Using a 2-position mono HH pedal with a DTXPRESS
2006-08-29 by bncarty
I was wondering if anyone in this group knows if a mono HH controller
with a standard two-position switch (closed/open) would work with a
DTXPRESS I module? I realize there's no way of getting all the middle
switching options of a true Yamaha peddle, but would I at least get
the open and closed control? My old drum brain packed it in and I'd
like to know what my HH pedal options are before I buy a DTXPRESS.
Thanks
bc
Re: Using a 2-position mono HH pedal with a DTXPRESS
2006-08-29 by Keith
--- In DTXpress@yahoogroups.com, "bncarty" <bncarty@...> wrote:
> Hi,
> Thanks
> bc
Yes, it will work (I just tried it to make sure).  Ideally you want
the switch closed when the foot is pressed down, but you could always
reverse the voice if it was the wrong way round.
Keith.
Thanks for the quick reply Keith. When you did your test, did you
use a stereo connector or a mono one?
--- In DTXpress@yahoogroups.com, "Keith" <keith@...> wrote:
> --- In DTXpress@yahoogroups.com, "bncarty" <bncarty@> wrote:
> > Hi,
controller
with a
middle
get
I'd
DTXPRESS.
> > Thanks
> > bc
always
> Keith.
2006-08-29 by Keith
I just unplugged my pedal and shorted the tip of the existing stereo
connector to the shield with a piece of wire.  I can check with a mono
connector if you like.  I have never quite worked out exactly what the
stereo ring does on the HH Controller, but I think it is to help
produce the splash sound.
Keith.
2006-08-30 by bncarty
That's okay Keith, thanks anyway. I think I've got enough to go on. I
have a number of different stereo and mono plugs so I should be able
to come up with something that works. You answered my basic question
that it will at least work and I can go ahead and get the module.
I may even look around for a proper HH60/HH65 of HH80 controller so I
can have the "middle" control too.
Thanks again.
bc
mono
> Keith.
2006-09-10 by bncarty
Well, no luck. I've been poking around for a few days now, and I've
tried all kinds of cables and trigger setups, but I can't get
anything from my hi-hat peddle. It's almost like the DTX is looking
for an active signal from the peddle instead of just an open closed
switch.
on. I
able
question
so I
> Thanks again.
> bc
you
stereo
a
> mono
what
> the
> > Keith.
2006-09-10 by Keith
> switch.
It is a while since I took my DTXpress pedal apart, but it just has a
few resistors inside and the FSR just progressively shorts them out as
you put the pedal down.
I took the cable out of my HH pedal and shorted the tip to the sleeve
and it gave a closed HH sound, and open HH when I didn't short it out
(while hitting the pad).  I suggest you try the same in case there is
something wrong with your pedal.
When fully closed the pedal has as resistance of 150k, so you could
try putting that in series, although it doesn't seem necessary on mine.
Are you always getting a closed HH sound or open?
Keith.
By the way ..
2006-09-10 by Keith
I was using a stereo cable and leaving the ring open circuit.
Keith.
More information
2006-09-10 by Keith
I have done a bit more checking and while I get the open and closed
sounds, I don't get the foot closed sound.
The solution to that is to use a stereo cable and stereo connector and
connect your switch between the connector tip and sleeve and a 150k
resistor between the tip and the ring.  There may be other
combinations that work and other resistor values, but that worked on
mine (DTXpress III).  I now get closed, open, foot close and splash
sounds from a switch (I only checked the open & closed sounds before).
If you are still having problems, let me know and I will take my pedal
apart again and find out what is inside.  I measure 1k to the ring
when the foot is closed and 150k to the tip when the foot is closed,
but the circuit was a bit wierd with a diode and capacitor as well so
you may have to reproduce that if you still cannot get it to work.
Keith.
Re: More information
2006-09-11 by bncarty
Hi Keith,
I really appreciate all the research you've done on this, but I'm
just going to take the cowards way out and buy a proper Yamaha
peddle. Maybe some cold winter day I'll experiment with my existing
peddle, but for now, I just want to get playing.
Thanks again.
and
on
before).
pedal
closed,
so
> Keith.
2006-09-11 by Keith
> Hi Keith,
> Thanks again.
If you look at recent posts here you will see that ddindublin may have
one to sell, unless I can think of a novel solution to that problem :-(
Keith.
