New member - question on midi function
2005-10-11 by pmarb38
Hi all, recently bought myself a dtxpress 2 kit (used to play drums in
a college band 20 years ago, thought I'd get back into drumming again)
and searching on the net found this site - an excellent source of info!
Wanting to expand  my kit and wondered could I attach a Yamaha DD55 via
midi out on the DD55 to midi in on the DTX 2  module ( or is it the
other way round?), - would this allow me to assign sounds from the DTX
2 module to the 7 pads on the DD55 and hear them when i hit the pads on
the DD55 - or have I got the whole midi thing wrong?
any help appreciated, thanks
Re: New member - question on midi function
2005-10-12 by emf
--- In DTXpress@yahoogroups.com, "pmarb38" <a.r.butterworth@b...>
in
again)
info!
via
DTX
pads on
Welcome to the group. Any device that can be programmed with MIDI
note numbers will be able to access and play the sounds on the
DTXPress module. Go from MIDI Out on the DD55 to MIDI In on the DTX
(depending on how the DD55 operates, the reverse connection may also
have a function, but not necessarily). I won't go into detail here,
but first you have to find five unused MIDI numbers in the DTXpress
Utility menu and assign them to voices for the DD55's pads to play
(see Voice 5.1, p. 59). You'll be able to program them to your liking
(see pp. 60-61). Be forewarned, however, that once you've given your
selected voices their own permanent note numbers, they will be the
same in every user kit. (You'll notice that the voices in the
DTXpress kits normally don't have permanent MIDI note numbers; only
the inputs have permanent MIDI notes assigned to them. Input sounds
change from kit to kit, but not note numbers. Your DD55 voices will
remain the same whatever DTXpress kits you choose).
Ed
