TP65S Edge Switch Problems
2004-12-01 by bparker0701
I'm having a problem with my snare (TP65S). When I hit any side (edge), I only get one sound (1st edge I believe). Only every once and a while will I get the 2nd edge sound. I've taken the trigger apart. I'm an electronics engineer, so I have a lot of experience in this area. It's not a complicated device what so ever. It looks like everything is in good shape, I see no wear. The only soldering is on the piezo itself and where the components (resistors and jack) are soldered to the small PCB. The edges really just look like switches made with serperated, conductive traces on a plastic base. It might be a somewhat resistive conductive trace to provide a resistive curve based on the intensity of the strike. Could they be somewhat stuck together on the 2nd endge? Is it just worn after more than a year of playing? The snare takes the most abuse, but not the edges by any means. Could it be some stupid setting that I mistakenly changed in the brain? I haven't tried resetting the brain to default and reloading my kits (via MIDI of course). Bill
