--- In DTXpress@yahoogroups.com, "Keith" <keith@...> wrote:
> --- In DTXpress@yahoogroups.com, "draker2003" draker2003@ wrote:
> > How do you recording directly into 4-track DAW with DTXpress w/o
using
> > MIDI? I looked on the back of the DTXpress II I have and there
doesn't
> > appear to be a standard I/O, 1/4-inch jack or RCA outs?
> Just use the two 1/4" jacks on the back marked "OUTPUT" - R & L/MONO.
> If you just use the L/MONO one then the DTXpress combines the two
> stereo channels into one mono channel. If you also plug a jack into
> the R channel then it splits them (it detects the other jack). Note
> that the master volume control affects these outputs.
> Keith.
Hi Keith,
Cool. Thanks for taking the time to respond. I'll try your suggestions.
One more thing: How would you recommend going into the DAW - go stereo
and split the R & L by panning hard left and hard right, and/or keep it
in the middle, or go MONO onto a single track -- and keep it in the
center of the mix when you get to the mixing stage? Finally what is
your recording background -- home enthusiast, semi-pro, etc.? Thanks!
