DTXTREME IIS Question - appropriate message board?
2004-07-21 by vl2000_us
Hello,
Please direct me to a more appropriate board if this is not a good
place to ask a question about setting up the brain for DTXTREME IIS.
I am hoping the question is relative to earlier brains as well, since
this one is fairly new.
First, I will warn you that with 25 years behind the kit, I have zero
experience with these electronic modules.  I have started a new
project and plan to trigger my acoustic kit to elimate all the open
mics, etc.
I purchased the DTXTREME IIS brain and have been pouring over the
manual for the last 2 days just to try to get some of the information
to sink in.
The one thing that is confusing me most at this point, is I came
across a section of the manual that talks about programming NOTES to
each channel.  This precedes a section on programming VOICES.  VOICES
I understand, notes ...I do not.
Is this an optional thing, it doesn't appear so, since the section on
voices, seems to reference notes... arggggghhh.
I don't know notes, I am but a lowly self taught old fashioned
drummer!
How do I know what notes to tell it for each trigger channel?  Are
there any guidelines?  I have 11 toms from 6x6 to 18x24, snare and
kick.  I tune them on 'soft' or 'wet' side.  I don't know what notes
they should be :-)
Can anyone offer some guidance?
Thanks in advance for any light shed!
Vick
Re: DTXTREME IIS Question - appropriate message board?
2004-07-21 by emf
to
VOICES
on
> drummer!
notes
> they should be :-)
Hi Vick,
This is a fine place to discuss the DTXT2S module. A bunch of members
have it. I don't happen to be one of them at the moment, but I'll be
happy to get your foot in the door. As basically a MIDI instrument,
an electronic drum module includes note numbers among its settings as
part of the MIDI language that instructs MIDI-compatible devices
about what sounds to play and how to play them. There are sixteen
MIDI channels available to transmit such commands. Traditionally,
percussion voices get their data through MIDI channel 10, the default
for drum modules. Each of a Yamaha module's inputs has traditionally
had its own note number, which will correspond to any percussion
voice preset to it at the factory or assigned to it by a user (unless
the user changes it for some reason). Generally, MIDI-challenged
drummers who just want to bang away can ignore these note numbers as
they program their selected voices for pitch, decay, volume, etc. An
elaborate module like the DTXT2S, however, also allows drummers to
make tonal music in addition to the thumping that normally gets
programmed via channel 10. You can create all sorts of patterns,
loops, phrases, songs, and chords on the internal tone generator to
play as the sampled instrument of your choice, when pads or keys are
struck, routing the commands along the channel of your choice.
Obviously, you can't instruct an instrument, even a tone generator,
to play a chord or a melody unless you also tell it what notes to
use; the module deploys the standard MIDI code for this purpose (I
believe that p. 41 of the manual is a primer on note numbers in this
context).
For now, you'll probably stick to setting up percussion voices by
input from the list somewhere in the manual; note numbers should
simply go along for the ride without making any further demands.
However, as you venture into the world of MIDI, notes and their
accompanying numbers per se will become significant. As you master
the module, and germinate ideas to implement, the notes will also
seem less daunting.
I've just extrapolated very simply from the Yamaha modules with which
I'm somewhat familiar. I hope that I haven't misrepresented the
DTXT2S. I'm sure that someone will say so if need be (Cheakser,
OGD?). Why don't you try programming your drums, or simply hooking
them up to a preset kit, and see what specific questions arise.
Ed
Thanks for your warm welcome :-)
as
This may very well be my answer.  The manual made me think that I HAD
to program these notes first, prior to assigning a voice.  This
totally threw me for a loop!  If it's ok to just skip by that section
and go right to voices, I can start to dig in!
An
are
Definately not for my project :-)  My primary goal is to trigger my
acoustic set by finding similar voices in the module and maybe adding
some chorusing or layering to thicken the sound.  My secondary goal,
is to marry the pads from the DTXT2S into my acoustic kit for second
snare, handclap and some other special needs sounds.  If I can do all
this without getting into the whole 'notes' area, I will be
thrilled :-)  Nothing wrong with notes, but I'm a tad long in the
tooth to start a whole new learning curve :-)
Thank you so much for your guidance!
Vic
Re: [DTXpress] Re: DTXTREME IIS Question - appropriate message board?
