Expanding My Rack System...Extra Long Tubing Available?
2005-01-10 by zapaxe
I'm expanding my DTXpress rack system. This is getting VERY
interesting and reminds me of playing with an erector set. The
possibilities seem endless...If ONLY I had MORE rack parts "he,he"...
I just bought a 2nd DTXpress rack (used) to accomodate all my extra
pads & modules. I've already merged the two racks together with most
of the rack parts... Very cool too! I now have a full extention with
3rd base/leg which is rock stable for my 3 modules to sit on :)
In addition to my extention onto the left side of my rack - which is
similar to an older DTXtreme rack now (I think?) - with it's 3
base/legs, and a 2nd teir extention to the right...
...I thought about extending the center section of the rack in
an 'upward' fasion. Actually I did 'somewhat' already by adding
the 'T' fitting on top of each left & right tall post/tubes. I set
the 'T' fitting half way on each side and used more taller tubes,
then placed another log tube at the top in the horizontal position.
After my 'upward' extention, I got to thinking...Hmmm...maybe this
is not the most stable, though it seems fairly stable...
...Being electrician for a living, I'm think that 1 1/2"
EMT 'thinwall' conduit/tubing has the same outside diameter as the
DTXpress rack. Though EMT conduit is steel not aluminum.
So!...I was thinking that 'instead' of having a hodge-podge of end
to end DTXpress tubes held together with my 'T' fittings used as
couplings, I could use TWO  vey long/tall tubes of EMT electrical
conduit in it's place.
I tried looking around at Home Depot for some long pieces of
Aluminum tubing but didn't find any.
Any idea on WHERE I can find very long pieces of aluminum of the
same diameter?
Of course I'd paint the tube black :)
Steve
Re: Expanding My Rack System...Extra Long Tubing Available?
2005-01-11 by vap19592000
--- In DTXpress@yahoogroups.com, "zapaxe" <a_zapelectric@h...> wrote:
> Hi,
parts "he,he"...
most
with
is
> same diameter?
> Steve
Hi Steve..
Would love to see a picture of what you are doing with your rack.
I did a similar upgrade myself, by merging my existing rack with a
gibraltar rack.
When I ran out of tubing, here is what I did. I found out that
the "Torchiere" FLOOR STANDING LIGHTS (hope I have spelt it right),
has 3 pieces of tubing twisted together to make one long piece, makes
an ideal substitute for the rack tubing. It is made of steel, sturdy
and just about the same diameter as the rack tubing. It is also
LIGHT. The LAMP I am talking about has a heavy round base in the
bottom and a dish bowl type shade on the top with HALOGEN type bulb.
It has a on-off rotational switch in the middle piece of the tube.
The lamp is made in China and most probably sold in home
depot/orchard supply...but why pay for a brand new one??? I found
heaps of them at the local SALVATION ARMY of THRIFT used store
outlets, or any place where they sell USED stuff. I paid $5.00 for a
good working one, and in great condition. The tubing was also BLACK.
Took it home and "gutted" all the unecessary stuff by cutting the
wires and unscrewing the three metal pieces. The final
product...about 6 feet of steel tubing. NOTE though, not ALL the
floor standing lamps are simialr as to the one I have described
above. Some have different types of stands....but when you spot one,
you'll know thats the one....
GOOD LUCK!!
VAP.
2005-01-11 by zapaxe
Hi Vap,
Huh, I 'thought' you were about to go into some sort of lighted drum
rack Hybrid for a moment! :o ...We could even install a dimmer
switch 'lol'...
Yeah, I was thinking about what 'other' things have as far as tubing
go's...Even my computer desk, bought at Office Max has the exact
size tubing used for it's base to table top legs. I figure I have to
be able to find this stuff available somewhere!
When I'm done I'll see about taking a picture of it! I think it
would be interesting to see what OTHERS have done with their racks
and what creative ways can be configured. I really hadn't thought
too much about getting ceative beyond a simple 'To-The-Side-Add-On'
extention untill I did my side extention and then had extra parts to
then play with.
At first I was dumbfounded on what to do...I stared at it over a
beer or two, then with a proper buzz, I started getting
creative 'he,he'.
To describe what I've done so far...To the left of my existing DTX
rack, I've added a 3rd base, the 90 degree leg as on both sides of a
standard DTX rack. I then added a long tube horrizontally(as in a
cross tube middle section of a DTX rack)to connect this 3rd leg
section to my 'tall' left virtical tube. This cross-extention now
has a completely stable tube to mount my multiple modules on. This
looks great and in addition to being stable, it's very functionable!
As you know, when you install just ONE module in the NORMAL fasion,
your rack starts a rockin' when you get rockin' - Try TWO modules!
You've seen 'The Flinstones' when Fred get's a side of brontasouras
ribs put on his car, tipping it over? :o
Ok, for my extention in "The Upward" fasion...What I've done is
simply use my extra 'T' fittings as couplings to extend the Left &
Right virtical tubes with my spare long tubes by about 2 ft or so.
