questions from a new user
2005-04-26 by phoenixrnb
Being brand new to the electronic set up, having played accoustic for
donkeys, it's good to see that us older ones (late 40's) are still
getting enjoyment playing drums after all these years. Once a
drummer...............!!
I'm slowly (very) coming to terms with my electric kit. I picked it
up
second hand, so that I could compare the feel,and experience, before
possibly upgrading further.
I've got an original DTxpress with Roland KD80 kick and mesh snare
with Roland cymbals. All other pads are Yamaha.
As accoustic drums don't come with instruction manuals, and electric
do, I've done a lot of headscratching but am managing to get a decent
sound from them and am enjoying the experience.
Few questions however, which I'm hoping to have your assistance on.
1 Being an older kit, some of the pads do seem loose when attached to
the frame and theres a bit of movement even when tightened. Can the
pads be dismantled and the clamp inside(or whatever) be tightened?
2 I like a good cymbal crash, but am having difficulty getting a
decent, loud sound when playing in the band, and a good bell sound.
Any tips?
3 Can you recommend the best midi cable to get and where to get it
from so i can download some kits?
Thanks a lot, and keep up the good work. I'm sure these won't be my
only questions
Steve
Re: questions from a new user
2005-04-26 by emf
to
> Any tips?
> only questions
Hi Steve,
Good to have you with us.
1. The threads on the plastic clamps start to wear after a while and
lose their grip, and the smooth surface of the rack isn't great for
bite, anyway. Many people simply replace the clamps with heavier duty
metal ones, usually from Gibralter.
2. Try changing the Volume Mode in Utility to "live" so that you can
use the front knobs to control kit levels and setting the overall
volume of the kits in Voice to 127. Avoid turning up the pads' gain
unless you're trying to maximize dynamic range. It's also possible
that your Roland cymbals aren't getting the volume out of the module
that Yamaha cymbals would. I remember experimenting with Roland CY-6
cymbals through the DTXpress; they were all right but not as lively
as Yamaha's own. YOu might try changing the pad type for them to one
of the "miscellaneous" options to see if that helps. Don't hold me to
it, but I remember Cymbals voices 32-34 as being the best bell type
sounds. Maybe layering two of the same ones, or even two different
ones, as v1 and 2, on a cymbal will increase the volume. The cymbals
also tend to get overwhelmed when playing live. If you turn the
individual volume settings of the other pads down a little but leave
those of the cymbals higher, you might have a better balance on stage.
3. Any MIDI cable will do these days. Whatever your local music or
computer store or web outlet carries will work. Length isn't much of
a factor unless you're planning a 16 m run. You can even get a cable
with a joystick adaptor if you have a Soundblaster-type card on your
PC.
Ed
