drum sets during songs
2005-03-29 by ajoantmug
Hello, I am learning more every time I sit down behind this drumset. I
also seem to have new questions each time.  I am trying to toy with
different recordings, which leads me to this question: How can I
record 1 track of a song with 1 drumset and record the second track
with a second drumset? What I am trying to do is lay the first track
down with a pretty standard jazz setup and the second track with a
vibraphone voicing so I can play different notes over the original
beat. Thanks in advance!
Re: drum sets during songs
2005-03-30 by emf
I
To the best of my knowledge, you can't do it on the DTXpress sequencer
alone without erasing the song. You'd have to play along with a song
via MIDI on another sequencer while recording the combination on track
1. Then you could record on track 2 with your second kit, or whatever
melodic instruments you wanted to add.
Ed
2005-03-31 by architiger1
im fairly new to it as well, but couldnt you make the song a "pad
song"...start the song with the pad, recording the first track with
that song and the kit using the song, then use the second kit on the
second track?
2005-04-01 by emf
--- In DTXpress@yahoogroups.com, "architiger1" <architiger1@y...>
> second track?
Architiger,
I can see how you might have arrived there. But a pad song isn't
different from any other song in the module. It will have been
composed on two tracks. It will not be mixed down to a single track by
virtue of being played within the context of a particular kit. It
isn't actually even "played" on a pad and thus recordable on the
sequencer again. The programmed pad simply triggers a pre-existing two-
track song already in the sequencer. No room at the inn.
Ed
2005-04-01 by architiger1
> Architiger,
track by
two-
> Ed
i see now. that clears it up a bit.
a related question:
could i make a drum set with intrument voices (say bass) and record
some riffs (with each pad/input being a diff note) then play along
with it on another set, and record that?
2005-04-02 by emf
> a related question:
I can't see any reason why you can't use the tone generator to create
an instrumental kit and record a melody from it on track 1.
Quantization could smooth out any imprecision in tempo. Then you could
record your drums on track 2. I think one of our members describes
doing something similar, and using the bass track as a pad song to
trigger with his kick (or something like that). We added his method in
tips and tricks at dtxpressions.com. You might want to take a look at
it.
Ed
