Urgent !!!!!! dtxpress recording sequencer
2006-08-20 by geek_boy_in
Friends,
Suddenly am facing this weird problem in the dtxpress. I usually
record my practice in the dtxpress using the "rec" function .....
typically i would record, listen to it, get the faults and delete the
track (sound edit -> clear track option) .......
but now suddenly it isn't recording properly i can only hear the
various pad hit sounds on the measure that i select. (means if i
select 4/4 measure with quarter notes, then it would record only the
notes/hits on 1,2,3 and 4th counts.... the other hits are missing) ...
Please help whether i messed with my dtx setting somewhere ?? Will
reset'ing to factory setup help ???
Please share your inputs,
Best Regards.
