks,
>     Paul T
Re: [CZsynth] Re: CZ-1 Relay Failure/Low Volume
2013-06-12 by analogmonster@...
Not that i can give you an answer for where to source either, but it may help if you specify whether you mean the sliders themselves or the slider caps.
On 11 Jun 2013, at 13:36, "angelsynth" <angelsynth@...> wrote:
> Hello all,
> Regards,
> Ángel
> > Thanks,
> > Paul T
2013-06-12 by jammie
try alps or alpha
you will need to find the dimentions of your sliders volume are log audio types if its stereo they will be dual log
2x10ka are the usual oners used for audio on most synths both old and new
  To: CZsynth@yahoogroups.com
  Sent: Tuesday, June 11, 2013 1:36 PM
  Subject: [CZsynth] Re: CZ-1 Relay Failure/Low Volume
  Hello all,
  Ángel
  > Thanks,
  > Paul T
2013-06-12 by Paul Krull
As far as replacing the slider caps which seems to come up often on the CZ-5000 I have only found this guy and while the caps fit they clearly are not original or a close match:
http://sounddoctorin.com/synthtec/casio/cz5000.htm
  Paul T
To: "CZsynth@yahoogroups.com" <CZsynth@yahoogroups.com>
Sent: Wednesday, June 12, 2013 10:35 AM
Subject: Re: [CZsynth] Re: CZ-1 Relay Failure/Low Volume
> Hello all,
> Regards,
> Ángel
> > Thanks,
> > Paul T
Yahoo! Groups Links
2013-06-12 by Narfman96 - Narfland Studio
The CZ1 service manual lists these as Panasonic EWA style slide pots. I attached the pdf datasheet if it will come through...
The stereo chorus pot is a 50k dual with a B taper. It is 30mm travel. The Panasonic part number is EWA-NA1X05B54.
The single volume pot is a 10k with a B (log) taper. It is also 30mm travel. The Panasonic part number is EWA-NF0X05B14.
Panasonic discontinued these so if anyone finds a source or replacement for these I would really like to know. These are used in many of our synths from this era. The datasheet has all of the dimensions and leg placement to help with replacing them.
>________________________________
> From: jammie <jammie.emma@...>
>Sent: Wednesday, June 12, 2013 1:40 PM
>try alps or alpha
>----- Original Message -----
>From: angelsynth
>To: mailto:CZsynth%40yahoogroups.com
>Hello all,
>Regards,
>Ángel
>> Thanks,
>> Paul T
No attachment here's the link:  www.panasonic.com/industrial/components/pdf/aol0000ce2.pdf
The moderator of this group could turn on the attachment option in group messages if they choose to do so.
> From: Narfman96 - Narfland Studio <narfman96@yahoo.com>
>Sent: Wednesday, June 12, 2013 2:24 PM
>> From: jammie <mailto:jammie.emma%40blueyonder.co.uk>
>>try alps or alpha
>>From: angelsynth
>>Hello all,
>>Regards,
>>Ángel
>>> Thanks,
>>> Paul T
