Tips for the DTXPRESS RHH-130 hi-hat controller
2007-12-04 by synthartist69
I found that the hi-hats tend to rub against the the stands shaft
which prevent them from fully opening or closing at times. Yamaha
actually made a very poor system for this hi-hat. The bracket that
mounts to the bottom of the high hat with the wing nuts is very
poorly designed and very cheaply made. The hih-hats are too heavy for
the plastic-pot metal system and tend to not stay tight which causes
even further rubbing against the hi-hat shaft. I have found a
solution that seems to be working thus far...
Put a washer in between the two back pieces that act as a collar for
the hi hat shaft then tighten the round grooved nut and the wing nut.
This will allow more clearance for the hi-hat shaft to move freely up
and down.
Purchase a tube of lithium grease and grease the hi-hat shaft. Also
grease inside the collar area, especially where the hi-hat shaft
touches.
The hi-hats will be slightly shakier, but not enough to really matter
or enough to affect your playing. The response of the hi-hats are now
much much better.
Yamaha should redesign the entier mounting bracket for this hi-hat so
that these modifications are not neccessary. It amazes me that they
didn't do it right to begin with. Gheeeeeeeze!
Happy drumming everyone!
