dtxpander for 3zone pads?
2005-10-21 by epvk_jahoe
I'm thinking about making a dtxpander circuit for a brain inputs 6 and 7, by connecting a
trigger to the stero PCY65S's. Some time ago, Keith wrote that just a few extra
components are necessary to do just that, but the problem is I don't know how the 3
different signals ("rim1", "rim2", main) can run through a stereo (2 signal) cable (similarly,
how this works for the TP65S in input 2 is a puzzle). The only option I can think of is that,
in terms of the jack, for example main gives signal to the tip, "rim1" only gives a signal to
the part below the tip, "rim2" gives signal to both...? But how to build a circuit for that?
Keith? anyone?
Btw the two circuits that I have been able to solder are for normal stereo pads. They work
well only if I omit diode D2 from the circuit (as suggested by others) which is connected to
a Pintech Concertcast. Also mentioned by others and working best for me is reducing R1
to as low as possible values for increased sensitivity of the "rim pad".
Erik Paul
