Points of Interest
Points of Interest
2004-08-02 by oldguydrummer
I noticed that Yamaha now has a paragraph in the brochures that come
with the various pads that state that the rubber and foam do have a
limited life cycle depending on the amount of play and that you can
contact them for "replacement" parts. I would have to go back and dig
out the manuals for my DtxpressII kit pads, but I don't remember that
being in there, specifically, talking about the foam in the KP65
deteriorating.
Also, got out the tools and took apart some of the new pads. I will
try and post some pics of the insides by the weekend. Specifically,
the TP100/TP120S/PCY150/PCY130S/PCY130/RHH130. Since the latter four
are a part of the Dtxpress IIIsp, I will post the pics here in this
group. The TP pads are only a part of the Dtxtreme IIS, so those will
be posted to the Yahoogroups/dtxtreme group only.
The RHH130 top is the same material used on the PCY130S, except the
color of the plastic is black inside rather than the silver on the
bottom of the PCY130S. The metal "clutch" that attaches to the hihat
rod is not attached to anything inside the pad, so you don't have to
worry about it rotating and hurting something inside. It is just a
hunk of metal with a teflon washer on the bottom. If you look at the
HH65 pictures you will see a rubber rocker  that presses down on some
ribbon sensors. They have simple modified the sensor ribbon and the
rubber rocker to accommodate the hole in the middle for the shaft and
placed it in the bottom plastic housing of the RHH130. Instead of
four contact points on the HH65, there are five contact points on the
RHH130 sensor ribbon. The metal clutch simply presses down on this
rubber rocker. Simple and elagant.
(This actually looks like a winter project in the working. Since
there is no real need for the top rubber pad to come in contact with
the bottom pad, there maybe a way to modify the RHH130 so that the
top swings a little more freely, as it is a rigid as a rock as it
comes from the factory.)
OGD
