RE: Spam:[DTXpress] PCY65S Question
2006-06-06 by Damon, Rob
The velocity levels for the pad and rim are via the single piezo in the pad. Rim is just a ribbon switch. When you hit the edge, you are triggering both the piezo and the rim switch. When the module gets a signal from the piezo without the rim switch closure, the main pad sounds at a volume level based on how hard the pad was struck. When the module gets a signal from the rim switch at the same time as the piezo then the module plays the edge sound at the volume level the pad was struck. The TP65S will only function as a two zone pad on the hihat input. Both rims with play the same sound. OGD ________________________________
From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On Behalf Of geerayman Sent: Tuesday, June 06, 2006 12:36 PM To: DTXpress@yahoogroups.com Subject: Spam:[DTXpress] PCY65S Question I'll be getting a DTXpress III soon, but I have a question about the dual-zone cymbal trigger. Is the edge velocity sensitive like the main body is? My concern is that if I set up a second sound on the edge trigger, it will only be one level. TIA! ______________________________________________________________________ The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ______________________________________________________________________ This email has been scanned by the MessageLabs Email Security System. For more information please visit http://www.messagelabs.com/email ______________________________________________________________________
