Amplify!
Amplify!
2005-02-03 by samuelhcohen
First off, I want to say that I haven't been to this group in a while. In fact this is the first
time that I've seen the DTXpress III (I'm a DTXpress II owner). Wow... It looks pretty slick.
Especially the new high hat assembly.
Anyway, I want to amplify my kit. I want to play loud. I'd like to be able to reach acoustic
kit volumes. What's the best way to do this? I've been told that a PA is the best thing to do.
I've also been told that I can use a keyboard amp. What do you guys think? What have your
experiences been with amplifying the DTX? How much power do I need?
Thanks for your input!
Sam
Re: Amplify!
2005-02-03 by swanseadrummer
Sam,
I am going through the same kind of process myself.  Last Saturday I
used the kit live for the first time and started off by going through
the main PA.  A Peavey 1300w stereo power amp and Peavey mixer.  The
problem I found was that the kit sounded very far away and the rest
of the band really missed having those drum sounds coming from behind
them as is usually the case.  Second half I reverted to a 150w
Carlsbro powered wedge monitor right next to the kit and it all felt
a lot more comfortable for every everyone including myself.
Volume though was little restricted as I was running at full volume
on the wedge and on the DTexpress - so there was nowhere to go when
more volume was needed.  Next gig I will be trying out a separate
200w pa system and also a line out to the main pa just to see how
that works.
I guess a min 300w system would be better and to this end have been
looking at the Carlsbro system that is on ebay for £199.
I'm shure there are plenty of drummers on this group that have far
more experience with this kit than I have and can advise better, but
for me it seem the more power, coming from the vicinity of the kit
(not too close so it seems) and easy access to control it yourself
the better.  Would be interested to know what you settle on.
Aeron
--- In DTXpress@yahoogroups.com, "samuelhcohen" <samuelhcohen@y...>
> Sam
Re: [DTXpress] Re: Amplify!
2005-02-03 by MrPhoney@aol.com
I use a Roland KC500 Keyboard amp. 150W and 15inch speaker with dome
tweeter. I used to use a 300 watt bass head hooked up to a 4x10 speaker cabinet.
That was even better.
2005-02-03 by nick@nickmela.com
I use a Peavey keyboard amp which really has a wide range and sounds good.
I have a 200watt bass amp with two cabinets that have a 15 inch speaker,
two tweeters and a horn in each cabinet. It definitely has power but it
doesn't give me the range especially with regards to the cymbals. They
don't sound nearly as good as the keyboard amp. I'll try different
settings on the bass amp and report back.
> cabinet.
2005-02-03 by Vernon Graner
When this happens, drummers will sometimes decide to put a large PA
system or amp/speaker combo of some type right near the kit. Then you may
end up with another common problem for live, loud amplified kits:
dropouts and false triggers.
What you might try (depending on how much power you have) is to route the
kit to the floor monitors so the band can hear the beat. Also, to make
the experience better for you, try using a "butt kicker" type "bass
shaker" transducer. There's been discussion of using these in a previous
thread:
http://launch.groups.yahoo.com/group/DTXpress/message/9967
Vern
Vern Graner CNE/CNA/SSE    | "If the network is down, then you're
Senior Systems Engineer    | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com        | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" \ufffdVLG