Then 'instead of the long tube with the "Yamaha" lable at the lower
section as a 2nd cross section as shown typically on a DTX rack, I
used this longer "Yamaha" lables tube at the 'Top' of my "Upward"
extention. Looks VERY cool too! Besides looking very spiffy
esthetically, I can then mount more semi-long extention tubes
horrizontally on either side of my higher placed virtical tubes to
mount more various cymbal & drum pads etc...
As said, I'd MUCH rather have the original, virtical sections of my
DTXpress rack as one LONG tube on EACH side, rather than have
to 'coupling' them together with the standard Yamaha 'T' fittings
for much better stability. I'd imagine that with much use, the
vibration of playing may loosen the coupled extentions, ESPECIALLY
if I then mount various extra extentions arms and pads to them!
As it is the center section of my rack with it's two virtical
extentions stands about 4 ft tall, but I'd like it to be a little
higher when I can use longer/taller/single one-piece virtical tubes.
Actually, I think I was wrong about the 1 1/2" EMT electrical
thinwall tubing being the same size...I quickly checked a while back
out of curiosity, and I 'think' it's actually 1 1/4" EMT thinwall
electrical tubing/conduit that's the same outside diameter...Or VERY
close at least! I remember actually trying a Yamaha 'T' fitting on
it at one time. Electrical EMT conduit however is not as 'smooth' as
the aluminum tubing as it's slightly galvanized and may need to be
smoothed out with a fine sand paper before painting it
black....Speaking of paint and racks, I really DO NOT like the look
of the DTX III rack systems with the silver color and the ribbed
tubing. Though I guess the ribs add to the tightness of the fittings.
I always thought that the DTXpress kits with it's simple & small
rack looked kind of basic and "toyish". With my extentions I've
install so far, the set looks MUCH more pro-like.
Anyway, all this rack extending is my NEW passion or should I
say 'obsession'...I don't know why I didn't do this a long time ago!
If anyone else has ideas and/or pictures of getting creative with
their glorious racks speak up! :)
Steve
Hi Steve..
> gibraltar rack.
right),
makes
sturdy
bulb.
a
BLACK.
one,
> GOOD LUCK!!
> VAP.
2005-01-14 by zapaxe
Hi and thanks,
I've been checking ebay for a long time for deals on used DTXpress
components etc...That's where I bought my 2nd Yamaha DTXpress rack
used from.
I've also looked many times at Drumbalya, but I've not noticed any
VERY long tubes for racks. What I was proposing to do is have two
very log rack tubes (longer than ANY DTXpress rack tube I've seen,
so I can have a tall center section rack without having to have to
use some sort of couplers as I'm doing now. I can actually see the
tube slightly lean at the coupling joint. When I add a load to this
weightwise, it'll be worse:(
I'll have another look at Drumbalya to see if I've missed something
other than the 'standard' tube lenths.
If not, I'm wondering who carries aluminum tubing in extremely long
lenths? Not Home Depot, Nlot Lowes, Not Orchard Supply Hardware...I
guess a specialty metal shop oof sorts. But as I said, I beive that
electrical EMT tubing/conduit is about the same outside diameter. If
nothing else, I'll give that a go! Don't know how much aluminim
tubing would cost in it's raw state...?
Steve
--- In DTXpress@yahoogroups.com, "tboginski" <tboginski@y...> wrote:
> Drumbalya sells the yamaha tubing in almost any length you would
need
> (clamps too)..also check ebay, i see that stuff on there all the
time.
2005-01-14 by moosetication
--- zapaxe wrote:
> What I was proposing to do is ... have a tall
>  can actually see the tube slightly lean at
> the coupling joint.
Why not reinforce the joint INSIDE the rack tube? Use something
that's a tight fit, like a length of large wooden dowel.
Remember that Roland and Gibraltar racks are the same 1.5" section,
and the tubes and clamps are interchangable.
Stewart
Re: [DTXpress] Re: Expanding My Rack System...Extra Long Tubing Available?
2005-01-14 by Charles Baer
I usually am looking for turbo plumbing here, a pretty good selection of
metal tube:
http://www.aircraftspruce.com/index.php
Charlie
zapaxe wrote:
>Hi and thanks,
>used from.
>Steve
2005-01-15 by zapaxe
Thanks Charlie,
Quickly looked through the Aluminum tubing and they have 'plenty' of
aluminum tubing to choose from!
Steve
selection of
> metal tube:
> Charlie
> zapaxe wrote:
> >Hi and thanks,
DTXpress
rack
> >used from.
any
seen,
to
this
something
long
Hardware...I
that
If
> >Steve
That's a pretty good idea to reinforce from the tube from the
inside. I 'thought' I heard before that 1.5" is a standard.
Now that OGD posted a link -
http://www.bananas.com/productdetail.asp/pid_3071/productname_Ultimat
e-Support-12068-Standard-Tubing-Black,-1-1/2 - where I can get
a 'Generic' tube (1.5") in lenths from 1 ft, up to 12 ft and they
are already painted black to boot, I think I'll look into
the 'single' long lenth option.
My rack is gonna' be rockin'...err..hopefully NOT rockin' that is :)
Steve
--- In DTXpress@yahoogroups.com, "moosetication"
> > the coupling joint.
section,
> Stewart
