--- In DTXpress@yahoogroups.com, "xillion2one" <xillion2one@...> wrote:
> Anybody know why I can't split a dual zone pad to two different inputs
> on my DTExpress?
> -joeR-
Joe,
If you mean a standard Yamaha dual zone pad then yes, I know the
reason - there is only one piezo output from a Yamaha dual zone pad,
the other is just a switch closure. If you split it with a Y splitter
then one input will get the piezo, the other will just get a switch.
Some other make pads have two piezos and you would be able to split it
with a Y splitter into two separate inputs - in fact that would be the
only way of using it with a Yamaha module without my DTXpander box.
Keith.
