Some hits in snare rolls not registering using DTX as midi controller
2006-09-11 by mac_jason
I'm using electronic drums (DTXpressIII) as a midi controller to drive Reason 2.5's NN-XT sampler, but find that it doesn't work so hot with snare rolls. Basically, the sampler isn't triggered on each hit when the drum is played rapidly. It "misses" some. This doesn't happen running the drum module direct to an amp, so I imagine its a problem of configuring some parameters on reason or its sampler, or perhaps using different software. I've already tried messing with the envelope knobs (attack/hold/decay/sustain/etc.) to no avail, though admittedly I'm a novice with Reason. I also got the same problem using the drum machine. Has anyone else out there had/resolved this problem?
