Soundtower editor not updating after changed made on MEK
2009-10-24 by waxwobbler
Hi When iI make changes to the patch using the knobs on the MEK the GUI in the editor is not updating. I have editor V5 a midisport 2x2 & cables connected in - out & vice versa. I think everything is cabled correctly as when i adjust the gui the MEK updates. When I change the MEK no update to the gui until I hit receive. The MEK is online & shown as such in the editor. Does it have anything to do with the "Enable editors control real time update" in th evirtual midi ports ? I can't find any info about this. Also in logic there is a Evolver SE virtual midi port, what are these used for ? I have the problem when running Logic 9 or when just the editor is running. When I twist the knob logic shows x 1 0 0 as incoming data, I guess this is the sys ex. Hope some one can help me out with this, Thanks......