2004-07-25 by temp1111
Ed,
The rest of my DTXT2S is supposed to arrive tomorrow (the module, snare and cymbals arrived last week separately) So I've been re-reading the manual over and over again, as well as your response to my post. If possible, I'd like to dig a little further into your response to ensure I am understanding correctly. Then tomorrow when everything arrives I can really dig in.
So are you saying that as long as I am not using the notes perse', I can basically assign any voice to any note and the voice will remain as it is supposed to be and is not affected by the note at all. In other words the note just becomes a 'pointer' to the voice. The the voice can be adjusted as needed. For example it wouldn't matter if I assigned a C, D or F to a given voice, the voice is going to sound the same, unless I specifically change the voice? Am I on the correct track with this line of thinking?
>You can create all sorts of patterns, loops, phrases, songs, and chords >on the internal tone generator to
Speaking of 'chords', I can think of several instances where I might want to try layering more than one voice together, such as a snare and a handclap, multiple toms (to thicken it up), etc. Assuming I'm anywhere near the right track (above) regarding notes, would I have to assign an arbitrary additional note to that trigger first? Then, assign the additional voice? This is kinda what I am thinking but the manual is not very clear on this, as it seems to be written for someone who already knows about midi notes, e-drums, etc., as opposed to a lifetime acoustic player :-)
Thank you once again for your knowledge and patience.
Vick
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: ; DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
2004-07-25 by emf
--- In DTXpress@yahoogroups.com, "temp1111" <temp1111@w...> wrote:
> Ed,
The way other Yamaha modules work is that if you are working with
untuned percussion voices, you don't change pitch by selecting notes
from a scale per se (say, middle "C") but via a numerical setting
that raises or lowers the voice by increments. So long as you're
working with drum/cymbal/percussion voices, the note number assigned
to them will not change regardless of how you tinker with the voice.
As I said, that's my take on it from previous experience. I don't
have the module itself with me, though I've read through the manual.
Drumsonly, Cheakster, and OGD should be able to confirm.
Again, extrapolating from previous experience, when working with drum
voices, the module should give you a distinct option for stacking or
alternating voices, and you should be able to follow the thread of
steps easily enough without getting tangled up in extraneous music
theory. For instance, the DTXpress allows two voices to be stacked
via the voice menu; you don't assign MIDI notes to do so.
Let me add that these functions all seem daunting in the abstract.
But once you get the actual module in front of you, and you realize
that it won't blow up or laugh at you if you make a mistake, they
eventually begin to accumulate their own logic (regardless of the
module's deficiencies in that respect).
Ed
2004-07-26 by Dan Cheak
notes
assigned
voice.
manual.
drum
or
> > Ed
CONFIRMED! ED!
I have done absolutely nothing with "midi--notes", etc., but am
having a ball extending and altering the voices in all directions!!
This module offers incredible voice control, and , with the RED pad
control BUTTON (which itself can be assigned several different
parameters to control), you can do a final tweak
of "tone", "volume", "tension" etc!
And YES! You can layer the pads. I have not done much with this yet,
but have seen as many as 3 velocity layered voices in a pre-
programed snare.
(from Temp1111)
You are right on!!
  The truth is..it's very simple! The sad thing is...you just have
to figure it out to get to the simplicity! The manual will not start
at step (a).... Once I stumble into something and work with it, I
then go back to the manual and it makes a little more sense. I
just "broke the code" on some really cool EFFECTS this
weekend....WOW!...a whole new range of great sounds!It's endless! IT
JUST KEEPS GETTING BETTER!
Enjoy!
Dan
2004-07-26 by temp1111
>theory.
I couldn't agree more. I think its mostly that the manual is poorly written for anyone who does not have experience with these devices. The rest of my kit is due to arrive today and I'm sure once I start fiddling with it, things will start to become clear.
For reference to where this whole confusion started, here is the introductory paragraph from page 48 of the manual, for the section entitled Voice Settings. Keep in mind that this is preceded in the manual by the section on midi notes, which in and of itself is quite confusing and appears to be a pre-requisite to the voice settins:
Voice Settings - Edit Pages and Basic Operation
"In the first six pages you can assign a drum voice for each note number contained in the rhythm and drum part (MIDI channel 10)........note the huge amount of note numbers available...........this is the total number of useable notes..........to set up a simple kit."
That is where I got all hung up... well, anyway, thanks for your clarifications, and I will post as soon as I get everything set up and working, if I have further confusion :-)
Have a great day!
Vick
CONFIRMED! ED!
This is encouraging news!!! Thanks for the post!!! C'mon UPS.... hurrry up!!!
