Recording Session
Recording Session
2005-08-08 by WoofwoofX
Hello there,
I amnot a drumme, but we have bought a DTXpress III Sp for our studio
and not mutch of experience with it, hopefully I will get a hand from
you guys in order to do a recording session with Cubase sx (in 3 days
time)so:
1- Drumer Tried to trigger Ghost notes and the least vel I got it was
18 and not all the hits were recorded, How do you achieve ghost notes.
2- using brushes ...which is better tell the guy to bring his snare
and record it accosticly... or is there a way to work with it on DTX.
3- trying to achieve swiiishhhhhh effect by continuously hiting a
cybal will retriger the note and instead I will have a machine Gun
effect... is there any way to do it or should I tell the drummer to
bring his cybal and Mic it.
4- Is it possible to record Cymbal Chokes via MIDI and if not any
ideas or woekarroung.
5- do you have a drum map for cubase sx ...note I have placed one in
the forum's files section but it is based on the excel file already
there and it didn't match?
Thanks a million
WoofWoofX
Re: [DTXpress] Recording Session
2005-08-08 by matthew jones
I'll have a go at answering at least _some_ of your questions (though I'm
not the most experienced user here):
You can do a lot adjusting the gain, minimum velocity and velocity curves
for the trigger inputs.  In the trigger setup you can select which trigger
to edit by hitting it, then increase the gain to pick up lighter hits
(decrease to make you have to hit harder).  Is there a minimum velocity
setting? can't remember.  The velocity curve can adjust the way in which it
gets louder with increasingly hard hits and you can make it boost your
accents or make heavy hits almost the same volume as quieter ones.  I think
there are other controls that may also help here.  So if you are having a
problem with ghost notes not recording then increase the gain (but be warned
this can bring you into problems such as the other triggers interfering with
one another, setting each other off if gain is too high).  If the quietest
notes are getting picked up but send out too high a velocity number then I
think adjust the minimum velocity and velocity curves.
no point playing with brushes on the electronic kit.  If you want the brush
sound, record it acoustically.  If the guy just prefers playing with brushes
as opposed to sticks then make him use the flexible plastic rod ones
(whatever they're called) since these may act as brushes without many of the
nasty effects of brush 'sticking' to head, too soft to get picked up, etc.
Yeah I have mentioned this on the list and nobody seems to make any comment.
Its also just the way in which the cymbal sound drops in level when you hit
it quietly after hitting it loudly just before.  Impossible to do on a real
cymbal (without choking...) it sounds ridiculous and pisses me off.  This
pretty much makes the cymbals useless for playing anything other than a
standard crash/splash, so yeah you really need live cymbals for these kits.
can't answer any more q's. hope that is of some help!
Matt
http://www.loopit.org
To: <DTXpress@yahoogroups.com>
Sent: Monday, August 08, 2005 6:42 AM
Subject: [DTXpress] Recording Session
> Hello there,
> time)so:
> Thanks a million
> WoofWoofX
Re: Recording Session
Cheers mate,
You really helped in clarifying issues I thought that noone has faced
before.
Please guys if you have any more info I do appriciate your help.
//Danny
(though I'm
was
notes.
curves
trigger
hits
velocity
which it
your
I think
having a
be warned
interfering with
quietest
then I
snare
DTX.
the brush
with brushes
ones
many of the
up, etc.
to
comment.
you hit
on a real
off.  This
than a
these kits.
> Matt
> From: "WoofwoofX" <woofwoofx@y...>
> > Hello there,
studio
from
days
> > time)so:
was
notes.
snare
DTX.
to
in
already
> > Thanks a million
> > WoofWoofX
2005-08-12 by Nick Carroll
Regarding the use of brushes, it just isn't possible to use them
with an e-kit. But I have used sticks on the module's brush kit when
playing live with my country band. It didn't sound too bad, and I
tweaked and changed the sounds to suit what I wanted, but obviously
there are limitations, and real brushes on an acoustic kit will
always sound better.
Nick.
--- In DTXpress@yahoogroups.com, "WoofwoofX" <woofwoofx@y...> wrote:
> Cheers mate,
faced
> before.
> //Danny
> (though I'm
it
> was
ghost
> notes.
velocity
> curves
which
> trigger
> hits
> velocity
in
> which it
boost
> your
ones.
> I think
> having a
(but
> be warned
> interfering with
> quietest
number
> then I
> snare
on
> DTX.
want
> the brush
> with brushes
> ones
> many of the
picked
> up, etc.
hiting a
Gun
drummer
> to
any
> comment.
when
> you hit
do
> on a real
> off.  This
> than a
> these kits.
> > Matt
> > > Hello there,
> studio
hand
> from
3
> days
> > > time)so:
it
> was
ghost
> notes.
> snare
on
> DTX.
hiting a
Gun
drummer
> to
any
one
> in
> already
> > > Thanks a million
> > > WoofWoofX
