Inputs on DTXPRESSIIISP
2005-03-14 by electricmusic
I just purchased a DTXPRESSIIISP but it has not arriced yet.  A
question that has been nagging at me.....
Is the DTXPRESSIIISP in any way expandable? ....
as far as something like adding a cowbell trigger without sacrificing any of the standard
triggers and sounds that come with the kit as is from the factory?
Or are all the trigger points used up already with the hardware provided?
Also, does anyone out there have any suggestions for setup that are not already in the
manual?
Thanks, THC
Re: Inputs on DTXPRESSIIISP
2005-04-18 by jkfrench
I also just purchased a DTXPRESSIIISP and have been playing around
with expanding it through the MIDI port.  I had an old Yamaha DD-50
(the newer iteration of this is the DD-55).  I connected it to the
DTXPRESS III module (MIDI out of DD-50 to MIDI in of DTXIII) and then
mapped each of the pads to play one of the 900+ available drum voices
of the DTXPRESS III.   You can also just use the voices from the DD-
50 (or other midi device) directly, but I found the mapping gave me
more of the sound I was looking for...and definitely a lot more
options for voices!   Since the DD-50 has 7 pads and two 'foot
triggers' it gives me a potential of 9 additional 'voices' through a
single midi connection (although I am not personally using the 'foot
triggers').
I'm not however saying this is a perfect option, and it definitely
takes a bit of work to get both ends in sync.  The biggest problem I
have however is finding the right location for it...I haven't gotten
that issue quite worked out yet.  It may be better to have one of the
smaller units (like the 3 or 5 pad versions...or maybe something
totally different).  But the MIDI option for expandability seems a
reasonable one at this time.
By-the-way, when I unplugged the DTXIII, it lost all of the mappings
I set up (it saved my 'kits', but not the map...it may have been
something I did, but it may not be too).  I would recommend keeping
some sort of 'written' record if you decide to use midi mapping, so
you can restore it all in a short amount of time.
Also, as you will find out, all of the trigger inputs are used with
the default set.  However, the 'Crash 2' input is a stereo input, and
according to the documentation the Crash 2 that is plugged into that
input is only a mono, single voice pad...even though they give you a
stereo cable for it, so you could potentially add an additional mono
trigger to that stereo input, giving you a seperate input on both
left and right sides (and are considered port 9 and port 10 by the
DTX III module).  You'll see once you get your set.
I hope this was of some help.
Jeff
--- In DTXpress@yahoogroups.com, "electricmusic" <thcmusic@c...>
provided?
not already in the
> manual?
> Thanks, THC
2005-04-18 by emf
--- In DTXpress@yahoogroups.com, "jkfrench" <jkfrench@y...> wrote:
> Hi,
then
voices
a
the 'foot
> triggers').
mappings
and
that
a
mono
Guys,
See my message #11284 or a fairly recent rundown on the options for
kit expansion. I won't reiterate that material here. Even though the
DTXpress will not retain the mapping of extra inputs on a kit by
itself when you exit that kit, any trigger to MIDI interface (TMC)
worth its salt will allow you to store parameters created for the
DTXpress. Once you assign permanent note numbers to voices in the
DTXpress Utility menu to be used with particular DTXpress kits via
external inputs, and make the adjustments on the TMD's own bank, you
can access them easily whenever you choose a particular kit on the
DTXpress. The limiting factor may ultimately be the number of free
MIDI notes on the DTXpress. I don't remember exactly how many are
available but mayber fewer than yhou think.
I may not be reading JK correctly, but the DTXpress stereo inputs
(like the crash input that JK mentions) cannot be split into two mono
pads with a Y adaptor , even though it uses a stereo cable to produce
two sounds (look up "stereo input," "rim switch," or "FSR" for the
reason). Input 9/10 (dual-trigger) is not simply a split stereo
input; it is a totally diffrent animal. The only possible way to
split a stereo input at this point is Keith Raper's hard-earned
invention (temporarily called the "Magic Box"), which may reach the
market in one way or another relatively soon.  Stay tuned (search the
archives for our recent "Special Notice" to all members for a
detailed descriptio of it and give us feed back by replying to it, if
you haven't already).
Ed
