Crosstalk
Crosstalk
2005-09-16 by rhys_nataly
Firstly I want to say hello :). I have just recently purchased the
DTXpress, second hand, great kit. I have joined this group because it
looks very helpful and you all seem a happy bunch :).
Any way my problem:
At first all was well then (unless I didn't notice at the start) major
crosstalk(CT), when I hit the snare or crash(crash Triggers
occasionally and sometimes quietly also) they have CT with tom 1, I
changed the settings in Specific Rej and Self rej etc none of this
worked. Good plan, I moved the snare off the same rack as the tom 1
(the short one pointing up) and put it on the cross rack by its self
no more CT AT ALL hooray. Now the crash, I moved this to the rack with
the brain, it still has CT and triggers occasionally etc, I thought it
may be broken??? I have now swapped it (completly) with the ride (to
check if it is broken), NOW this is strange, it still does not trigger
all the time etc(must be broken I'm thingking) but the most amazing
thing is it still has CT with tom 1??? WHY??? If the original ride did
not have CT with anything then settings must be right and all should
be ok??. what am I missing. is the information (settings) processed at
the trigger or at the brain?? :(
Re: [DTXpress] Crosstalk
2005-09-16 by john@johnallsopp.co.uk
> Any way my problem:
Since no-one has answered, I thought I'd just say hi, otherwise we'll
rapidly lose our reputation of being a happy bunch.
Personally, I've not actually played with the rejection settings, I
got rid of all my crosstalk problems (I only got crosstalk when I
re-arranged the pads away from the recommended Yamaha setup) by
re-siting the pads so hitting one didn't vibrate another.
Another possibility is the .. ummm, what's it called .. oh yes, the
Trigger Setup. I'm currently using DT10/20 while I'm waiting for a new
bass drum pedal. See p12 of the owner's manual.
Good luck
J
