you might want to look at the self-rejection settings in the trigger
menu also- try reducing that a notch or two.
On Mon, 29 Nov 2004 16:36:08 -0000, emf <liberatusvirus@...> wrote:
> --- In DTXpress@yahoogroups.com, "rav4t3" <a.holmes@u...> wrote:
> > Hi fellow pad bashers,
> > I have a pretty simple problem to put forward to the group,
> > (Bearing in mind that I am quite new to the world of E Kits)
> > I am experiencing a volume issue with the Kick Drum sound.
> > I have noticed that If I hit say about ten consistent single beats,
> > one or two notes are heard at a higher volume or depending on how
> > you look at it, eight are too low and 2 are OK.
> > The volume setting in the modules display indicates 127,
> > I have adjusted the gain pot on the rear of the actual rubber pad
> > which as expected, increases or decreases the volume.
> > This erratic Kick volume is evident on all factory kits,
> > I have not edited any of the factory volume settings on the Kick.
> > I have to be honest the Kick volume seems a lot lower than the
> snare
> > & Tom's, the Kick seems to be at maximum ?
> > It's as if the pad is not working consistently ?
> > Am I thick or am I missing something ?
> The first thing to check is the cable. If swapping another cable from
> the kit doesn't help, it's possible that the pad is defective. The
> problem might be a loose wire or bad soldering, both of which you
> might be able to fix yourself, though I wouldn't open up the pad if
> the kit is still under warranty. If you haven't adjusted any trigger
> settings yourself, and another cable doesn't eliminate the problem,
> contact the dealer. You might be directed to Yamaha, but they are
> usually responsive. If you don't get any satisfaction, let us know.
> We can probably get someone's attention.
> Ed
> Community email addresses:
> Post message: DTXpress@yahoogroups.com
> Subscribe: DTXpress-subscribe@yahoogroups.com
> Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
> List owner: DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
> http://www.dtxpressions.com
Creighton Higgins
